Question about Miele Washing Machines
W3725 miele washer
Water coming from bottom of machine
5 Suggested Answers
  • 16 Answers
SOURCE: miele washing machine
All Miele washing machines and dishwashers need to fill in a required time. Flashing inlet (Tap icon) indicates that the machine can not fill in time. There are filters in the end of the hoses which connect to your water supply from the machine and filters in the inlet valves which you can get at by removing the hose from where it fixes onto the machine it'self. You will need some long nose pliers to grab the little tab on the small filter to get it out. Clean all filters and hoses. Still same problem then check the pressure of the water coming into the machine. There should be a good pressure coming out of the hose and will be difficult to stop the flow of water with your finger.
Posted on Feb 08, 2008
  • 3 Answers
SOURCE: miele touchtronic 1113 washer
There is a float switch in a pan under the machine. This pan is probably full and the float switch is causing the Intake & Drain fault signal. You can lean the machine over to towards the front to partially drain the pan. Put a towel down to catch the water. When you put the machine level again the fault lights should be out. The real question is where did the water come from. You can easily remove the top (4 screws, 1 on each side behind the little plastic caps and 1 on each side of the back. Torx heads) and look down inside while you start the cycle. Look for leaks.
Good Luck,
Dan
Posted on Aug 11, 2009
  • 1937 Answers
SOURCE: Water comming out the bottom of washer
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
See the section for the basket and tub assembly's
I'd pull the cabinet in order to get to the hoses going to and from the pump first.
See the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
If the hoses are fine, check the shaft from the motor to the pump and check inside the pump to make sure the inlet and outlet aren't blocked.
I'd also check the gaskets at the bottom of the tub.
If you're reasonably mechanically inclined, these are easy fixes.
If you have to get to the gaskets at the bottom of the tub, see the following for how to remove the agitators, pump, motor, transmission, spin tube and basket.
(It sounds a bit complicated but it's not really that difficult.)
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
You don't have to buy a special spanner wrench to remove the spanner nut. I've used a short 10" pipe wrench hooked over one of the tabs on the spanner nut, tap the handle with a hammer and it should loosen.
Also, don't directly hit the drive block with a hammer. Use a short piece of wood under the drive block and tap up on the wood.
As an aside, see the following Whirlpool Service Manual for top load direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Depending on the problem (hoses or gasket) it's certainly less expensive than calling in a repair person.
Posted on May 08, 2010
blueextc3221
  • 15935 Answers
SOURCE: our miele w3725 is coming up with drain default
You'll need to clean the filter and/or remove the hoses to inspect the inlet strainer & clean it out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
Miele washing machine W3725 is coming up with Technical fault F51 ?
F51: Pressure Sensor
Symptom
In the operating mode, the display indicates Technical fault.
The program is stopped, the water intake valve is closed, and the drain pump is
switched on for 120 seconds.
Cause
Electrical defect in analog pressure sensor (ADS). The values are out of range.
x
Note
The pressure sensor is integrated into the power/program electronic (ELP)
This will usually require a professional to repair.
Dec 10, 2016 | Miele Washing Machines
My miele w3725 front loader washing machine appears to be leaking drops of oil into the wash and staining the clothes. What could be the cause?
Hi dear,
Seems like your washer has bearing seal damage. It will be expensive repair. You may contact Miele to get a quote. Thanks.
Jan 01, 2016 | Miele Washing Machines
Miele W3725 washing machine appears dead. No lights on control panel. 240V AC wall socket is OK. Is there a fuse for power coming into machine? Can't seem to find one.
go to google and type in miele washing machines on one of the pages you will find a contact us tab
make a call to a service department and they will advise over the phone
May 12, 2015 | Miele Washing Machines
Miele w3725 won't start
If the Start LED keeps flashing, either the door is not closed properly, or the door switch is broken.
Mar 01, 2015 | Miele Washing Machines
What is code error F50 on my miele W3725 washing machine mean
I have today purchased a Miele 3985 machine with a know F50 Fault code appearing
Before I went to the expense of calling a Miele technician, I explored the blocked / clogged drain path
I removed the drain pipe and noticed there was a lot of 'residue' / gunk in there
I cleaned what I could, and blew through the pipe back into the machine
Then I did a cotton wash cycle at 90degrees, with a 1litre of bleach to clean the drain path
The wash looked extremely dirty during the cycle
It appears that this resolved the F50 fault code issue with my Miele 3985 Navitronic
Aug 08, 2014 | Washing Machines
Miele w2240 check drain and check inlet lights both flash
There is water at the bottom of the machine. You could tilt the machine forward until the water dumps out and then the lights will go away. The cause of the problem could be the following: 1. There is a hole in the seal. 2. A hole in one of the hoses inside the machine. 3. Too much soap (the most common), the suds come out of the door and enter into the bottom.
Hope this works for you. Please leave a feedback.
Feb 28, 2011 | Miele W2240 Front Load Washer
Miele w3725 front loader. message on screen "waterproof fault"
For our model Alemnesh's suggestions were spot-on. It's hard to believe that a machine with such a good reputation would (a) allow this fault to occur so easily and (b) not have its own manual provide explicit guidance as to how to fix it.
Oct 03, 2010 | Miele Washing Machines
Our miele w3725 is coming up with drain default
Jun 29, 2009 | Washing Machines
Miele g665
Peter,
where is the water coming out at? Are you using the proper detergent? if the machine is too full of water and a fill float valve is stuck open, water sometimes overflows.
Check to make sure the fill valve is working, then check to make sure pump is operating. (you will know when you turn the machine onto the rinse cycle.)
Mar 17, 2008 | Miele 24 in. G665 Built-in Dishwasher
Washing Machines Logo
15 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
