I have a curtis flat screen and when i turn it on the volume automatically goes to zero. I press the volume to turn it up but it just goes back to zero. I press the menu button and it just cycles through the menu slots on it's own. I set down the remote and leave it to show my mom she says to unplug it. I try it and it doesn't work. Any thoughts?
    Loyalty:
    Visited the website for 30 consecutive days.
  • 372 Answers
Take the batteries out of the remote and turn it on manually see if that helps............ you might have a stuck remote.
Also make sure none of the buttons got stuck in the pressed position......
Posted on May 18, 2014
SOURCE: Polaroid HD flat screen TV with DirecTV
I have Polaroid TV Monitor HDMI LCD 15.4" no power light on TV, blank screen, the power adaptor is Ok 12VDC supply. I need suggestion; in any possible problem or parts busted?
Posted on Mar 24, 2008
SOURCE: 52 INCH sharp aquos lcd REMOTE NOT WORKING
Make sure your remote lock is set to off.
Posted on Apr 22, 2009
  • 304 Answers
SOURCE: Menu Screen Keeps Coming up on the screen
The most commom causes are One. There ia a stuck button on the tv itself. The Menu button. The membrane switch or the TACT switch is bad and needs to be replaced. The Main bd can also be bad.
Posted on Jul 17, 2009
SOURCE: Panasonic remote and volume/channel buttons do not work
My son put a penny in the SD card slot of my Pansonic flat screen tv. I finally got the penny out but now the volume and tv controls do not work. I can change the channels through my cable box but that is it. The volume does not work on my cable remote or the flatscreen. What do you suggest I do to fix this problem?? Thanks, Josh
Posted on Aug 23, 2009
  • 3 Answers
SOURCE: 42" LG 42LC7D LCD TV stuck in demo mode?
Did you have any luck? My LG is stuck in demo mode too. Menu button doesn't work, and keylock was on as default so I can't use the buttons on the TV itself.
Posted on Nov 30, 2009
Volume keeps going down to zero
Emerson volume keeps going down Questions & Answers ...
www.fixya.com > Forum > Tags > volume keeps going down
Emerson volume keeps going down related problems. Ask your Emerson ... myEmerson TV. It turned itself down to zero and stayed on the screen and wouldn.
Emerson Flat Screen TV volume trouble? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Aug 10, 2011 - My Emerson 32 inch does similar things, volume just goes to 0-100 and stays there. ... Why is the volume on my Emerson flat screen TV not working and how could i fix it? Whats wrong with my Emerson Flat screen tv? Why is the volume on my Emerson flat screen TV not working ...
Jul 13, 2013
My son has an Emerson tv it keeps turning down by itself. Anyone ...
Aug 24, 2006
More results from answers.yahoo.com
Emerson TV problem ' Techlore
Dec 15, 2015 | Emerson Televison & Video
I have a Curtis LCD2425A flat screen tv it powers on fine with picture and sound. After about 20 minutes the screen goes black but the sound works fine. If you turn the set off and then back on the Curtis...
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Jan 11, 2015 | Curtis LCD2425A TV
I have a klu by Curtis LT -1041-c screen went black can't get it to come back on.help tablet.
1. Make sure tablet is off.
2. Press and hold the "Volume Down" key and 'Power' key
3. When "Klu by Curtis" splash screen shows release the power key
4. A laying down android with cover open and a red triangle with an exclamation point will appear.
5. Rock the 'Volume Down' and 'Volume Up' and press the 'Power' keys to dislplay the BIOS screen.
6. Use the 'Volume Up/Down' keys to navigate choices (wipe data/factory reset) and the 'Power' key to select the choice.
7. The following screen will ask you to confirm your choice and warn you that this cannot be undone. Repeate step 6 to select your choice.
8. When wiping all data is complete, select 'reboot system now' to restart tablet.
Done!
Oct 07, 2014 | Tablets & eReaders
Unlock dot pattern lock android
Normal way for Android is to power down and then hold the power button and the volume Up button.
Way 2 is to hold power, vol up and vol down.
You have to hold until the recovery console appears, so about 20 seconds.
Only a few have a reset button inside a hole.
However, yours is different to all the rest :>)
Just completed this procedure and repeated to confirm: Klu by Curtis 7035-j
2. Press and hold the "Volume Down" key and `Power` key
3. When "Klu by Curtis" splash screen shows release the power key 4. A laying down android with cover open and a red triangle with an exclamation point will appear.
5. Rock the `Volume Down` and `Volume Up` and press the `Power` keys to dislplay the BIOS screen.
6. Use the `Volume Up/Down` keys to navigate choices (wipe data/factory reset) and the `Power` key to select the choice.
8. When wiping all data is complete, select `reboot system now` to restart tablet. Done!
Read more: How to perform a factory reset on a Curtis Klu LT7035-J tablet? - How to perform a factory reset on a curtis klu lt7035 j tablet :: Ask Me Fast at http://www.askmefast.com/How_to_perform_a_factory_reset_on_a_Curtis_Klu_LT7035J_tablet-qna6954204.html#q6015781
Curtis Klu 7 inch Touch Screen Google Search
Apr 23, 2017 | Curtis Klu 7-inch Touch Screen Mobile...
Volume keeps going down on samsung t260hd
The digital main board has the fault. This is not a user repairable one. Contact any technician.
Dec 05, 2012 | Televison & Video
Curtis Alpha3GT coffee volume is very erratic
Reprogram control panel. or clean fill level sensor with vinegar.
Nov 12, 2012 | Curtis ALPHA3GT Automatic Coffee Brewer
Menu Trouble
perhaps the volume down button on the TV is stuck. It could be either physically stuck, or the electronic logic could be messed up. Just to rule out a problem with the remote, take the batteries out of it and then adjust the volume at the TV and see what happens.
Sep 07, 2008 | Samsung LN-S4051D 40 in. LCD Television
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
