Question about GE JVM1350BW/WW/AW/SY Microwave Oven
I have a ge microwaveJNM1851DM288 what are the metal racks for
JVM 250vwoo1
Pry off plastic tab. Clean up burn marks with sand paper and touchup paint. Order a new rack clip. Also clean any burn residue off rack.
MOST IMPORTANT: After the repair, do not put the rack back in unless you are cooking on it. Running the microwave with nothing on the rack is what causes this to happen.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jeffrey_634abadf963e31e5
Sep 05, 2014 | GE Microwave Ovens
Maytag Microwave MMV5207AAQ
its common to all ovens! causes are food spills and oil spills left uncleaned! painting only might fix the problem for a while, but it won't give you a lasting service!!
! you should buy a new rack for much safer use!
keep in mind also to clean the oven after every use! (let it cool first of course!)
Dec 09, 2007 | Microwave Ovens
Cooking with convection oven
You do not have to remove the turn table, but I use the metal rack when cooking with convention.
Apr 15, 2014 | GE Profile PEB1590 1.5 Cu. Ft., 1000W,...
My JVM1350 has metal rack inside. How do I use it. I thought you couldn't have any metal inside.
on the inside of micro.. the rack is supported with plastic clips.. this allows stock part metal rack work
May 26, 2012 | GE JVM1350BW/WW/AW/SY Microwave Oven
I'm experiencing occasional arching from the center of the oven i.e. out of the spindle that rotates the metal rack and glass turntable. I cleaned thoroughly and it seems to have minimized the proble
Its unlikely to be associated with the tuntable motor. Units are tuned to prevent arching. Therefore it appears something may have changed inside the unit. Be sure there are no loose items or bits of foil or other mateallic items inside. Also check metal turntable.
Dec 31, 2011 | GE Advantium 120 Convection/Microwave Oven
Sparks from GE Microwave - HVM1540SN2SS
THERE SHOULD NOT BE ANY METALS IN A MICROWAVE WHEN THE UNIT IS RUNNING
If the unit paint is flaking and behind that flake is metal.. You need to throw it away or talk to your appliance guy and see if there is a speacial paint to coat the metal so you can use your MW
Jul 25, 2010 | GE Microwave Ovens
Sparks coming from inside of oven
This is a simple fix.
You need to remove the rack and all of the holders.
Clean the metal thoroughly where the rack mounts fit.
Replace all the rack mounts with new ones, insert the rack and you're all set.
Then be sure to keep it really clean, even if you have to remove the rack and new mounts periodically to get it really clean.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Dec 27, 2009 | GE Profile Spacemaker Over-the-Range...
My microwave sparks inside where the metal rack rest on the plastic holder
You will need to remove the rack and all the rack holders.
Any grease or carbon arcs will have to be cleaned thoroughly, and if the metal is charred or damaged, you will need to apply some high-temperature appliance paint, available from places like Wal-Mart or Lowe's.
Then replace all of the rack supports, not just the one that arced.
I'd recommend that your bookmark this link to your favorites.
Dec 06, 2009 | GE Microwave Ovens
Metal rack inserted backwards
It will just have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Mar 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1190WY 003 Microwave Convection sparks
The problem that you are having is that the magnetron inside the microwave is shorting out to ground and it will find the shortest path to reach whatever has metal in it. Replacing the magnetron will solve your problem altogether and you need not do anything else different and continue using your metal racks.
Nov 09, 2008 | GE JVM1190 Microwave Oven
GE JVM1350BW/WW/AW/SY Microwave Oven Logo
24 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
