Question about Miele KF7642S Bottom Freezer Refrigerator
I have a miele fridge freezer .The freezer alters temperature dramatically when food is either added or removed .It then can take days to recover to - 18 deg .Can you please advise
  • 171 Answers
SOURCE: freezer is icing up and
Hi miss_i2000
I'm Harvey the Master Plumber
Your question is: freezer is icing up and fridge temperature has risen to 10 from 5. Also alot of condensation in the fridge and the fan doesnt seem to be working in fridge. Correct temperature on freezer -18 but ice. new frost free fridge freezer bought 1.5 weeks ago
This is no problem for you. You are under warranty and as long as you have not tryed to repair it yourself you are completely covered. Look for the manufacturer's warranty phone number on the paper work that came with it or call the sales man, he will be happy to track that down for you because he wants repeat business.
If you bought it used the only answer is to return it. You could get a local pro to repair it at yuor own expense but I wouldn't recomend that for a frige only 1.5 weeks old!
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 11, 2008
maklean
  • 1665 Answers
SOURCE: MIELE KFN8762SDED (SS/fridge/freezer)
Have a look at page 5 (KFN8767 Miele refrigerator) it may be similar. Exact model number didnt find.
http://www.miele.co.uk/Resources/OperatingInstructions/KFN%208767%20S%20ed-2.pdf
Posted on Sep 19, 2008
  • 70 Answers
SOURCE: Miele bottom freezer / fridge. Main control panel
Electronic is about 150 pounds plus vat
Ring Miele in UK on phone number below.
01235 233133
Posted on Mar 29, 2010
  • 70 Answers
SOURCE: The fridge section of my Miele fridge/freezer
You require NTC for fridge evaporator. Part no.7323301. It is the one screwed to the back wall of the fridge with a green band on it.Behind the cover at the rear of the light.
Posted on May 24, 2010
ginko
  • 19396 Answers
SOURCE: The Miele Fridge Freezer KFN8462S
Hi.
F2 indicates that there is a defrost problem. For this reason, if you turn off and defrost the fridge manually, the unit will work for a while after doing defrost.
You said that you replaced temperature sensor. What is called temperature sensor is different from the defrost thermostat, which is one of the parts involved in the fault.
If there is no defrost cycle, or if defrost is insufficient, problem is usually the defrost thermostat. The thermostat is located behind the freezer section rear wall, where the evaporator resides. To access it you need to remove frozen food and undo screws holding the back panel. The thermostat is a metal cylinder shaped object connected to two wires and clipped to the evaporator. The thermostat can be tested using a multimeter set on impedance. If reading impedance at room temp. on the thermostat contacts is infinity (circuit open),then the thermostat must be replaced. In the same way is tested the defrost heater. Check also that evaporator fan is starting.
If parts in the evaporator section are working, then the problem can be the defrost timer, which starts the defrost once every 8 hours.
Here how thermostat looks like. In same page read also the repair instructions from other users.
Regards.
Ginko.
Posted on Jan 25, 2011
Miele KFN8993SDN Freezer temperature to high
Temperature displays
During normal operation, the temperature display shows the temperature in the middle of the refrigerator section and the temperature in the warmest part of the freezer section.
Aug 20, 2015 | Miele KFN12923 SD-2 Stainless Steel 369 l...
How do I set the temperature for miele fridge freezer pigeon pair kfn 9753 iD?
Wait for it to cool
while it dies you will see flashing bars
wait
it will cool
Feb 24, 2015 | Miele Refrigerators
Why does miele fridge light keepsflashing
temperature displays flash under the following conditions:
  • - wheneveradifferenttemperatureis being set,
  • - wheneverthetemperatureinthe appliance has risen by several degrees, indicating that the appliance is warming up too much. This short-term loss of cooling is no cause for concern in the following cases:
  • - whenthedoorhasbeenleftopenfor a while, for example to take out or put in a large amount of food,
  • - whenfreshfoodisbeingfrozen.
Sep 03, 2014 | Miele KFN12923 SD-2 Fridge Freezer, A...
