Question about Onkyo TX-SR674 Receiver
It will turn on and after a few seconds it shuts off and the standby button flashes
    Brigadier General:
  • 3,917 Answers
Is the subwoofer self-powered (signal fed by RCA cables) or is it wired into the Speaker Outputs? If the latter, take it out of the mix and see what happens. In either case, is there a subwoofer-designated output or are you borrowing from the main channels?
And check the ever present Tape Monitor switch on older equipment. If it's in the wrong position you'll possibly lose all sound but it could also have an oxidized connection in its 'normal' position, which could make one channel crackly or dead.
On old equipment it is wise to TURN THE POWER OFF and manually operate all controls fully throughout their ranges and move all switches and buttons on and off repeatedly to clean oxide. Also disconnect/reconnect every RCA cable using a twisting motion to clean them
or
Could be a short in the speaker wires or one of the speakers. Or it could be an internal short in the receiver. You're going to have to do some debugging to narrow it down.
Try disconnecting everything but the front left and right speakers and make sure these two speaker wires are intact (no damage like crushing or frayed wires) with clean connections at the speaker and the receiver end. If you are able to play the receiver like this with just the front two speakers connected for more than an hour, using music (use "5 channel stereo" mode to make sure you are sending a signal to all channels) then add in one speaker at a time: add the center, wait an hour with music playing through it, add the left rear speaker, wait an hour with music playing, add the right rear speaker, etc., then finally the subwoofer.
If the system shuts down after you add any of these specific channels then you've narrowed it down to the speaker wire for that channel, the speaker itself or that amplifier channel. To narrow it down further, try using a DIFFERENT WIRE and a DIFFERENT SPEAKER for the "bad channel" - if the receiver shuts down after adding the center channel, then substitute one of the rear channel speakers (and a new speaker cable) for the center channel and see if this works. If it shuts down again, then you can be pretty sure it's the amplifier/receiver at fault.
If it's the amp, then your best bet is probably to ship it to the Onkyo shop for repair unless you have a good local shop. Onkyo will send an estimate before performing the work.
But first inspect the speaker wires closely, make sure there is no damage to the wires and make sure you have clean connections on both the receiver and speaker ends with no stray strands of wire that may be rubbing against each other either on the speaker or receiver side.
Thanks for contacting Fixya
Posted on Jun 23, 2009
SONY VPL FX-40 projector. After plug in-ON/Standby LED is red for few seconds and starts flashes in red(repetition rate of 12 flashes). After pressing I/O key-ON/Standby LED flashes in green(few...
A Flashing Red ON/STANDBY LED means one of the following
2 Flashes - The internal temprature is high. Check the air holes are unobstructed.
4 Flashes - The fan is broken
6 Flashes - The internal electrical system has failed.
There is no entry in the manual for 12 red flashes.
Feb 19, 2011 | Sony VPL-FX40 Projector
TV is on standby and turning it on goes green then a few seconds later the screen will qiuckly flash and go back to stanby so it will not turn on
indicating over current shut down. Depending on brand and model, power supply troubleshooting will aid you in repair.
Feb 18, 2011 | Televison & Video
TV Turns Off On Its Own
Standby light flashing is error sign and shows tv got problem some where in its circuit boards.
You will notice 3 seconds long pause between red standby light flashing so count pause to pause and post how many times it flashing to diagnose problem of tv.
Thanks.
Jul 01, 2010 | Sony KP-65WS500 65" Rear Projection...
Enters standby after being on for only a few seconds.
Sounds like either the volume is turned up too loud, or you have a short. Have you tried disconnecting all the speaker leads from the rear, and then powering it on? Usually if it turns on for a short time and then shuts off, it is throwing itself into protection mode.
Sep 07, 2009 | Yamaha RX-V363 Receiver
Only power light will power on for few seconds then flashes.
Does the main lamp light at all? It sounds light a cooling fan failure. If the fan iis not working the the main lamp will not turn on and the power light will flash.
Jan 07, 2009 | Optoma EP755 Multimedia Projector
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
TV turns on for a split second then back to standyby
i think your capacitor is blown, do a google search for insignia, lcd, capacitor...
you can buy another one for about $2 but its a pain to install, you can also instead buy a new powerboard for about $80, its an east install and you wont blow more capacitors
bestbuy.partssearch.com
May 09, 2008 | Insignia IS-LCDTV32 32 in. Television
Onkyo TX-SR674 Receiver Logo
69 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
