Question about Hand Tools
How to thread a strimmer
A challange strimmer
Champion strimmer 25 cc cord
its a pdf
Champion Strimmer Manual - 64.140.158.30
64.140.158.30/champion/champion-strimmer-manual.pdfhomelite: operator's manual 25cc string trimmers - owneriq - read your operator?¢?€?™s ... kimmel manual kawasaki petrol strimmer tg24 manual ' champion ...
Jul 17, 2016 | Garden
How to thread a strimmer instructions
Top half you wrap the trimmer line in the direction shown .Bottom half in opposite direction.. Question not very clear ?? Ken
Jun 08, 2012 | Black & Decker Hand Tools
Hi I recently bought a Ryobi RLT26CDS. Every time the thread needs extending I have to undo all the gadget and manually pull and extend the thread. could you please tell me how I could extend the thread...
'Bump' the strimmer line unit on the ground (this is how it releases the line)-It sometimes gets stuck(welded to the sides if the release chamber-it gets hot and melts)-
hope this helps
Jun 07, 2010 | Ryobi Garden
Rethreading a garden strimmer
Hi Deborah,
You need to start from the beginning of the trimmer string. Remove the entire spool. Insert the start of the line through and wedge it into the little groove to keep it from coming loose. Now wind the line tightly and neatly in the direction shown on the spool. (it should provide an arrow stating to "wind this way". As you near the end of the line, keep it snug and push the end through the hole where it leads out to the cutting zone. As you re-insert the spool into the housing, make sure it stays tightly wound as you lock it into place. This should help. Usually when your string is too short, you tap the **** of the spool on the ground to advance the line. It should feed a bit at a time, and when you hear it getting cut off, you should stop advancing the line.
Hope this helps.
Apr 13, 2010 | Black & Decker Garden
Bump feed on Strimmer head will not un screw. it Just turns constantly
your strimmer head has rounded where the bolt is located.You will need a new head so you have to break the plasic to get at the bolt and fit a new head.
Jul 19, 2009 | Garden
Where can i get a replacement bump feed strimmer head for my Husqvarna strimmer
Lowes, Home Depot, or any small engine repairer that deals in either Oregon or Rotary repair parts. Or try Husqvarna directly: http://www.husqvarna.com/au/homeowner/support/genuine-parts/
Jul 10, 2009 | Garden
Gls 220 auto strimmer
When putting new line on, it must be wound clockwise onto the spool
Jim
Jun 30, 2009 | Black & Decker Garden
Threading line on black & decker GL301 strimmer
Do you mean that the string keeps feeding as you try to operate the trimmer?
If so, you are winding the string on the spool the wrong way. Put the string on the spool in a clockwise direction. This should do it.
Jim
Jun 19, 2009 | Black & Decker Garden
How to thread a strimmer Black and Decker
the spool itself had a direction how to wind the string.
Apr 28, 2008 | Black & Decker String Trimmer Cordless 12"...
Hand Tools Logo
13 people viewed this question
Top Hand Tools Experts
Don Numinen
Don Numinen
Bill Boyd
Dan Apthorp
Are you a Hand Tool Expert? Answer questions, earn points and help others
