Question about Logitech Rechargeable Speaker S315i (984000083) Speaker System
How can I get a 3.5 mm jack for my Logitech S715i
Where do i get a 3.5 mm jack
2 Suggested Answers
gopakumarg43
  • 75178 Answers
SOURCE: need replacement remote for logitech s715i speaker
There is no replacement remote control for this device.
Posted on Aug 14, 2012
Can I connect a flash drive to logitech s715i?
The inputs are the Apple port (on the top) for iPod or iPhones, and the Auxiliary input for other digital music devices. You will need a 3.5mm headphone cable. The auxiliary input is located located just above the power connector on the back.
If you have a musical device that uses flash memory, then Yes you can. If however if you are reffering to a USB type of flash memory, there is no port for that.
May 18, 2014 | Logitech Audio Players & Recorders
Cnanot get a 3.5 headset jacl to fit
3.5 mm jack is for 3.5 mm jack.
Please check first if it is 3.5 mm. More or less will not fit.
Dec 09, 2013 | Computers & Internet
Can you connect logitechz320 speakers to a tv and how
You can connect the speakers up to the headphone jack, if the tv has one. If not, you may be able to use a Y adapter from the tv's composite audio outputs (again, if it has them). The Y will be red and white connectors on one end and a 3.5 mm jack (female) on the other.
Sep 15, 2013 | Logitech Z320 Speaker System
Need replacement remote for logitech s715i speaker
Aug 13, 2012 | Logitech Televison & Video
My iphone4 will no longer play music in my s715i. I have 2 gigaware boxes it will still play in just not the logitech. Says not supported. Played great for first six months, I know it is an iphone...
Hi harkirj,
There's an ongoing compatibility issue with Logitech s715i and iphone/ipod. If you're using iphone 4 with iOS 4.3 you will be encountering no sound or unit won't play at all. It only works for iOS 4.2. You can use a 3.5 mm jack, connect it to the top of the iphone to the back of the player and it will work. However, you will lose all functionality of the remote, battery etc.
Hope it helps.
Thank you for using FixYa.
Jul 10, 2011 | Logitech Rechargeable Speaker S315i...
93 accord timing belt installation
  • Car jack
  • Jack stands
  • Torque wrench
  • Chain wrench
  • 3/8 inch drive ratchet
  • 1/2 inch drive ratchet
  • 10 mm wrench
  • 12 mm wrench
  • 10 mm socket (3/8 inch)
  • 14 mm socket (3/8 inch)
  • 17 mm socket (1/2 inch)
  • 19 mm socket (1/2 inch)
  • Timing belt
  • Balancer belt
  • Bottle of Liquid Paper
  • Disconnect the negative battery terminal. Using a ½-inch-drive ratchet and the 19 mm socket, turn the center bolt on the crankshaft so that number-one cylinder piston is at top dead center (TDC). You will know you ware at TDC when the mark on the crank is in alignment with the arrow on the timing cover.
  • Disconnect the cruise control connector and remove the cruise control actuator. Loosen the upper mounting bolt with the 14 mm socket. Use a 12 mm socket to loosen the lower nut then use a 10 mm socket to loosen the adjuster from the power steering pump and remove the belt.
  • Loosen the upper air conditioner mounting bolt using the 14 mm socket. Use the 12 mm socket to loosen the lower nut and adjusting bolt on the alternator and remove the alternator/AC belt. Remove the valve cover using a 10 mm socket.
  • Place the jack behind the left front wheel where the arrow is located indicating the jack location, and raise the vehicle. Put the jack stand under the subframe behind the jack, then lower the jack. Remove the left front wheel for easy access to the crank pulley. Using a block of wood atop the jack, place the jack under the oil pan and lift with slight pressure to hold the engine in place. Remove the side engine mount using a 17 mm deep socket.
  • Take off the dipstick, pipe tube and upper timing cover using a 10 mm socket.
    Then remove the timing belt adjuster rubber seal without loosening the adjuster nut. Take off the crankshaft pulley bolt. Use the chain wrench to hold the the crankshaft pulley while turning the crankshaft pulley bolt with a 19 mm socket. Use the 10 mm wrench and 10 mm socket to remove the bolts on the lower cover. Remove the lower cover and mark the location of the cam, crank and balancer shaft with Liquid Paper. Remove the balancer shaft belt and timing belt. Install the timing belt and the balancer shaft belt in the reverse order of removing them. During Installation of the crank pulley, coat the threads of the crank pulley bolt with engine oil and tighten it to 159 foot-pounds. Finally, adjust the tension of the power steering and alternator belts as well.
    Feb 03, 2011 | 1993 Honda Accord
    How do i connect my logic speakers x230 to my pc with windows xp
    Connect 3.5 mm Jack to the Line out port & get connected your speakers to PC.
    Thanks.
    Happy to help you.
    Apr 24, 2010 | Logitech X-230 Computer Speakers
    Logitech speakers :(
    Hi and welcome to FixYa,
    Initially, I feel uncomfortable cutting the 3 plugs, splicing them together and soldering to just one plug. What I have in mind is to use 3 barrel jacks (use stereo, the image is for a mono), splice them together and connect a single 3.5 mm plug, homemade splitter.
    Pls post back result(s). Good luck and Thank you for using FixYa.
    Jan 16, 2009 | Logitech X-530 Computer Speakers
    Headphones
    Hi Meanmama
    Is there still enough cable left from the headphones to the chewed end for comfortable use? If not you might have to replace the whole cable length.
    If not, you can just fit a stereo mini jack (3.5 mm diameter) on the chewed end.
    For this you will need a soldering iron and some basic soldering skills.
    Are you able to solder a plug onto a lead?
    Sep 25, 2007 | Logitech FreePulse Wireless Consumer...
    Logitech Rechargeable Speaker S315i (984000083) Speaker System Logo
    Top Logitech Audio Players & Recorders Experts
    Michial Gueffroy
    Jerry Umali
    Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
