User manual for veise rear view system reverseing camera
3 Suggested Answers
jango2
  • 38 Answers
SOURCE: Rear view camera setting???
Dear debbie,
This could be caused by the following:
Purple/white "reverse sensor wire" not connected to vehicles reverse lamp harness. (Are your reverse lamps functioning?)
OR
Reverse cam video out not connected to Kenwood's "rear view camera input" (Yellow RCA socket behind the unit).
The monitor set up controls merely switch R-cam betwen "full, just, zoom and normal" modes. No provision here to ebnable or disable the cam.
When you put your car in reverse dos the monitor screen change?.
Jango
Posted on Mar 09, 2008
  • 202 Answers
SOURCE: the rear camera when reversing the car does not respond on the screen. No viewing on Suzuki escudo 2006 model. What should be done ?
sorry for being smart but that connection between your head and shoulders ,,, try rotating it !!!!
Posted on Feb 15, 2012
My rear view mirror camera quit working I checked the fuse it's good the backup lights work.Help
Circuit/System Description
When the transmission is placed into REVERSE, a 12 volt signal is sent to the rearview camera image display module indicating that camera operation is requested. The rearview camera image display module then supplies ignition voltage and ground to the rear vision camera. The rear vision camera sends video information through the rearview camera image display module to the inside rearview mirror through a video signal + and a video signal - circuit. A grounded shielding also wraps the video signal circuits to reduce electronic interference which may degrade the video signal and cause a distorted or otherwise degraded image.
Rearview Camera Image Display Module (UVC)
In the instrument panel behind the driver side knee bolster to the right of the steering column
Do you know how to do electrical testing ?
Rear Vision Camera System Does Not Display
Ignition OFF, disconnect the harness connector at the rear view camera image display module.
Test for less than 1.0 ohm between the ground circuit terminal 3 and ground.
? If greater than the specified range, test the ground circuit for an open/high resistance.
Ignition ON, verify that a test lamp illuminates between the ignition circuit terminal 2 and ground.
? If the test lamp does not illuminate, test the ignition circuit for a short to ground or an open/high resistance.
Ignition ON, park brake applied, vehicle in REVERSE, verify that a test lamp illuminates between the control circuit terminal 1 and ground.
? If the test lamp does not illuminate, test the control circuit for a short to ground or an open/high resistance. If the circuit tests normal, replace the BCM.
Ignition OFF, connect the harness connector at the rear view camera image display module. Disconnect the harness connector at the rearview camera.
Ignition OFF, test for less than 1.0 ohm between the ground circuit terminal B and ground.
? If greater than the specified range, test the ground circuit for an open/high resistance. If the circuit tests normal, replace the rear view camera image display module.
Ignition ON, park brake applied, vehicle in REVERSE, test for 5.8-6.2 volts between the 6-volt reference circuit terminal A and ground.
? If less than the specified range, test the 6-volt reference circuit for a short to ground or an open/high resistance. If the circuit tests normal, replace the rear view camera image display module.
? If greater than the specified range, test the 6-volt reference circuit for a short to voltage. If the circuit tests normal, replace the rear view camera image display module.
Test for less then 1 ohm between the shield ground circuit terminal 10 at the rear vision camera display module harness connector and terminal D at the rear vision camera harness connector.
? If greater than the specified range, test the shield ground circuit for an open/high resistance.
Ignition ON, test for less than 1 volt between the signal circuit terminal 9 and ground.
? If greater than the specified range, test the signal circuit for a short to voltage.
Test for infinite resistance between the signal circuit terminal 9 and ground.
? If not the specified value, test the signal circuit for a short to ground.
Test for less then 1 ohm between the signal circuit terminal 9 at the rear vision camera display module harness connector and terminal C at the rear vision camera harness connector.
? If greater than the specified range, test the signal circuit for an open/high resistance.
Ignition OFF, disconnect the harness connector at the inside rearview mirror.
Ignition ON, test for less than 1 volt between the following signal circuits at the inside rearview mirror harness connector and ground:
• Video + signal circuit terminal 6
• Video - signal circuit terminal 7
Test for infinite resistance between the following signal circuits at the inside rearview mirror harness connector and ground:
? If greater than the specified value, test the signal circuit for a short to ground.
Test for less then 1 ohm between the following signal circuits:
• Signal circuit terminal 12 at the rearview camera image module and terminal 6 at the inside rearview mirror.
• Signal circuit terminal 11 at the rearview camera image module and terminal 7 at the inside rearview mirror.
