Question about Ruud UBHC Air Conditioner
Thermopompe stop end start constanly - Ruud UBHC Air Conditioner
    Genius:
  • Ruud Master
  • 1,363 Answers
Going off on safety. could be drawing to many amps or compressor overheating
Posted on Aug 26, 2015
Hello, My thermopompe model is VBHC 21J18SFA. I have it fo 5 years (new). The thermopompe seems to work fine. But the temperature does not cool down to what I set to be. Inside temperature is at 28...
Check your filter make sure it is new and not clogged with debre. If thats ok you have a refrigeration leak in the sytem most likely. Have a pro take care of it. Its not a DIY project let me know if I can further assist
Jul 23, 2011 | Ruud UBHC Air Conditioner
Horn starts and won't stop - why
You probably have a stuck horn relay or a wire is shorted and constanly providing voltage to it.
Jul 14, 2011 | 1998 Ford Explorer
Water flow to my humidifier wont stop. and the pump is constanly running.
Sounds like the float valve inside the water holding tank is stuck in the open (down) position. Unplug the unit and take the cover off the tank portion of the humidifier. Look inside and you will see the float valve, if it's in the down position, manually lift is up. If it stays in the up position the incoming water should stop, The next thing is to determine what caused it to get stuck? Is there some sort of debris in the tank? Is the float lever rod bent or out of place? Does the float on the end have a hole in it and is full of water? These are the things you need to start with in troubleshooting the unit.
Hope this helps to get your started in solving the problem.
Mar 11, 2011 | Aprilaire 550 Humidifier
The drip panel of my ref, 690/s is overflowing and dripping constanly. the water does not get evaporated. can you show me how to fix it?.
Check the door seal around the freezer... it is letting in moisture which defrosts and then ends up in the pan...
heatman101
Aug 27, 2010 | Sub-Zero 690 Side by Side Refrigerator
End to end configuration errors appears constantly ? fix
You could try doing all the updates to Service pack 2 but i would seriously consider buying an upgrade pack to Windows 7 you'll it compared to vista. Please vote...cheers from Scott
Jul 04, 2010 | Microsoft Windows Vista Home Premium with...
My cruise control stopped working fuses are good any suggestions, of what to check
more than likely if the fuse is good the cruise servo is bad when controls the speed constanly
Jan 30, 2010 | 1995 Buick LeSabre
Thermopompe stop for no reason
Chech the door switch, & see if the fan door switch is on correctly.
Sep 12, 2008 | Heating & Cooling
Vehicle idles horribly.
throttle cable sticking??
Jul 17, 2008 | 1995 GMC Safari
Ruud UBHC Air Conditioner Logo
70 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
