Question about Swatch Watches
How do you open the clasp? - Swatch Watches
How to open clasp on hugo boss yachting timer ii watch
it has a fold out clasp , holding thumb close to the clasp pull the other side upwards this should open the clasp.
Oct 11, 2017 | Hugo Boss Watches
How do i adjust the band on the slimline mesh skagen watch
Step 1. On the reverse of the strap you should see a succession of ridges. You will also notice a corresponding ridge on the clasp. Sounds obvious, but once you have decided where the clasp should reside on the strap, you need to align these two ridges.
The reverse of the strap
Step 2. Get a piece of string or ribbon and wrap it around your wrist. Snip the string so that one end meets the other and measure this diameter.
Step 3. On the other end of the strap you will see the hook which goes over the clasp - you will see the next picture. From this hook the measured distance will be where the end of the string lies.
The clasp mechanism - the watch is to the right of the picture
Step 4. This is the tricky bit! Insert a small screwdriver into the hole on the main clasp part, from the right hand side and bend it down towards the strap thus opening the clasp. Do not insert a tool from the left side, under the clasp and use the bar as a fulcrum; you will bend this rod and the watch strap will not hook over it. Move the clasp to the desired position and gently locate the ridge nearest the position. Once located, press down on the open clasp until it clicks into place - voila!
Related posts:
Dec 26, 2012 | Skagen Slimline Mesh 358SGS Wrist Watch
HOW OPEN INVICTA WATCH CLASP
Look at this video
https://www.youtube.com/watch?v=dkAoxVYtjXQ
you'll see the clasp as it look s when open. You need to hold the strap and clasp near one side of the 'join' while pulling the upper part of the strap away from the clasp on the other side.
Jan 11, 2012 | Invicta Square Angel Diamond Stainless...
The clasp on my steel watchband pulls away from the band creating a large gap. it looks bad and catches on things. what do i do?
You need to make sure that if you had the watch band adjusted they did not adjust it at the clasp. When you adjust the watchband links should be removed if you adjust it at the clasp the band keeps pulling open. When you open the clasp fully make sure the pins are on the end holes. If the pins are in the end holes then, the clasp is probably sprung somehow and you will need a new one or have a jeweler or watch repairman fix it! You may also be able to order a new clasp from manufacturer! Hope this helps!!
Sep 21, 2011 | Watches
Tag Heuer "link" woman's watch-- can't open clasp!
You just have to pull with more force. Decent watch brands always make clasps very tight.
Apr 15, 2011 | Tag Heuer Watches
I bought my bulova 96R105 today, the jeweler placed it on my wrist, but now I can't undo it. Please help
It may have buttons on the sides of the clasp that you must press. If you do not see the buttons on the sides of band, it is a friction fitting, and you must pull on one or the other side of the "butterfly" clasp for it to release.
If you see a large outside clasp, there will sometimes be a fold over safety. This is called a tri-fold clasp. You must pull up the hinged clasp one direction, then the main clasp the other direction. A bi-fold clasp has no safety, and can be pulled one direction to open.
Feb 04, 2011 | Bulova Diamond Accented Calendar #96R105...
Hello, I have received a just bling womans watch as a gift and can't figure out how to put the wrist ********. Just bling/ JB 6210 serial #17861854
Your watch has double folding clasp and it is opening by pulling bracelet exactly in the middle of clasp. Some clasps are very stiff, so, use a bit of force to open it. Here is the link where you can see how the opened clasp looks:
http://www.amazon.com/Just-Bling-Ladies-JB-6210-Diamond/dp/B002JPK310
Jul 31, 2010 | Bulova Watch
I need help
It probibly is a tri-fold clasp or a "hiding clasp" When you look at you watch can you see a clasp? If not you just need to pull from the middle if the back of the band. One end will open to the left another will open to the right. Don't be afraid to pull on it, that probibly is the main problem your having. Movado makes a solid band that can take some punishment
i
Aug 13, 2008 | Movado 0604586 Wrist Watch
Watch clasp on Tag Heuer
http://www.worldofwatches.com/cust/sizingwatch.asp?d=0
Apr 24, 2008 | Tag Heuer WK1111BA0317 wristwatch
Watches Logo
24 people viewed this question
Top Swatch Watches Experts
Ansel Alberto
Ansel Alberto
Ian Browning
Ian Browning
Level 1 Expert
Are you a Swatch Watch Expert? Answer questions, earn points and help others