If all circuits test normal, test or replace the rear vision camera.
Ignition ON, park brake applied, vehicle in REVERSE, verify a clear rear vision image is displayed on the radio.
? If a clear rear vision image is not displayed, test or replace the inside rearview mirror
Feb 21, 2016 | 2009 Hummer H3
When put in reverse the image is up side down.
How to Reverse the Image on Backup Camera eHow
EVERYTHING YOU NEED TO KNOW ABOUT REAR VIEW CAMERAS
After installing a backup camera on your vehicle, you need to reverse the image so that the image on the screen matches that of your rear-view mirror. The orientation must match so that the driver doesn't get confused with two conflicting images. The nature of the camera's technology is that its image will be recorded un-reflected, but the mirror will display a reflected image. Fortunately, the engineers who designed back-up cameras thought of this and created simple controls for you to change the orientation.
Read more : http://www.ehow.com/how_6641139_reverse-image-backup-camera.html
Jan 12, 2016 | 2011 Lincoln MKX
I purchased a 7"" pillow ftf color monitor,what else do Ineed to use it as rear view reversing aid
You need rear view camera in back of car /truck.
This is attached to reverse light ,live and negative
and live run to the monitor while monitor earthed.
Just you tube it.
LUCK
Jan 02, 2015 | Mercedes-Benz Mercedes Benz A Class Maisto...
How can I get the install instructions for PYLE PL7300BT Rear View camera system?
Pyle PLCM7300BT Mobile Video Navigations Back up Camera Rear View...
Went to this site to find your particular product,it has a downloadable pdf manual whic will by default show you your setup.You may not have the green wire but if you read this manual you may be able to by process of elimination figure out your question.Pyle also has a very good technical support staff,been there done that ,they will also help you out.Good luck hope this helps you.
May 19, 2014 | Pyle PLCM7300BT 7"TFT Mirror Monitor W/...
My toyota vitzs 2007 modal came with NDDN w56 multi av station i fixed a rear view camera by connect the vedio yellow cable and power to the reverse gear light but when put reverse gear no no display .any...
you don't need any settings actually it works with a three wire camera because the camera operates on 7volts and is powdered by the system, no need to connect it with the reverse switch, its already wired to the system, just connect the camera and will work.
May 12, 2011 | Car Audio & Video
My pioneer double din screen says ''Caution, screen image may appear reversed''...how can i solve this problem?
As you know, you can use this DVD AV Receiver with a rear view camera. And also it can be installed to switch automatically from the video to rear view image when the gear shift of the car is moved to Reverse position.
But it is important to use a camera which outputs mirror reversed images.
Otherwise the screen image may appear reversed. And this means that you will see the rear view reversed in the monitor. And that may cause accicent and injury.
To solve this problem, first check your rear camera whether it has the capability to output mirror reversed images.
If it is, then check the wire connections of the rear camera using the operation manual or ask a technician.
Also check the settings of camera polarity if it is set properly or not in the system menu when connecting the rear view camera.
You can download the operation manual (pdf file) by clicking here.
I hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Apr 11, 2010 | Pioneer AVH-P4000DVD Monitor
What does the green/white wire connect to on my jensen vm9312hd? Says it is reverse +
Rear View Camera Input: The VM9313 features a composite video input and a green/white wire lead attached to the harness for connection of a rear view camera. If a rear-view video camera is connected, the unit is on, and the TFT monitor is retracted inside the unit, the TFT monitor automatically moves into the viewing position and Camera modes is selected upon shifting into Reverse gear. When shifting into Drive gear, the TFT monitor is retracted back inside the unit. If the monitor is already in a viewing position and in display mode, the monitor automatically switches to Camera mode upon shifting into Reverse. When the reverse driving stops, the monitor returns to its original input display mode. You can choose for the monitor to display a Mirror mode image or a Normal mode image from the rear-view camera.
Jun 21, 2009 | Jensen's VM9312 Car DVD Player
The rear camera have two wires: one is Video AV2 and the other is black/red color, OK. Now, my question is:Where to connect the black/red wire? Thank you.
This is the power connection.
You need to connect this to a 12v switching circuit to enable the camera to overide the current display.
For example, you could attach it to the reversing light switch in the gear box so that when you select reverse the picture is over ridden with your camera view. Or to the reversing lamp. You could connect it direct to a switch for manual control.
Mar 23, 2009 | Car Audio & Video
Dear debbie,
OR
Jango
Dec 11, 2007 | Kenwood DDX7019 6.95 in. Car Monitor
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
