Question about Toto Aquia II Dual Flush Toilet
I lost the push buton of the doultron pedigree when i did open the lid to replace a gaskit the butto fel into the toilet
Grohe service
toilet will need syphon replacing. the lid should lift of the cistern, some have the push buttons screwed down to the syphon and to remove them just turn the ring around them anti-clockwise.
Aug 22, 2014 | Home
Toto toilet won't flush
Replace the assembly. This is common in areas with high mineral content in water. You will be glad you did. Delay too long, you may find your toilet running while you are at work .
Jan 25, 2013 | Toto Drake ADA Compliant Toilet with...
How do i take the lid of the cistern
There is a trick to this for Porcher toilets. Push big flush button down, then lift up and out the small button. The big button lifts out. Undo plastic bolt and lift up lid. cheers, zoofish
Dec 18, 2010 | Porcher Toilet Seat Veneto 70032.001
My eljer toilet leaks between base and back. it has a built in overflow. there is no overflow tube. i change gasget but still leaks.
Look for cracked ceramic at gaskit joint might need to replace tank..I did after weeks of trail and error.
Nov 28, 2010 | Eljer & Savoy& Toilet Tank With Lid
The lever (handle) to flush the toilet does not rise after it is pushed down, causing the toilet to run. One has to push the lever (handle)up after the down motion to make it function properly.
I had this issue as well with my toilet. My chain was unattached and had been sucked down the drain under the stopper valve preventing the toilet stopper valve from completely closing and causing the water to continually run. After re-attaching the chain I noticed when I flushed the toilet that the handle did not rise again until I manually pushed it up. After readjusting the chain to a tighter position where the chain was not floating at all but instead holding the stopper valve in place I again flushed to check the reaction. This fixed the issue of the water continually running and also the handle not resetting itself properly.
Here is the steps I took to resolve my issue:
Step 1: Remove the lid off of the tank.
Step 2: Check to see if the chain coming from the Toilet Handle to the Stopper Valve is loose, unattached, or broken.
Step 3: Flush the toilet and check to see if the problem has been fixed. If not readjust the chain to a different position and flush again.
Step 4: If all is resolved replace the tank lid.
Other possible things to check:
Check the Float Ball to see if it's Half-way or more submerged in the water. If it is it needs to be replaced.
I hope this helps!
Nov 08, 2010 | Toto Home
Mansfield 160 extremely difficult to make it flush
If this is the model am thinking it is, you need to replace the flapper. it goes down in open to far and gets bound.Or if you have hard water or calciaum buildup,it is making for a tighter opening. I hope this helps. :)
Jul 06, 2009 | Mansfield Plumbing Products Mansfield...
Need instructions and Switch for twyford close coupled cistern
i presume with lid of u can flush toilet by pusshing switch with finger if so buttons must be spot on when replacing lid can be adjusted inside systern any probs get back
May 07, 2009 | Toto CST414M-51 Aquia Dual Flush Close...
Fuel filter
Hi yes i sure can i have the same year of truck you have also. ok your fuel filter will be on the top of your engine towards the front just in back of the cover that says powerstroke diesel. it will be a little round canister that twists off like a lid on a jar. but before you do that you will want to open the fuel/water seperator valve by sliding the little yellow plastic lever located just under the fuel filter. allow this to drain for like 5 seconds. then make sure you close it back up. then just twist the round canistor counter clockwise until the lid can be taken off. once it is off discard of the whole lid due to the new filter will come with a new lid. also throw away the gaskits because your new filter will come with new ones. just be careful and watch for the big gaskit that seals the lid to the canister this is the way you will want to install your new gaskit. beveled side up. but before you install the new gaskets and filter make sure you put a little either motor oil (15w40) or just diesel fuel on the gasket for lube so you do not tear the gaskit when you tighten the new filter lid. but anyways just lube the gasket and install. then just take the fuel filter and install it into the canister and tighten. but do not over tighten just a good snug will work. ( i just use my hands to tighen and loosen them) so there is no need to have to put a wrench on this. after that make sure you wipe up any spilled fuel. and then get into your truck and turn on the key the electric fuel pump will automatically prime and fill the canister with fuel just turn your key on and wait until your wait to start light comes on and then start it up. Make sure you climb back under the hood and fell with your hand to check for any leaks around the canister. after that you are all done. you should replace this filer with every 2nd or 3rd oil change.
Oct 21, 2008 | 2000 Ford F250 Super Duty Crew Cabs
Toto Aquia II Dual Flush Toilet Logo
27 people viewed this question
Top Toto Home Experts
Donni Steen
john h
Robert McCall
Robert McCall
Are you a Toto Home Expert? Answer questions, earn points and help others
