Question about Kitchen Ranges
My hja2540 extractor works but the light does not, new bulbs didn't work
Hja2540 extractor hood
  • 203 Answers
SOURCE: baumatic cooker hood lights not working
take the bulb out and bring it with you to store and see if you can find one the same . DIY stores have tons of types.Joe
Posted on Nov 22, 2008
SOURCE: Kitchen extractor fan
hi! most of the time this will be sticky switch normally located on the inside edge of the extactor unit behind the filter mesh!.hope his helps
Posted on Dec 20, 2008
SOURCE: Bulb has blown on one of the lights but the other light will not
Its definetly the control board again.
Its worth $110.00
Read other answers ive given to others about similar problem
gtp_jmp
Posted on Feb 08, 2009
manhandy
  • 146 Answers
SOURCE: light on cooker hood doesnt work
check the switch, if you got power then the switch or bulbs sockets.
Posted on Jun 24, 2009
  • 72 Answers
SOURCE: bosch dke 935 90cm hood. light and extractor not working
The fuse will be located in the switch or socket that the hood is connected to. This is sometimes inside the flue on the back wall. There should be two small screws either side of the chimney located at the top, unscrew and slide one part of the chimney down, please be careful as stainless steel has very sharp edges.
Posted on Jan 04, 2010
Hi I have an Ikea cooker hood/ extractor fan, fan is working but lights ( 12 V. GU4 ) are not. Just replaced the bulbs but no joy.....
Without the MODEL Number... and the 12v GU4 lamp... I am going to HAZARD A GUESS that your lighting has an internal TRANSFORMER... (most likely)...
But there are less expensive things to check first
Since this is now a GLOBAL SITE you will have to disclose your Line power... (USA: average household range hood = 120V 60 cycle AC current)...
ERGO:
transformer is a 120v to 12volt output (live measurement)
For walk up TROUBLE SHOOTING
"Multi-meters" are a must...
Opening assumption
THAT YOUR NEW BULBS are good... is understandable... but possibly wrong (I'm just saying).
Power OFF
- Verify bulb continuity
- Verify switch operability
Happy hunting
Carnac the Magnificent
Feb 07, 2017 | Kitchen Ranges
Why do interior lights stay on 1998 silverado
well need to sort the buttons on the side off the doors mate be jammed just flick everyone of each door .
Aug 27, 2014 | Cars & Trucks
HJA2540 cooker hood fan not working. Lights work and little red light comes on when switches for fan speeds are pressed so has the fan gone or is it the capacitor? Many thanks Steve
Unless that's a much bigger range hood than I imagine, there won't be any capacitor - the motor will be of a shaded-pole design. If you have a multimeter, you could measure for voltage on the motor wires when the motor should be running - if reasonable voltage is there but the motor isn't spinning, then the motor's dirty or unlubricated or dead. If no reasonable voltage is present, the electronic controller has failed.
Aug 03, 2014 | Kitchen Ranges
Hi my Kuppersbusch fan is not working. Is this common, any suggestion?
My extractor hoods lights have stopped working(2X 20W). I've replaced the bulbs with new ones but no joy!
Any suggestions?
Carl Dally
Oct 23, 2009 | Kuppersbusch K IKD12250.0E Island Range...
Light on cooker hood doesnt work
Jun 22, 2009 | Kitchen Ranges
Its worth $110.00
gtp_jmp
Jan 22, 2009 | Kitchen Ranges
Baumatic cooker hood lights not working
Nov 16, 2008 | Baumatic F60 Stainless Steel Kitchen Hood
The extractor on my Baumatic fan stopped working. Thsi was shortly after the light bulbs blew which I replaced and they work OK. Any suggestions as to how i can resolve this?
Sounds like it was the main fan motor - that caused the lights to blow in the first place.
Isolate from supply, and get the fan motor checked out. If it is burnt out (inside) you will need a replacement.
Hope this helps.
Jun 05, 2008 | Baumatic F60 Stainless Steel Kitchen Hood
Neff extractor fan not working
I have a similar problem with a Whirlpool oven hood. In my case the kitchen fiitters used a (UK) standard 3-pin plug to power the hood. The plug is fitted into a socket that is placed on top of the cupboards that house the hood.
I have replaced the 3 amp fuse in the plug and now the fan is working.
HOwever, the light isn't working and so I'm assuming that the bulb has blown and that this has caused the fuse to blow as well.
Now my problem is accessing the bulb so that I can replace it.
Mar 20, 2008 | Whirlpool GZ7730XGS Stainless Steel...
Fan and light not working where is fuse box?
Hi - I have a neff extractor fan and have the same problem. The light and fan have both stopped working. Does anybody know where I can find the fuse as I suspect that this may be the problem too?
Dec 07, 2007 | Whirlpool GZ7730XGS Stainless Steel...
Kitchen Ranges Logo
69 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
