Question about Maytag Neptune MAH5500B Front Load Washer
Maytag neptune washing machine
The transmission is defective in this machine. Can you tell me what steps to do next in order to fix it myself?
Who told you the transmission is defective??? I have worked on my Neptune and it has a belt going from the motor to the drum - there is no transmission. I don't know the model number of my washer, but it is a Maytag Neptune from 2002; I think they all have used the same basic design without a transmission ever since they came out.
Posted on Nov 05, 2007
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
Jun 29, 2005
More results from
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
Anyone know why
If the machine has a mechanical control, the timer is stuck in a certain position. Whatever cycle it is stuck on will continue to run until the timer is advanced to the next setting. If you have an electronic board controlling things then that board is defective and needs to be replaced.
U might try unplugging unit to see if that affects the electronics. If manual timer, unplug unit and move the cam yourself to the next position.
Aug 06, 2015 | Maytag Washing Machines
Order/Replace Rubber Boot on Maytag Washer?
it can be quite tricky to fit, you can buy one,I would however advise to get a supply/fit quote from an engineer as he will get discount on the part, unless you are good diy person ,get hired help....
Nov 28, 2009 | Maytag MAH6500 Neptune Front Loading...
Maytag washer is leaking out of front door, its a front load washer
There are a couple of steps to be done to fix the issue. Please follow the steps provided in the bellow mentioned link:
Thank You
Sep 12, 2009 | Maytag MAH6700AWW Neptune Front-Load...
the board is the easiest fix you can have, just take the backsplash apart & swich it out, order from with your model #
Jul 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
Gray marks on light colored clothes
That is exactly what it is, grease. It is coming from the transmission past a worn or defective seal usually the transmission will have to be replaced.
Mar 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
Neptune washing machine will not lock
Dear raghar73,
ngfam at you service!
The Neptune is discontinued due to to many defects in design!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Aug 09, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune mah7500aww adding water to wash cycle problem
Your inlet valve at behind top of machine is defective; or the pressure from your faucet is insufficient.
Close your faucet valve on wall & unscrew your hoses to check screens on hoses & machine. Clean out well. See that the water pressure is good. Refit, check for leaks. If this is not the problem change your inlet valve, it is easily done.
Sites for spares: (which is good)
Pl rate if helped.............
Jun 06, 2008 | Maytag Neptune MAH7500WH Front Load Washer
Won't cycle to the next step
maytag neptunes are the worst appliances to get. i worked for maytag and the neptunes are over price and break very easy. plus the cost of repairs are very expensive. i would recomend getting a new washer. youve put enough money into this one and getting it fixed is going to be expensive. especially when the fix is only temporary. something else is going to leak or break.
Feb 02, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
151 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
