Question about Intermatic Hardware & Accessories
15312 I have a 15312 timer that is controlling my porch light. When I first installed it prior to day light saving time, it worked perfectly. But when DST came it needed a correction by one hour. Now the problem. Under programming ON/OFF Events on the instruction sheet I followed word for word to reprogram it. I have it set to go on @ 8:30pm & off@ 11:30pm. It goes on OK but when I check it in the morning the porch light is still on. I reprogrammed it 3 different times and it always does the same. WHAT AM I DOING WRONG .? Do I have to reprogram from initial setup ? I'm at popsie252000@yahoo.com my name is Don
SOURCE: I have woods lighting timer
See Woods timers:
http://waterheatertimer.org/Woods-timers-and-manuals.html
Are you sure about that model number?
59200 is a plug-in dial-type timer.
Timer does not have a light.
The dial is rotated to set current time.
And segments located around dial are pulled up and pushed down to set timer function.
http://waterheatertimer.org/pdf/Woods-59200.pdf
Add a comment with description of your so I can locate manual and help.
Posted on Nov 22, 2010
SOURCE: Utilitech model 0141224 wall switch
As luck would have it I'm 60, and learned how to program your 0141224 wall switch timer.
You can see instructions with big print and pictures on following page.
Press CTRL key on keyboard and use scroll wheel on mouse to make web print bigger.
http://waterheatertimer.org/Program-wire-Utilitec-LW60418.html
Add a comment any time.
You have wired your timer correctly and the lights turn on when you push on-off button.
If lights do not turn on, we need to review the wiring.
Your timer looks like photo below.
I'm going to parrot back the manual with some extra words.
To start, press the reset button and clear any programming
Programing overview:
Each program has ON time ... and OFF time
So you set program1 ON and then set program1 OFF
When you set program1 ON, you choose the Day, hour and minute you want program1 to turn ON.
And then you set program1 OFF, and choose Day, hour and minute for program1 to turn OFF.
Your ON-OFF times for program1 should be on same days.
For example program1 ON for all-days-of-the-week, but program1 OFF is for TU Tuesday, then timer will not work.
IN this case, program1 OFF should also be set for all-days-of-the-week.
Let's start.
Setting the clock:
Press and hold CLOCK button
Keep holding CLOCK button and press DAY button until display shows current day (MO TU WE TH FR SA SU)
Press Hour button until current hour with am pm displays
Press MIN button until current minute displays.
Release clock button and current day and time show on display
At no other part of instructions do you press and hold one button while pressing other button.
Setting programs:
Press PROG button until "1" and 'ON' show on display
This is program1 ON
Press DAY button to choose which days for program1 ON.
You can choose: all-days-of-the-week and MO TU WE TH FR SA SU show on display
Choose individual days and MO or TU etc shows in display
Choose weekdays MO TU WED TH FR
Weekends SA SU show in display
Next step
Press HOUR button to select hour for program1 ON
Press MIN to select minute for program1 ON
Now program1 ON is ready, next, you will set program1 OFF
Press PROG button until "1" and 'OFF' shows on display
This is program1 OFF
Press DAY button to choose which days for program1 OFF.
( Remember, you want same days for ON and OFF)
Press HOUR button to select hour for program1 OFF
Press MIN to select minute for program1 OFF
Now program1 ON and OFF are ready, next, you will set program2 ON by repeating same steps above.
You can set up to 7 programs.
If you don't want to set program2, or any more programs, that's fine.
To exit programming and save your program, press CLOCK.
Now current time shows in display.
Final step: set MODE
Press MODE button until AUTO shows in display. You want AUTO for programming to operate lights. That's it, timer is ready.
If you're going on vacation, press MODE button until RDM shows in display, and then timer turns lights on-off at random
Copy and save these instructions to your computer so you have them next year.
Posted on Dec 05, 2010
SOURCE: GE 15 amp 7-Day In-Wall Programmable Digital Timer
Your timer is bad. It comes with 1 year limited warranty.
