Question about xmarks.com Computers & Internet
Xmark mower will not go backward or forward - xmarks.com Computers & Internet
lester482529
  • 226 Answers
SOURCE: Mtd mower will not move forward or backward.rear
OPPISITE MOVEMENT IS STANDARD W/OUT TENSION,SOUNDS LIKE TRANS IS GOING OUT.HOW OLDIS YOUR MOWER?
Posted on May 31, 2009
  • 15 Answers
SOURCE: Suddenly stopped then could not pull mower
Sounds like your mower has a safety mechanism that has locked up. On your push handle is a bar that must be pulled back in order to pull start cord, it has a cable that goes to the safety brake, check the cable to the safety brake on the flywheel, it may be broke. If it isn't in the safety brake itself, try spraying the cable with WD-40 as this may free it up. Or the cable may need replacing from wear. To check this pull back on the handle and watch the on the side of the engine where this cable attaches, if it is moving on the side of the engine then this cable won't be the problem. In this case it most likely will be the safety brake itself that's the problem. Do not remove the safety brake if under warranty as this will void your warranty.
Posted on Mar 25, 2010
  • 143 Answers
SOURCE: Toro self paced lawn mower works just fine going
Your cable might need renewing, it could be rusted or frayed where it connects to the gear lever,or the lever itself could be stuck. Try spraying it with W D 40. Check the gears inside the wheels, they might be stuck and need freeing and oiling. Stephen.
Posted on Nov 05, 2010
  • 3911 Answers
SOURCE: Mower will shift into forward and reverse gears
either your drive belt has failed or your transmission has failed. make sure the drive belt is snug and not broken, do not do this while the engine is running. if the belt is good, then it is new transmission time. they cost more than a good used replacement mower.
Posted on May 08, 2011
  • 6468 Answers
SOURCE: mower run but wont drive forward or backwards?
check the drive belt also is the release lever pulled the one that allows you to push it
Posted on Apr 17, 2012
Simplicity hudrostatice 4212 riding mower..wont go forward or backward?
ether bad pump are bad check valve pump 350.00 check valve 100.00
Sep 08, 2014 | Garden
Why wont my cub cadet 1050 go forward or backwards
the transmission drive belt may have came off.
May 24, 2013 | Cub Cadet Garden
Motor will not turn over on xmark riding lawn mower
use a pair of jumper cables and go direct from the battery to the starter if it starts start checking your safety switches starting with the clutch/brake pedal
Sep 23, 2012 | Garden
Xmark not charging
se if you have power from the alternator to the voltage regulator
Apr 29, 2012 | Encore EXMARK LAWN MOWER HEAVYDUTY STEEL...
Mower run but wont drive forward or backwards?
Apr 15, 2012 | Toro Garden
Rider mower won't go forward or back
Ihave craftsman Lawn Tractor was cutting grass and it stop moving forward or backward. Can you help me
May 16, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Computers & Internet Logo
14 people viewed this question
Top xmarks.com Computers & Internet Experts
David Payne
David Payne
Are you a xmarks.com Computer and Internet Expert? Answer questions, earn points and help others
