Question about Haynes Chevrolet and GMC Pick-ups Repair Manual Online for 1988 thru 1998 Full-size Light-duty Gasoline Engine Models. Includes 1999 and 2000 C/K Classic models, 1992 thru 1999 Suburban, 1992 thru 1994 Full-size Blazer and Jimmy, 1995 thru 1999 Tahoe, 1992
My 1992 gmc 2500 melted a few starter wires that i repaired and now it trys to start but wont.how do i fix it
1992 gmc wont start. new starter, new battery. just clicks
I had an 84 silverado & a 91 sonoma with the same problems. It was a ground wire. Make sure all body, & frame wires are Attatched, tight & clean of rust & corrosion, no frawed wires. Also make sure battery terminals are clean & tight. Good luck.
Nov 02, 2012 | 1992 GMC Sierra
Starter wont turn over
Most of time the reason for a chevy starter wont turn over stems from no power blown ignition fuse. Dead battery ,dirty battery cables, loose connection at the starter, bad starter solenoid or burnt starter motor.Start with easiest and cheapest things first.Check any fuses marked ignition,remove battery cables and clean with wire brush clean the battery post also. While the battery is unhooked charge and load test, check the connections at the starter. If the fuses are good and battery is ok. The cables are clean and connections are tight you will need to remove starter and solenoid and take them to be tested
Aug 11, 2012 | Haynes Chevrolet and GMC Pick-ups Repair...
Car wont start
check starter,alternator
or any loose wire on battery
Apr 03, 2012 | 1992 Lincoln Town Car
My 92 olds 88 royale will go for a few minutes then just die and sometimes wont start back for hours!!
check your wiring harness that plugs into the coil pack and see if the wires are melted or showing. i have a 92 and the wires melted together and it was doing the same thing and it also could be your coilpack or your ignition control module (icm)
Aug 20, 2011 | 1992 Oldsmobile 88
Starter tests good. ignition switch on steering column replaced. still have starter problems. clicks when key turned, but motor spins only intermittently.
Will we know switch and battery are good, need to check for voltage at the big wire on the starter assembly, should always have voltage, that voltage comes from the battery right to the starter, while some one trys to start it, with test light check at big wire, if you have voltage at big wire, try hitting the starter, could be stuck, if you have voltage but goes away while trying to start, check connection's at starter and battery, also check body ground
Aug 05, 2010 | 1992 GMC Sierra
Car randomly wont start
Next time you have this problem, try shifting into Neutral then start the car. If it starts, then it's your neutral safety switch.
May 25, 2010 | 1992 Subaru SVX
My truck will not turn over! It intermitantly
THIS IS MOST LIKLY DUE TO A FAULTY ELEC. CONNECTION TO THE STARTERS POWER
Nov 29, 2009 | 2008 Dodge Ram Pickup 2500
Car wont start at all not turn over or anything has power just wont start check everything still nothhing
try to start it while moving the gear shif all around. if it trys to crank put a new nutural safty switch in it.
Aug 05, 2009 | 1999 Dodge Neon
Haynes Chevrolet and GMC Pick-ups Repair Manual Online for 1988 thru 1998 Full-size Light-duty Gasoline Engine Models. Includes 1999 and 2000 C/K Classic models, 1992 thru 1999 Suburban, 1992 thru 1994 Full-size Blazer and Jimmy, 1995 thru 1999 Tahoe, 1992  Logo
63 people viewed this question
Top Haynes Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Haynes Electrical Supply Expert? Answer questions, earn points and help others
