Question about Samsung Computers & Internet
Lap top will only show boot menu ?
Samsung lap top screen is showing a dos boot menu apps menu It says'1. SATA CD: TSSTcorp CDDVDW SN-208BB And it switches itself on and off and stays on this screen
MDoe
  • 156 Answers
SOURCE: lap top problem
Hi
If the AC power light is blinking, try the following steps:
1 Cut off power to the computer by disconnecting the AC adaptor and removing the battery. The error condition will be interrupted, and the AC power light will stop flashing.
2 Put the battery back into the computer. Do not connect the AC adaptor. Try turning the computer on again. If the computer starts normally, the AC adaptor may be
defective and will need to be replaced. If the AC power light starts flashing, remove the battery, and continue with the steps below.
3 Connect the AC adaptor to the computer. Leave the battery out of the computer. Try turning the computer on again. If the computer starts normally, the battery may need charging, may be depleted, or may be defective. Turn the computer on, insert the battery, and then leave the computer running for several hours, which will deliver a slow, steady “trickle-charge” to the battery. Once the battery has been trickle-charged, it may begin working correctly again. If the trickle-charging does not prove effective, consider replacing the battery with a new one.
4 Connect the AC adaptor to a different power outlet, preferably in a different room. If the computer starts normally, there may be a problem with the AC outlet itself, or the voltage level available from it.
5 Verify that the AC adaptor is the correct unit for your computer model. The computer may not be able to start from an AC adaptor that is rated for less current (amperage) than the computer requires, even if the rated voltage is correct, and the plug fits correctly in the DC-IN socket. The labels on the bottom of the computer and the AC adaptor show the specifications for voltage ("V") and current ("A") for each device. The voltage level must match exactly. The amperage rating of the AC adaptor must be equal to or greater than that required by the computer
Regards
Mike
Posted on Mar 27, 2008
billspeer
  • 180 Answers
SOURCE: the lap top computer screen is loose
Those screens tend to lose their tightness as time goes on from all the opening and closing. Regrettably, there isn't much to be done with them except replacement of the part. You can jury rig it but that's about it. I,too, had a zv5000 and experienced the same thing.
Please don't hold my bad news against me when you rate my answer! ;-)
Posted on Jan 11, 2009
billspeer
  • 180 Answers
Yes, the bushings tend to wear out over tme and use. Options are either replacement of the lid ($$) or laptop ($$$). Which course you decide on is up to you.
Posted on Jan 12, 2009
nassimjd
  • 104 Answers
SOURCE: my lap top doesnt show i have a cd rom drive or it
right click on my computer icon and choose manage. In Computer managemen, if you see a CD rom drive, the it is only a matter of changing a drive letter ,,,,, if you don't see in computer management, then the PC has not recognized it from boot.
Posted on Mar 30, 2009
benwabnick
  • 2404 Answers
SOURCE: samsung v 25 dvd room not working
Hi Alfonso, you can put any dvd-rw into your laptop, all you have to is change out the screw holder on the back of the drive and also change out the face plate. This will allow you to make sure that the drive fits properly and that you can screw the drive into place. Also make sure the shape of the drive matches up as well.
Posted on Jun 06, 2009
Samsung NP355E5 not boot from HDD.
You may find best results finding Samsung support for this at...
http://www.samsung.com/us/computer/pcs/NP355E5C-A01US-specs
If this, my reply helps, you may show that.
A
Jun 28, 2017 | Samsung Computers & Internet
Why do l have horizoncal the bottom of my tv screen
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 22, 2014 | Samsung samsang slim dvd-rw sn-208bb 8x...
Cddvdw sn 208bb does not burn stuff on CD-R
Faulty burner. The laser can read discs I presume but cannot develop enough power to burn a disc.
Mar 17, 2014 | Computers & Internet
I have this message " SATA CD :: TSSTcorp CDDVDW TS-U633J" What does it mean?
SATA : Serial ATA, the type of interface for the Drive as opposed to IDE (the older type.).
TSSTCorp is a joint venture Toshiba Samsung for Optical drives
CDDVD R-W CD and DVD Read Write.
TS-U633J is the model number. That is the reference you use if you are looking for drivers.
Why did this information get you worried?
Oct 27, 2013 | Samsung NC10-14GW Notebook
Get into boot menu samsung laptop
Its telling u what ur CD DVD righter is,what type it is.
Oct 27, 2013 | Computers & Internet
Unable to install XP OS to MSI lap top
Insert your installer to the lap top then try to change the boot up priority by entering the bios. Try to press del key while your lap top boot. If these deosn't wok try F1 or F2 thesame process. If you have enter the BIOS, look for the boot priority which includes the First Boot, 2nd Boot and 3rd boot. Change the 1st boot to CDROM and the 2nd boot to hardisk. Then save the changes by pressing F10. your PC will reboot and it will direct you to the OS installation.
Mar 29, 2010 | Computers & Internet
Computers & Internet Logo
27 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
