Question about Whirlpool WTW6400SW Cabrio Washer
Can lid lock be disable on whrilpool washer WTW4800BQ
I need to check the drain pump to see if it is clogged as my washer won't spin. It is a whirlpool wtw4800bq top loader. How do I get to the drain pump?
Go to www.repairclinic.com and enter WTW4800BQ. You will be presented with a list of common replacement parts (such as the pump) and may be able to view a generic Whirlpool video showing disassembly and identification of major parts and assembles.
Oct 05, 2016 | Whirlpool WTW4800BQ White-on-White 3.6 cu....
Lid lock broken. Can it be bypassed?
yes - jump the two wires going to the switch by the lock to bypass.
Mar 14, 2016 | Whirlpool WTW4800BQ White 27" Washer Top...
Need to bypass lid lock Kenmore 2002 white red blue yellow which ones
Kenmore Whirlpool top load washer. lid lock issues - YouTube
? 3:34
https://www.youtube.com/watch?v=Vf1hVhpC8yE
Mar 12, 2013 - Uploaded by EurekaRecycler
Kenmore Whirlpool top load washer. lid lock issues ... The new one I bought or actually have a loan on the EXACT issue and I've only had it 3 ... cheap way to bypass the lid lock which is irritating, aggravating, frustrating on my ...
Kenmore Lid Safety Switch ( Temporarily Fix ) - YouTube
? 13:17
https://www.youtube.com/watch?v=UMlLqEF8EGM
May 20, 2012 - Uploaded by matttherepairman
This is a easy way to bypass a lid safety switch with-out cutting into the wire! Did your Kenmore Washer machine fill up and stop ? Your Lid ... +Jerry Munroe That is correct,,, You will not need to cut any wires Thank you for watching .... Kenmore Whirlpool top load washer. lid lock issues - Duration: 3:34. by ...
how can I disable the lock on my new top load Kenmore ...
www.shopyourway.com > Manage My Life > Questions
Jan 08, 2016 | Kenmore Washing Machines
Can the lid lock be bypassed?
Yes you can turn washer upside down find switch cut the wires twist together and tape up bare wires
One problem you have disabled a safety feature with risks to your or other user safety
Is it a lid or door lock you want to disable if it is a door lock switch risk of flooding rooms is higher
Jan 01, 2016 | Washing Machines
I need to bypass the lid switch on a whrilpool cabrio
no one in their right mind should give you this do to safety issues. bad idea
Oct 19, 2014 | Washing Machines
Won't go into final spin and lid lock light flashes
Will try and point you in the right direction you probably have one of the F7 codes which relate to motor speed, since the lid is locked you have to get the entire top up to do this on the back of the machine there is a screw on each side same level remove slide top bout 1/2" forward lift on the front panel infront of basket to the left should be a plastic packet with the service manual it will tell you how to place the machine in diagnostic and explain the error code and possible causes
Sep 05, 2014 | Whirlpool WTW4800BQ White 27" Washer Top...
I can not get the lid locked light yo stop flashing and the lid is closed and has not been in a spin wtw4800bqcycle
Check the lid to see if there is a small metal tab sticking down and at 90 degrees from the lid. If it gets bent that will cause it to do weird things. You can easily straighten it up with a pair of pliars.
Sep 05, 2014 | Whirlpool WTW4800BQ White-on-White 3.6 cu....
Whirlpool Cabrio Lid
The lock cannot be disabled, The lid removes easily and is also simple to replace.
Depending on where in the world you are depends on where you will get a lid, If you do a google search in your area for whirlpool spares you will get some results.
Mar 10, 2012 | Whirlpool WTW6400SW Cabrio Washer
My washer comes on and fills with water and i can pump out water but its not spinning or doing any tub movement at all, i have the whrilpool calyspo top load
If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Replace the lid switch with this part.
Jan 02, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool WTW6400SW Cabrio Washer Logo
167 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