Buy one at Home Depot and then return defective one.
Make note of wiring before removing bad timer, so re-wire is easy.
GE 15086 is White 7-day digital, non-astronomic timer made by Tork, and sold on-line and at Home Depot.
On the shelf, 15086 timer looks identical to 15071 >> same package >>> difference is 15071 offers daylight savings time and random option, and costs a bit more.
These in-wall timers usually last a few years, and some can last for several years.
Especially when timer operates from electric circuit and not battery.
15086 operates from electric circuit.
15086 manual on-line:
http://waterheatertimer.org/pdf/GE-15086-Manual.pdf
SOURCE: GE smart digital timer was
It sounds like wiring is wrong.
If you have GE Tork Intermatic UPM Woods Brinks Hagar Pass-n-Seymour Stanley Westek in-wall timer, with red, black, white and green wires, then you probably put red and white wires together.
See instructions along with image at following link:
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
Heres how to wire timer
1) Timer-green-wire connects to bare ground wire.
2) Switch has 2 wires. Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
3) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires.
4) If electric box does not have white wires described above, then connect timer-white to bare ground, along with timer-green wire.
5) Turn on electricity, and push ON-OFF button > with GE timer, door is push-button switch. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
Posted on Dec 11, 2010
At daylight savings time the timer jumped 2 hours forward. How to I set it back an hour without going thru whole set up process?
Expert cannot see the timer you are talking about without model number or photograph
-With modern timers, usually the product manual shows how to change DST with push of button or by pushing two buttons simultaneously.
-If the DST was not set correctly when first programmed, then probably you have to reprogram.
-Normally, with modern timers, the on-off programs stay in memory if you re-enter current time of day and set DST.
-Most modern timers have battery back-up or capacitor back-up
-Only if you press reset button are the memories wiped clear
http://waterheatertimer.org/How-to-set-timers.html
http://waterheatertimer.org/How-to-troubleshoot-timers.html
Gene
Water Heater Timers Save Money
Mar 18, 2015 | Hardware & Accessories
Troubleshoot ge model 15086
GE 15086 will not work for 3-way.
There are several timers that do... keep in mind that 3-way timers replace 1 or the other switch, but not both... and the remianing switch must be rewired slightly depending on which 3-way switch is replaced. Sounds confusing, but copy following links for exact wiring diagrams for the GE 15312 timer, and Intermatic ST01c 3-way timers: Easiest to wire is ST01C since it is battery-powered.
Another thing to remember, is that when the remaining switch is flipped in a 3-way timer circuit, it just reverses the timer programming, so dawn-dusk would become dusk-dawn etc.
These timers offer astronomic dawn-dusk function or 7-day programming.
http://waterheatertimer.org/How-to-wire-GE-15312-timer.html
http://waterheatertimer.org/ST01C-program.html#3-way
Gene
hh
Aug 17, 2013 | Hardware & Accessories
The timer has 3 wires, blue, black and green and the wires from the outlet after I removed the original switch are 2 black and one red. How should I connect the new timer? The timer is a GE 15313.
There are 2 different timers: 15313 and 15312
15313 has Black Blue and Green wires
15312 has Black Red White and Green wires
1) Your Switch has 3 wires: sounds like a 3-way switch at each end of hallway.
The 15313 timer cannot be used to replace 3-way switch
http://waterheatertimer.org/GE-timers-and-manuals.html#15312
2) Buy GE 15312 timer for 3-way switching.
http://waterheatertimer.org/How-to-wire-GE-15312-timer.html#3-way
3) GE 15313 is for single-pole only, and rated for incandescent lights only and will not work for CFL, LED bulbs, or other inductive loads.
4) GE 15313 timer will work for single-pole or 3-way, and work with any type of bulb, or load up to 100 feet away.
