Question about Whirlpool Refrigerators
Water accumulating inside on shelfs - Whirlpool Refrigerators
  • 351 Answers
If the freezer is on top then you have a drain problem unglog drain and should be ok
Posted on Jun 23, 2009
I have ice accumulation on the bottom shelf of my freeze of my Maytag side by side MSD2957DE. There seems to be water dripping down from the back inside panel. Is this something I can fix on my own
If you have an ice maker, or water dispenser turn off the water supply to the fridge temporarily, and see if the problem still exist. The solenoid water valves on some of these models accumulate mineral deposits and don't close completely after time, thereby leaking.
Sep 19, 2014 | Maytag Refrigerators
Why is water leaking from the inside bottom of refrigerator?
Hay Lola , your drain hose is clogged open the back panel and blowdry all the ice until the water drains good luck APPLIANCES R EN
Mar 14, 2013 | Magic Chef Refrigerators
Water is accumulating on the shelfs and bottom under the crisper inside of refrig. water to the ice maker is turned off and has been for years unit is 20 years old and the problem started 6 days...
Water from the defrosting operation is not draining properly in the drain hole. Must be something blocking the drain. To remedy it yall must remove the service panel in the freezer and clear the drain.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 22, 2011 | Hotpoint Refrigerators
There seems to be water accumulating on the top shelf of our fridge. items on the top shelf get wet and the water also ends up dripping on the floor after awhile. we have not got the ice maker hooked up
YOUR DEFROST DRAIN IS EITHER CLOGGED WITH ICE OR GUNK, YOU CAN UNPLUG AND DEFROST, THE ICE THIS TAKES SOME TIME. AS THE OPENING FOR THE DRAIN IS IN THE CENTER BACK BELOW THE EVAPORATOR. AND THE ICE MAY BE FROZEN FOR 5-6 INCHES INSIDE DRAIN. YOU WILL SEE WATER DRAINING INTO THE PAN ON TOP OF COMPRESSOR WHEN AND IF DRAIN IS CLEAR. IF NOT ICE THEN TRACE DRAIN FOR BLOCKAGE. SOME FRIGS HAVE A SMALL PIECE OF PLASTIC AT BACK OF FRIG THAT PULLS OUT AND HAS VERTICAL SLOTS TO KEEP OUT DEBRIS, THAT WOULD BE WHERE GUNK WOULD BE.
Mar 10, 2010 | Refrigerators
Water accumulates inside on the bottom shelf from time to time -- why
Hi, The defrost drain behind the rear freezer panel is plugged. Remove the rear panel and clear the ice away from the drain. Then you will need to flush the drain hole with hot water to make sure it is open.
Some models require an after market drain heat kit.
Please get me your model # and I can look this up to let you know if you need that heat kit.
Thanks
Vic
Jul 18, 2009 | Refrigerators
Water accumulating in top shelf of refrigerator
Get yourself a thermeter and see what the tempeature is in the freezer. It should be "0" degrees or colder. If it is hanging around 30 degrees +/- you may have a compressor or control problem. You may have a drain tube clogged that takes the water out of the freezer. I am not familar with your model but many freezers are similar.
Mar 15, 2009 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Water accumulates and freezes in bottom shel
The drain for the defrost is blocked, probably with ice. If drain is frozen it will need to be defrosted, and a heat probe attached to the heat element and down through the drain hole. If not frozen there could be blockage in the drain cup depending on the model.
Dec 29, 2008 | Maytag MSD2756G Side by Side Refrigerator
Dripping water
YOUR DRAIN FROM FREEZER TO DRAIN PAN IS CLOGGED,LOOK INSIDE TOP BACK OF REFRIG. SHOULD BE DRAIN HOPPER,REMOVE AND CLEAR OUT DRAIN,THANKS-MIKE
May 29, 2008 | Whirlpool ET1FTKXK Top Freezer...
Refrigerators Logo
47 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
