Question about Midea MDF1-30AEN3-BA4 WP 30PT ES Dehumidifier
Is this on recall list - Midea MDF1-30AEN3-BA4 WP 30PT ES Dehumidifier
Is there a recall on Frigidaire dehumidifier Model FAD504DUD
Some dehumidifiers with the model number, FAD504DUD, are subject to a recall. Record the serial number and then go to https://www.recallrtr.com/dehumidifier to check if your unit was manufactured in the bad batch.
Without the serial number, I can't be sure if your unit is in the 2016 recall. For details, you can look at https://www.cpsc.gov/Recalls/2017/Dehumidifiers-Made-by-Midea-Recalled .
I hope this helps.
Jan 26, 2017 | Frigidaire Dehumidifiers
We use the bucket to gather water in our dehumidifier and it is starting to leak onto the floor instead of the bucket. FrigidaireFAD704DWD Solution?
It may be time to clean out the drain channels, which is a moderate maintenance job. Not too hard to perform for a DiY'er. But, have you checked to see if your dehumidifier is part of the recently announced recall? I remember seeing Frigidaire 70s on the list; (one or two factories make the machine, many companies label it as their own)
Please check the link for the recall and check your owners manual for cleaning procedure. You can download a copy from Frigidaire's website, too. Home Page
Dec 12, 2016 | Dehumidifiers
HE70ER-L Are there any recalls on this Haier Dehumidifier model?
Results
Dehumidifier Recalls - ConsumerAffairs.com
https://www.consumeraffairs.com/dehumidifier-recalls
  1. Cached
The recall is being conducted in cooperation with the U.S. Consumer Product Safety Commission (CPSC). December 30, 2009 LG Electronics is recalling about 98,000 portable dehumidifiers. The power connector for the dehumidifiers compressor can short circuit, posing fire and burn hazards to consumers.
Humidifiers & Dehumidifiers Recall List by WeMakeItSafer
wemakeitsafer.com > ... > Home & Garden > Temperature & Humidity Control
  1. Cached
  2. Similar
Danby, De'Longhi, Fedders, Fellini, Frigidaire, Gree, Kenmore, Norpole, Premiere, Seabreeze, SoleusAir and SuperClima Dehumidifiers. A recall was issued on 2013-09-12 due to a potential fire and burn hazard.
Dehumidifier Recall: How to Find Out if it Affects You
learn.compactappliance.com > A/C & Heating
  1. Cached
  2. Similar
Jun 12, 2014 - How to Find Out if Your Dehumidifier Was Recalled. ... Many popular brands known for having high quality dehumidifiers such as Danby, Frigidaire, and Soleus had models affected by this recall. ... Brands have taken different approaches to how they have responded to the Gree dehumidifier ...
Dehumidifiers recalled after overheating, fires - USA Today
www.usatoday.com/story/money/business/2014/.../dehumidifiers-recalled.../9145635/
  1. Cached
  2. Similar
May 15, 2014 - Appliance manufacturer Gree has issued another recall for a line of its ... .cpsc.gov/en/Recalls/2014/Gree-Reannounces-Dehumidifier-Recall.
Public Notices ' Haier America
https://www.haieramerica.com/public-notices
  1. Cached
Product Recalls. The latest public notices can be found here. Recall Date. Haier America Expands Recall of Chest Freezers Due to Fire Hazard, Sunday, May 12 ...
Nov 07, 2016 | Haier Dehumidifiers
The unit is not drawing water from the air
Mary,
There is a recall on Whirlpool dehumidifiers that may cover your unit, the website lists serial numbers of units on the recall list.
Dehumidifier Recall FAQs
I assume from your question that at least the fan is running. There are many reasons why a dehumidifier is not removing water from the air. Most likely is accumulation of dust and pet hair that restricts the air flow. If you can, unplug it, take off the covers and vacuum out all the dirt from the evaporator and condenser (little radiator like parts). This website has some good blow up pictures of how it is put together and part nomenclature:
WHIRLPOOL DEHUMIDIFIER Parts Model AD25J3 SearsPartsDirect
If the air flow is restricted, the compressor has to work harder to the point that the overload gets tripped. It may or may not be resettable; it is part #10 in the diagram on this page:
http www searspartsdirect com Whirlpool Dehumidifier Parts Model AD25J3...
If you do take the covers off, check that the fan turns freely and you may want to add a drop of oil to each end of the motor if there is a place to oil it. Light oil like sewing machine oil or light engine oil will do.
You cannot really tell if the compressor is working with all of the covers on; and I cannot recommend plugging it in with covers removed because there may be open electrical connections that you do not want to touch. However if the compressor is running, the outlet tube will get hot; that is the one that goes to the condenser [radiator like bundle of tubes nearest the fan] [it may get too hot to touch]. The evaporator [bundle of tubes farthest from the fan] should start to get cold where the tiny little tube from the condenser joins. If neither is happening and you are sure the compressor is running, it is out of refrigerant [freon] and may or may not be worth fixing. If the evaporator ices up [gets covered with frost] it may be low on refrigerant indicating a leak; again it may not be worth fixing.
Jan 15, 2015 | Whirlpool Dehumidifiers
Midea MDF1-30AEN3-BA4 WP 30PT ES Dehumidifier Logo
51 people viewed this question
Top Midea Dehumidifiers Experts
J.D. Browning
J.D. Browning
jasbo
jasbo
 Russ Hill
Russ Hill
Are you a Midea Dehumidifier Expert? Answer questions, earn points and help others
