Question about Canon PowerShot A410 Digital Camera
When i put in a compact flash card in my canon powerpro shot 1 camera i receive a memory card error
  • 8 Answers
SOURCE: canon power shot sx 100 reads card locked
SD Memory cards have a tiny switch on the edge that marks the memory card as read only and prevents any writes. If you get the message "Card locked!" when you turn the camera on then turn the camera off, eject the SD card. With the card facing you (metal contacts facing away) the switch is on the left hand edge, slide towards the top of the card to make the card read/write again.
Posted on Dec 19, 2008
randy320sgi
  • 121 Answers
SOURCE: New San Disk memory card not working
vebhat,
Make sure the little slide on the SD card is in the right position, and if it's a high capacity SD it might not be compatible with your camera...
randy320sgi
Posted on Jan 09, 2009
  • 3 Answers
SOURCE: memory card error after inserting SDHC card on powershot A620
the a 620 only goes up to 2 gb no higher
Posted on Jan 28, 2009
old marine
  • 1992 Answers
SOURCE: Canon Power Shot A400 will only work with original Canon SD card
Make sure you are using an SD card and not an SDHC card. The SDHC protocol is newer than your camera, and your camera does not support it. SD cards have capacities up to 2 GB. Your camera should work properly with any SD or MMC card.
Posted on Apr 22, 2009
John Conner
  • 30 Answers
SOURCE: Memory card error message
Cards are coming in different formats and it might be possible that you brought a card which is not suitable or functional with your camera. The other reason could be that we are having options to lock our memory card in digital camera and you might have taken out your earlier card without unlocking it. The system might be broken from inside and this could be a reason that you are still getting a message that memory card is locked. It seems possible based on problem you are sharing.
Posted on May 29, 2010
Err CF I have a Canon Rebel XT, how do i fix this error and what does it mean?
CF stands for compact flash which means you have an error with your memory card. Try removing and replacing your compact flash memory card. If that doesn't work you may need to format your memory card or replace it.
Jul 28, 2011 | Canon Rebel XT / EOS 350D Digital Camera
THE CAMERA BRINGING A NOTICE ON A SCREEN ERROR CF.WHAT IS POSSIBLE THE PROBLEM.
Digital Camera: How to Fix Compact Flash Memory Cards ErrorIt is not very typical for compact flash memory cards to give you an error. If you do receive an error, it most likely means that a pin within your CF card slot is bent, or your CF card has become corrupted. Unfortunately, if your CF card has become corrupted, you will need to reformat the memory card, which means that you may lose any pictures that were located on the card.
Fixing Your Flash Memory Card
You will want to remove your CF card and the batteries. Take a look inside the CF card slot to see if there is a bent pin. If you find a bent pin, you can correct this problem using a very small and skinny flat screwdriver. Moving very slowly, use the screwdriver to bend the pin back into place. You do not want to use enough force to make the pin back in one shot.
The pin does not have to be perfectly straight, but get it as close to straight as possible. Insert your CF card back into the slow very slowly. You should see the in align itself with the card. You can turn your digital camera on to verify that the compact flash memory card is now working.
Mar 11, 2011 | Cameras
Canon A10 - "CF card error" with new 4GB card
You need to format new cards in the camera before using.
Apr 05, 2010 | Canon PowerShot A10 Digital Camera
What size in inches is a A85 memory card. I put
The A85 uses a Type 1 Compact Flash (CF) card. If you're trying to put an SD card into the slot, it won't work. Using a strong light, check carefully in the card slot that you haven't bent any pins before inserting a CF card.
Aug 26, 2009 | Canon PowerShot A85 Digital Camera
Unable to save shots on memory card.
You can download the Camera User Guide here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=320&modelid=9828
As for the memory card, have you tried another one? This camera should be able to hand Compact Flash (CF) cards up to 2GB in size.
Jun 23, 2009 | Canon Cameras
Internal memory??
Highly recommend that you consider using a card reader to download you pictures. You insert the camera's memory card into the reader, and then insert the reader into a USB port on your computer. The card then shows up as a hard drive so that you can simply copy/paste or drag your picture files onto your computer. Card readers are much more faster in downloading pics, do not require the use of your camera's batteries, and provide much more reliable downloading of the pictures (fewer errors). They're also VERY inexpensive these days. Here are some examples of CF card readers from Amazon:
http://www.amazon.com/s/qid=1223745821/ref=sr_st?keywords=cf+compact+flash+card+reader&rs=172282&page=1&rh=n%3A172282%2Ck%3Acf+compact+flash+card+reader&sort=price
Also, if the card has somehow become corrupted, take no more pics until you've recovered the photos. Take the card out of the camera. Here's some freeware photo recovery software that should be what you're looking for:
http://camerarepair.blogspot.com/2007/12/recovering-those-accidentally-lost.html
You will also need to use a card reader with this software. Finally AFTER you've recovered your photos, recommend formatting the card IN YOUR CAMERA to prevent this from happening again. Note that formatting will totally erase your card. Turn on the camera, press the menu button, select the tools menu. Go down to the selection that states your CF card's memory capacity and select it. Then follow the formatting prompts.
Oct 08, 2008 | Canon PowerShot A75 Digital Camera
Compact Flash Problems
Dynamite,
have you tried to reformat the CF card?  If you deleted the image through your computer and not with the camera, the computer may have removed more than what was needed...
SteveK
Oct 27, 2007 | SanDisk ULTRA II 4GB Compact Flash Card...
Memory card not reading in canon a75
So as not to spoil your vacation, go buy yourself a new compact flash card locally. They should sell them anywhere electronics are sold, including WalMart, etc. See if you can get this new card to work in your camera. If so, then you can work on trying to get your current CF to work, by trying to format it in the camera. If you can't get a new CF to work in the camera, then you likely damaged either the pins in the CF socket in the camera, or some switch that is pushed when the card is inserted (to tell the camera there is a card in it). It is unlikely you will be able to have this fixed during your vacation, unfortunately.
Mar 05, 2007 | Canon PowerShot A75 Digital Camera
Canon PowerShot A410 Digital Camera Logo
22 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