Dec 20, 2012 | Hardware & Accessories
Unable to Program Utilitec 0192773 Timer
Let's figure it out together. I have one of these timers for testing, and can hook it up if needed. Add a comment as needed.
PLEASE read following material, so we are both saying the same thing.
There are two different options for programming.
7-day programming, and dawn-dusk programming.
You choose one or the other
This might be the point of confusion.
Copy following link for larger print instructions.
DST is daylight savings time, and you can choose to have automatic DST adjustment twice per calendar year, or choose not to have DST
Be sure to RESET timer before programming. This will clear any programming glitches.
Make sure that each ON time has an OFF time.
So Program 1 ON is set for day(s), hour, minute
The Program 1 OFF is set for same day(s), hour, minute.
Make sure there are no conflicts between day(s).
If selected time is 12:00, then use 11:59 to avoid am-pm conflicts.
Oct 08, 2012 | Hardware & Accessories
How to wire GE timer 15070
Copy following link for timer wiring.
Your box does not have neutral wire
The GE 15070 7-day timer wires same as GE 15312 7-day sunsmart timer
Dec 05, 2011 | General Electric GE 56941 24-Hour Outdoor...
SunSmart 15312 - timer has power and will turn lights on/off manually but will not turn on/off automatically after setting program.
Sun Smart is new GE timer.
There is no repair for defective timer, except buy another at Home Depot and return defect in new package.
When I bought 15312 timer for testing, I found many packages at Home Depot were taped together as if people returned the timer. The large aluminum fin shows that timer is expected to get warm.
When testing the timer, the door stuck, and the timer seemed cheaply made. Intermatic brand timers are more robust at this time.
The instruction manual is not clearly written as could be, and timer requires a lot of button pushes for each setting.
Because the instruction manual is complex, requiring multiple button pushes for each setting, I suggest writing out the steps to make sure nothing is skipped over.
If lights turn on-off with override, then timer should be wired correctly.
Be sure to reset timer before programming.
Press setup button twice to begin programming.
Check programming for conflicts and overlaps that will cause timer not to function as expected.
For example selecting days of week. If program1 ON says turn on at 7:00 pm all days of week, and program1 OFF says off at 9:00 pm Tuesday.
Another point of confusion is Dawn-Dusk-Time. If you want timer to turn ON at 7:00, then select Time.
Sep 21, 2011 | Intermatic Inc. ST01C Digital In-Wall...
Does timer 15071 automatically adjust for changing daylight length in addition to adjusting for daylight savings time?
GE 15071 sold at Home Depot and on-line has feature that adjusts for daylight savings time.
GE 15086 does not offer automatic adjustment for DST
http://waterheatertimer.org/GE-timers-and-manuals.html#15071
Daylight savings time (DST) is not same as dawn-to-dusk astronomical timer.
GE 15071 and 15086 single-pole timers do not have dawn to dusk astronomical feature.
For single-pole dusk-dawn astronomical with DST, Lowes sells Utilitec-0192773
For 3-way switching, 7-day DST -or- dawn-dusk astronomical:
http://waterheatertimer.org/Aube-timers.html
Apr 17, 2011 | GE Hardware & Accessories
We have 2 DZS400 digital tork timers. unfortumately when DST days were changed we have not been able to use the automated dst transition and must manually change the clocks twice each year. is there a way...
DZS400 product descriptor shows DST, and many other programming options:
1) This might help or not:
You can modify DST start & end times > Press MODE until dSt shows > Press MONTH, DATE, DAY to modify start times, and then press ENTER. (or press DEL and ENTER to delete) > Press MONTH, DAY, DATE to modify end times, and the press ENTER > press MODE to return to AUTO.
2) According to DZS400 product descriptor "The controller has 365 day holiday capabilities with 24 single dates" ... if above solution doesn't work, the 24 single dates might provide enough days to fill in programming gaps in the DST. Your manual should have programming steps.
Sep 18, 2010 | TORK Hardware & Accessories
Hardware & Accessories Logo
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
