Question about Datamax H-Class H-8308X Printer
Printhead won't balance... I have tried everything. I'm printing horticultural products (tags, labels, potstakes...) and I can't get a "happy medium" on print quality when changing stocks. I am highly familiar with driver settings, printer settings, and the labelling software we are using. I've tried mechanical changes to the Printer (no details on that one though....) to create more pressure and change the printhead angle and nothing is working. Some stocks it works great (treetags) but switching over to potstakes, for example, I would need to rebalance the printhead...I've spoke to Datamax about this as well...Any ideas?
  • 35 Answers
Buy a Zebra or a TEC printer, they haveno problems with ballancing. I have had similar problems with a customer Datamax printer and could not sort it.
Posted on Dec 31, 2009
LX810 Label Printer is printing out labels that are the wrong colour. Oranges are pink, darker colours are pink, and some are purple. I have swapped out the ink cartridges and the problem is occurring. Any...
It's time to clean the printhead. Use the procedure from the printer status monitor. Try cleaning several times but beware it will drain some extra ink from the cartridges. If the cleaning process will not increase the quality of print, probably you will need to replace the printhead. Before replacing printhead, remove all the cartridges and verify if all four gaskets (seals) are present on the inner bottom of the printhead. Also remove printhead, clean contacts both on the back of printhead and carriage with isopropyl alcohol. Put back printhead and cartridges and let the printer do its ink system initialization process. Then try to print your labels again. If all those attempts fails, replace printhead.
Apr 30, 2014 | Primera Technology Primera LX810 Color...
Barcode scanner won't read printed labels
1. The printhead in your printer might be scratched (evidenced by thin white streaks through your print). This is common, and the most likely cause. Printhead must be replaced.
2. Material might be stuck on your printhead (usually evidenced by wide white streak vertically through print). Printing surface of printhead can be cleaned with rubbing alcohol and cotton ball.
3. The ribbon might be wrinkling due to uneven tension, producing intermittent diagonal streaks in your print. This is somewhat common, but doesn't fit your description as well as 1 & 2 above. Mechanical adjustment and/or proper media loading solves ribbon wrinkles.
4. Poor pressure and/or printhead alignment. Evidenced by grainy, light or no print on one side or the other of the media. This is somewhat common, but doesn't fit your description as well as 1 & 2 above. Mechanical adjustment solves printhead pressure and alignment issues.
Dec 11, 2012 | Datamax E-Class E-4203 Label Printer
My cyan colour won't print : tried aligning page, everything, can you help?
Try to do the Deep Clean Printhead function on your printer to force ink through the nozzles and clean possible clogs and dirt.
Feb 11, 2012 | Lexmark Office Equipment & Supplies
We removed a stuck on label, now the printer won't print half the thermal label
I haven't seen one of these for years. However I really need more detail. In what direction is the print missing? across or down the label?
If across it most likely a dirty printhead
If down the label it could be a portion of label still stuck to the sensor.
Can you describe where the label stuck?
Aug 19, 2011 | Datamax Prodigy Plus Thermal Printer
Does this have ink why does it say it's thermal I have a Letra Tag
It doesn't have separate ink. The label tape is heat sensitive and the text is printed by a thermal printhead which heats the tape to change color.
Feb 23, 2011 | Dymo LetraTAG Thermal Label Printer
I have a Zebra Z4M printer. We use it to print on various labels - pre-printed and blank labels (semi-gloss). I've been struggling to print on one of the pre-printed labels. Everything else prints...
some labels are hard to calibrate, nee to calibrate the sensors with manual calibration.
1} go to the MEDIA AND RIBBON CALIBRATION,
2}take 2 or 3 labels from the base paber, load the way to the based paper stay unther the sensors, 3}close printhead.
4} press ok.
5} Move the ribbon out from sensors and close the printhead.
6) press ok
7) wen printer ask RELOAD ALL, load the labels correcly and the ribbon, close the printhead and the top door, and press ok. The printer run the calibration it self.
wen finish, saved (press setub twice) and test.
Jan 21, 2011 | Zebra Z4M Printer
Argox x-2000+ barcode printing is not clear
Hello !
This model is an thermal printer.
The thermal printhead need to be cleaned with isopropylic alchool with a cotton bud.
All the best !
Nov 05, 2017 | Argox X-2000+ Thermal Label Printer
The printer will print a bar code but the reader will not read it. the reader reads the bar code from a second printer just fine
Sounds like there are some elements worn off of the printhead causing some of the bars to not be printed. To test, create a label that prints a thick black line or solid black box across the width of the label (assuming a 4" label). Any vertical white lines that show indicate elements that are not functioning.
You could also put one label above the other, lining up the barcodes and you'll probably see bars that are missing from the label that won's scan.
The only ways to correct the problem are to install a new printhead or move the barcode field on the label so that the missing elements fall in the spaces between the bars.
Hope that helps !
Apr 08, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Label over run
Check the size of the label in your codes or driver.
The length must be correct or else you cannot use it correctly.
You must may be recallibrate the sensors
May 17, 2009 | Toshiba TEC B-452 Thermal Label Printer
Printing fade at the midle of the page
Build up on the printhead, printhead pressure, or worn platen roller...
Apr 26, 2007 | Zebra Stripe S600 Thermal Label Printer
Datamax H-Class H-8308X Printer Logo
135 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Starnley Johnwells
Starnley Johnwells
Joseph Mueller
Joseph Mueller
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