Meile fridge freezer ice on floor of fridge
This fix procedure is simple and should not daunt anyone. First switch off the unit - best by removing any electrical connection, plug, socket, etc. At the rear of some (?) Miele fridge freezer units inside the compartment, is a large plastic panel. Remove this by first removing the food trays and then, use the screws in place on this panel. You wioll probably have to manoevre out the small cabled temperature "sender" control unit. Also see the drain hole at the bottom of the unit's back wall. Above this is a heat exchanger (like a car radiator). You need to pour hot water into the heat exchanger body at the top so the probable ice build-up is melted. This can take several jugs full of hot water and the drained water needs to be recovered at the bottom and lost elsewhere. I think I used a combination of old towels and drain cooking tray. If you don't do this, you will simply have a big water mess. When you feel the water flows easily the ice has probably been melted. The hot water shouldn't damage the heat exchanger at all. Dry all the components you can see around the heat exchanger. Then turn your attention to the drain hole. This discharges through a small plastic outlet into a water overflow tray and this is likely to be blocked with either more ice, or dirt. Poke a plastic rod or wooden stick down this hole and wiggle it about. You are trying to ensure that the drain hole is free to drain any auto-defrost water away by itself. When all is clear and dry, replace the large plastic panel, switch on the unit and hopefully see that the fredige freezer comes back down to the right temperature. You may need to refer to your User Manual to see how the temperature and settings all work. Good luck.
Jun 03, 2014 | Miele KFN8762SDED Bottom Freezer...
Fridge temperature too hot won't go down with temperature controls
This looks like there is a problem with thermstat in the fridge. We had a fridge that would not cool and we found it to be the thermastat problem. You have to replace the thermstat on the fridge. Not 100% sure but a high possibility.
Mar 23, 2014 | Frigidaire Refrigerators
Miela fridge freezer freezes food in the fridge
Most likely reason is fridge evaporator sensor faulty. The sensor is screwed to the back wall of the fridge behind bracket next to light and has a green band near the end . The sensor come as a repair kit (part no. 7323301). Just follow instructions in the packet.It is quite straight forward
Jul 24, 2010 | Miele KFN8762SDED Bottom Freezer...
The fridge section of my Miele fridge/freezer keeps freezing all my food! I put it on 'holiday mode' to defrost and within 24 hours of turning on again, it has frozen up.I don't hear the motor switching...
HI
Most likely problem is NTC, which is behind cover at rear of light.You will require torx screwdriver to remove. It's the one with green markings on screwed to the back wall of the fridge. Part no.7323301 it about 35 pounds to buy
Mar 22, 2010 | Miele KFN8762SDED Bottom Freezer...
Fridge Freezer will not maintain fridge temp, but freezer fine
My miele fridge freezer has just come up with a fault code F4 where the temp is... what does this mean and how can we fix it???
Dec 30, 2009 | Miele KFN8762SDED Bottom Freezer...
No problem just use the + and - buttons when you have chosen the temp. you want just let go and that is the temp the fridge or freezer will set at.
Aug 19, 2008 | Miele KFN8762SDED Bottom Freezer...
Ffa70 hotpoint fridge freezer
Adjust the temperature control for the freezer to a normal setting. Fast freeze is only for when new products are put in that need to be frozen. This locks the system into a continuous run mode and could be responsible for the freezing condition in the refrigerator section. Check the temperatures with a thermometer as the sensor for the freezer temperature could be bad causing the light to come on.
May 18, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Open Questions:
ice blocks water drainage hole Our Miele fridge-freezer (actually model no. KF7542SN or KF76422SN) has a no-frost refrigerator as top section. This seems to work as follows: the cooling part of the cycle is followed by a short defrosting period when the ice crystals on the back of the fridge melt and the water runs down to a horizontal collecting "ledge" 2/3 of the way down the back wall. from there it is channelled through a small hole in the back of the fridge to the outside where (presumably) it evaporates. The problem is that the hole easily becomes blocked, initially only partially but enough that all the water can't run away before the next cooling cycle starts. It then freezes, further blocking the hole and impeding outflow at the next defrosting cycle. Pretty soon there is a solid block of ice constantly filling the freezing ledge and then the water runs down into the rest of the fridge and accumulates in the veg trays etc. We have several times removed the block of ice (melting with a hairdryer) and cleaned the hole as much as can be done from inside the fridge. Initially this cured the problem for several months, especially after we raised the thermostat on the fridge to 6 degrees. More recently however, the hole seems to freeze up again after a day or two each time we clean it. Perhaps there is dirt on the back edges of the hole which we are unable to remove from inside the fridge (I'm reasonably sure that the hole is not easily accessible from the rear of the fridge either, although we haven't tried). The Miele manual only states that the hole should be kept clean, but this is pretty clearly a design flaw which must affect all of these fridges. Perhaps they've cured it in more recent models. They have a £99 call-out fee to examine the fridge without any guarantee they will fix the problem first time or at all. I'd be very grateful for any advice!!!
Aug 16, 2008 | Miele KF7642S Bottom Freezer Refrigerator
Miele KF7642S Bottom Freezer Refrigerator Logo
Top Miele Refrigerators Experts
Starnley Johnwells
Starnley Johnwells
Oloyede Monsuru
Are you a Miele Refrigerator Expert? Answer questions, earn points and help others
