Question about Tunturi Exercise & Fitness
Where can I buy lubricant for Tunturi treadmill J9F
maxtreadmill
  • 832 Answers
SOURCE: IHAVE A TUNTURI 800 TREADMILL THAT IS ABOUT 18
Call Accell Fitness of North America they are a Tunturi distributor: Call 1-800-388-6887 they should be able to tell whether parts are available for your unit
Posted on Mar 02, 2010
maxtreadmill
  • 832 Answers
SOURCE: my tunturi treadmill 661f is showing E1 on the
E1 error code : Unplug unit remove motor shroud and check the distance between the speed sensor and the flywheel and ensure that the speed sensor is properly attached to the motor frame. Check also speed sensor connections.
Unplug the electrical cord from the wall outlet and from the treadmill, wait 1 minute and turn the power switch on again. If treadmill recovers to normal operation, you may continue to use the treadmill.
Check the motor brushes either they worn or not sitting properly
Posted on May 17, 2010
Testimonial: "very helpful thanks saved me lots of money "
  • 15 Answers
SOURCE: Where can I purchase a teflon spray lubricant for treadmill?
Tunturi.com or accellfitnessna.com should have the lubricant you need. Order it online and they should be able to ship it directly to your house. I service tunturi treadmills, although I haven't come across a teflon lubricated machine, it is very important with these machines you stick with the manufacturer specified lubricants.
Posted on May 27, 2010
  • 3 Answers
SOURCE: how to lubricate roger black gold treadmill and with what
http://rogerblackmanuals.co.uk
Posted on Apr 01, 2011
stevebuck453
  • 4 Answers
SOURCE: I have a Tunturi j770 treadmill with error code E1...
Buckmanservices.com solved the E1 code issue only $30 fixed it from online told me what to do
Posted on Jun 13, 2012
Supplier for a Tunturi T85 treadmill circuit board?
Here is a parts list for the Tunturi T85 with many available parts. I don't see a circuit board but you may be able to contact the company to see if it has a different name or if they can get it added.
Sep 14, 2012 | Tunturi T85 Treadmill
Tunturi t80 treadmill gives check lubricant message after multiple times of lubricating the belt
RESET the machine. Use your owner manual read section troubleshooting and proceed according.
God bless you
Aug 02, 2012 | Tunturi T80 Treadmill
Where can I obtain the belt lubricant for my Tunturi T20 treadmill?
go to www.fitnessrepairparts.com or www.unitedassemblers.com
God bless you
Jul 14, 2012 | Tunturi T20 Folding Programmable Treadmill
What lubricant can i use for my pro form tredmill model 380 E?
You can use silicone lubricants.
But if you want buy lubricants:
go to www. treadmillpartszone.com
or www. gympart.com
sincerely.
E.CUADRA
MANAGUA,NICARAGUA. C.A
Nov 23, 2011 | Tunturi T20 Folding Programmable Treadmill
My tanturi treadmill model j620p does not work. thou it has a power n the panel indicate a number 51 even i press the reset button it does not reset and all the key button does not function. what sould i...
Dear Sir:
I will try to help you:
If any error code appears on the display or there are other
malfunctions, proceed as follows:
1. Turn off the power switch for a minute and then
turn it on again.
2. Insure the tether key is properly inserted.
3. Insure the power cord is properly plugged.
4. Insure the treadmill is properly lubricated (see 4.3.
LUBRICATING THE RUNNING DECK).
5. If the error code does not disappear after the
above mentioned maintenance actions, please
contact your local TUNTURI dealer. Always give
the error code and serial number (see the sticker
at the back of the frame, below the left-hand side
rail).
4.3. LUBRICATING
THE RUNNING DECK
Lubrication is the most important service activity for the
treadmill. This is absolutely essential, if the friction of the
running deck increases noticeably or the motor begins to
heat up. Lubrication intervals must under no circumstances
exceed 200 usage kilometres; we recommend relubrication
once a month. During the first 200 km of use, the running
deck must be lubricated at intervals of 50 km. Insufficient
lubrication will cause the belt, running deck and motor to
wear out and break.
NOTE! Before you start to use your treadmill, it must be
carefully lubricated per the lubrication instructions
below! NOTE! If the treadmill is not used for at least
three weeks, it must be carefully lubricated per the
lubrication instructions below!
The need for relubrication depends to a great extent on the
running styles and weight of the user: heavy user weight and
slow speed put particular strain on the device and therefore
demand greater lubrication. Use only the teflon enclosed to
lubricate the treadmill. Contact your local TUNTURI dealer
for further supplies of teflon.
NOTE! The device must under no circumstances be
lubricated with silicone!
Please apply teflon by using the pressurised can provided
with these instructions.
instructions on the teflon bottle carefully.
1. Let the treadmill run at a slow speed and spray
teflon into the lubrication pipe underneath the
treadmill. The pipe is marked with a decal.
2. When teflon is applied for the first time, the
spraying time with the pressurised can should be
approximately 20 seconds. Later, a spraying time of
10 seconds is sufficient.
3. Teflon drops through the holes of the lubrication
pipe to the center of the running belt; the treadmill
is instantly ready for use.
Please ensure after each time that you relubricate your
treadmill that a strip of about 8" wide on the underside of the
running belt becomes moist with teflon oil along its whole
length. If necessary,
If you need further assistance, please reach me, sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Oct 23, 2011 | Exercise & Fitness
We found leaking oil underneath one side of the lifting arms on our Tuntuiri walking machine. We thought it was coming out of the lifting arm shockies or arm somewhere. What can we do? Sophia
hi,
Its normal. Its the silicon lubricant used to lubricate the treadmill belt. If there is excessive lubricant it will spill out. Don't worry about it. It will become normal within days. just wipe off the excessive lubricant coming out.Its coming out from the running base under the running belt.
ok
Jul 20, 2011 | Tunturi T20 Folding Programmable Treadmill
May 27, 2010 | Tunturi T20 Folding Programmable Treadmill
Looking to buy a good quality treadmill for home. Is the Tunturi T30 worth considering? I will mainly be power walking. The Lifefitness are very expensive...any other brands you recommend? I i live in...
Tunturi unit have been always a reliable unit and they do not have very many problems. I like and sell the Sports Art products for five years and they are reliable and sturdy units, at one time they were manufacturing for Tunturi and other highly visible companies in their 30 plus years in the industry.The only worry is, do you have a reliable service company that will take care of you if whatever product you choose to purchase. I know as a servicer I rely on my vendors to give me great service so I intern give great service to my customers.
May 10, 2010 | Tunturi T30 Treadmill
Exercise & Fitness Logo
14 people viewed this question
Top Tunturi Exercise & Fitness Experts
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a Tunturi Exercise and Fitnes Expert? Answer questions, earn points and help others
