Question about Kitchen Ranges
I have a defy stove 4 plate model dss369, it does not have a power cable at the back. So which cable is prefered that i can use and how do i connect it?
2 Suggested Answers
SOURCE: Kelvinator Stove Power Cable Connection
You should unscrew the small back panel, on the undercover should be a scetch of the wiring.
If not the three red are live, black is neutral and the g/y is earth, from number 5 to 1 connect as follows: 5 and 4-black,3,2,1 red and look for a screw type fitting or green wires to connect earth.
Its important to connect earth before operating the stove as it cuold lead to serious injury if not connected.
Hope this helps
Richard
Posted on Nov 23, 2008
Defy 731 multifunction oven stopped working
switch as probably burt out so that the connecors inside dont touch anymore, or your supply fuses for the stove have blown, check your fuse box. but at any rate if there are sparks i would replace stove or get in a qualifed person the check your stove.
Oct 22, 2014 | Ovens
3 plates stopped working and the 4th one does not switch off.
unplug the unit and gain access to the wiring connection for all 4 elements(plates). remove the wiring from the element that will not shut off. while making sure none of the unconnected wires do not touch any metal or another wire, and plug in power cord. if the 3 non-working elements get hot then replace the none working control knob
Apr 03, 2014 | Stoves Kitchen Ranges
Wiring Diagram Defy 521 Electric Stove
NEED A WIRING DIAGRAM OF A DEFY 521 ELECTRICAL STOVE
Sep 29, 2012 | Kitchen Ranges
How to connect the defy 600u stove to the main power supply
how to connect defy 600 su on single phase
Jun 25, 2011 | Ovens
I have a new Defy hob with the colour connections in 4's, but my oven is an older DEFY and has two rows of 6 connectors... please help. How do I connect a new DEFY hob to an old Defy oven?
I have the same predicament. Did you manage to connect your new hob to your old stove? If so, please let us know how to do it.
Thanks.
Mar 04, 2011 | Ovens
I need diagram to wire defy 600s hob and oven , can you help please
Hi Gary The hob connectors have colour coded plug ins. They are starting from right to left the red connector is for the front right plate, the white is for the back right plate, the blue is for the the back left plate and the black is for the front left plate. Now I am not sure of the config in your country but another way to look at this is that The red dot 2000 W (large plate) is connected to the black harness and the red dot 1500 W is connected to the blue harness. The std large plate 1500 W is connected to the white harness and the red harness is for the 1000W small plate. The wiring onto the actual plates should be accrording to the colour codes as follows: The harnesses are all 4 wires and are colour coded blue white ( wiring block 1) , yellow white(block 2), white ( wiring block 3) and the red white block 4. The actual plates are numbered from left to right as 1,2,4,3. But my wiring write up takes it as standard 1 to 4 so do mot worry about the numbers on the plates as some plates have no numbers. Hope this helps.
Nov 09, 2010 | Stoves 1100ESIDLa Electric Kitchen Range
Oven not working
I had the same problem. At the back of the stove is a plastic cover with thermal overload written on it.
Switch off your power.Remove the cover, pull out the two luggs and connect the two luggs straight to each other. Make sure the oven knobbs are in the off position. turn on the power. If your oven clock etc. comes on the thermal overload is faulty and needs to be replaced. It is fixed to the stove by a screw from the inside of the oven, so open the door and remove screw to remove thermal overload at the back of oven. Take sample to electrical shop and replace. DO NOT USE OVEN WITHOUT THERMAL OVERLOAD.
Dec 27, 2008 | Ovens
Hope this helps
Richard
Dec 23, 2007 | Stoves 1100ESIDLa Electric Kitchen Range
Kitchen Ranges Logo
21 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
