Question about Miller Trailblazer 302 Welder Generator 907217 907216
Service manual for trailblazer 302 - Miller Trailblazer 302 Welder Generator 907217 907216
Miller trailblazer 302 it has 110 volts but no 220 volts
Both sets of the 120? If both of those are there (all 4 outlets), then the machine is producing 220v. So get a flashlight and look into the holes on the 220 receptacle, or check the wires on the backside of the receptacle. All that 220 is, is two 120 volts out of phase.
Feb 19, 2015 | Miller Trailblazer 302 Welder Generator...
Operation manual for a miller trailblazer 302 stock number 907217
www.millerwelds.com have the serial number handy. Click on service, then owners manuals and follow the directions.
Oct 07, 2014 | Miller Trailblazer 302 Welder Generator...
What will cause my welding generator to start up at full rpm and not idle down?
Check the governor unit. Miller is a good make, shouldn't be a problem downloading a manual.
Sep 05, 2014 | Miller Trailblazer 302 Welder Generator...
I have miller 302. Outlet power working but stick weld not work
Check your machines fuses. For location of fuses look into your owner's manual.
Feb 17, 2014 | Miller Trailblazer 302 Welder Generator...
Trouble shooting miller trailblazer 302 engine powers out when air arcing
Blow cabinet clean of dust and check connections in cabinet and handle. first, Then check the wires to the step up solenoid and make sure they have sound connections and that solenoid is mounted securely. If you do much outside at night, have someone watch with the cabinet open and see where it sparks when the engine drops speed. Int he dark, even small sparks you would not see inthe daytime or the shop apper reasonably well.
Sep 24, 2012 | Miller Trailblazer 302 Welder Generator...
My 302 diesel trailblazer runs for a few minutes then shuts down and flashes HI H20 code ,the manual says its a coolant issue but even with the proper amount of coolant it still does this
You need to "burp" you're coolant system. To do this find the upper Radiator Elbow where it goes into the engine, then, use an allen head to unscrew bleeding screw (for lack of better term). place Rags under so as the spilling coolant is caught as best you can (it's basically a fill bolt style, fill radiator until coolant seeps from that hole, lock her back up, repeat testing.
- Logan P. Clayton
Miller Authorized Service Technician
Feb 08, 2012 | Diesel Miller 907218 Trailblazer 302...
I need the part number for the termial output and ground for my 302 diesel Trailblazer and a part number for the starter motor for my 400P Big Blue Diesel. Also any suggestions on spare parts I should...
Hi:
Part number for the ground output terminal is MIL 039046, list price is $24.34.
For the Big Blue need to specify what engine/model does your machine has or serial number.
Aug 07, 2011 | Miller Trailblazer 302 Welder Generator...
I have a miller trailblazer 301 G . my problem is that i turn the start switch to run and it doesnt run in high speed. this welder only has 24 hours on it.
i have the same machine, had same problem, changed broken springs on carburator and choke, problem gone. air gas ( authorized service tec. showed me how)
Jul 19, 2011 | Miller Trailblazer 302 Welder Generator...
Field wiring taps - wire 480 or 208 3 phase need schematic
Hi:
Follow the link for the trailblazer owner's manual, check section 10 for wiring schematic.
http://www.millerwelds.com/om/o4426ab_mil.pdf
If this was useful to you please vote. Thank you!
Feb 24, 2011 | Miller Trailblazer 302 Welder Generator...
My 2009 trailblazer 302 with kubota diesel engine keeps shutting down read out says lo oil. but engine oil dipstick shows full dobrodoc@starband.net
If you have owners manual I would locate the low oil safety switch and replace it. You can temporarily bypass the switch to verify that is the problem before buying new parts but I would not leave it that way. Use for diagnostic only. Thank you
Dec 02, 2010 | Miller 907068 MILLER TRAILBLAZER PRO 350D...
Miller Trailblazer 302 Welder Generator 907217 907216 Logo
185 people viewed this question
Top Miller Welding Tools Experts
Kory Ronning
hubiam
hubiam
Level 1 Expert
John Trevino
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
