Does this vacuum have a post motor hepa exhaust filter ? if so how is it removed ?
SOURCE: want to replace HEPA post filter
http://www.dyson.com/customercare/manuals/us/dc07_manual_us2007.pdf
here is the link to your owners manual. scroll down to page 6 it shows you the filter to clean and how to take it aprt.
SOURCE: HEPA FILTER REMOVAL
the filter should be easily accessable on the right side of the vacum cleaner if it's facing you. at the base of the vacum there is a large round cover that is removable and behind it it the filter. generally you dont need to replace it. its a big round spunge that you could rinse with water and squeeze out until it's clean. you also need to rinse the filter cover which is like a plastic netting. let it dry for 24 hours and you should be good to go!
enjoy!
SOURCE: remove hepa filter
Turn the Dyson on its back as if you were servicing the beater brush and on the RH side you'll see the filter housing for the HEPA and a T-15 Torx screw. Remove this screw and then remove the cover for the HEPA filter.
SOURCE: Does my Dyson Animal vacuum have a hepa filter?
The HEPA filter is not a cleanable item. The pre-motor filter is the washable one.
SOURCE: I own a Dyson 17
The procedure to replace the belt is as follows:----
1.First you will have to loosen 3 screws from bottom plate and remove it.
2. Wiggle roller until it pulls straight out.Do it slowly.
3. Then carefully squeeze the new belt and loop it over metal drive gear (you'll easily see the gear).
4. Keeping belt on gear, insert edge of roller through belt and rotate the roller while pushing it through belt until it is inside the belt, then continue rotating roller and sliding it over until belt is in position over gears on roller.
5. Insert roller into slots on that it came out of, reattach bottom cover and its done.
And the HEPA Exhaust filter.This filter is located directly underneath of the dust bin when it has been removed from the vacuum. You can find the filter by finding where the air is being exhausted. This filter should be replaced at least every 3 months. If you notice that your Dyson has lost some of the suction since you've had it, cleaning the filter should be the first place to start. You can remove the filter and try cleaning it with water and see if that helps.
This will help.Thanks.Helpmech.
