Question about Coffee Makers & Espresso Machines
Why does my caffitaly so6hs have the warning light stay red and nothing happens. I have had the machine for about a year. Any ideas. Thanks
My caffitaly coffee machine will not work. The red light stays on and nothing happens. I did a descaling to clean and now nothing works.
JohnnyBeans
  • 223 Answers
SOURCE: Trouble Lights Stay On
How long does it take for your machine to grind for 1 cup? Longer then 10 seconds? Grinder setting?
Descaling should be done every 2-3 regardless if the light comes on or not. To reset the light hold the steam button until the light goes off.
Descaling information can be found at http://www.cerinicoffee.com/clean_descale_coffee_equipment_instructions.asp
Hope this helps!
Posted on Oct 12, 2007
  • 2039 Answers
SOURCE: Saeco Royal Digital won't brew coffee
normaly descale it gonna affect the water . in the waste cointainer do you have coffee that goes there i tink the brewer is the problem the pvc thing inside the machine that can be remove .remove check it visualy something blocking it cheers
Posted on Jan 15, 2008
SOURCE: heating light stays on
I contacted Keurig at 866-901-2739. Based on my serial number, I was still within my 1 year warranty. They determined that my heating element was bad, based on the fact that the the area above the power cord was not at all hot, which it would be if it was truly heating.
My new machine will arrive via FedEx in 3 days!
The Keurig rep did also mention that the heating elements are sensitive to hard well water, which I have. They have seen issues where hard water requires you perform more frequent de-scaling of the brewer, depending on water hardness. Alternatively, we may switch to bottled water.
Posted on Aug 21, 2008
SOURCE: The decalcification light stays on constantly.
I had the same problem with Spidem My Coffee with no instructions how to turn the light off. used the Saeco instruction and solved.
simply press the steam button for 6 seconds and the light will turn off
Posted on Mar 18, 2010
  • 5 Answers
SOURCE: Senseo coffee maker not working
One of two things, first of all, it wont open until it cools down/depressurizes. First problem is that the ground coffee is two fine, and the second possible problem is that the coffee is packed too tightly. That is assuming that you dont use the pads but coffee pad adapters.
Posted on May 23, 2010
Descaling light flushing & nothing else works following descaling.
probably you have to rinse the machine and then it will be work!
Dec 28, 2014 | Saeco Coffee Makers & Espresso Machines
Why does the red and green light on the right side stay on?
Hi there, I am having the same issue. The machine has worked before, but I haven't used it for a while. I need it to work now while I try to fix my other machine! I will post a reply if I work it out.
May 13, 2014 | Saeco Coffee Makers & Espresso Machines
Giaggia Brera descaling problem
been talking to Gaggia (Philips) and they told me that with the newer Breras, you need to ill the water tank, put the machine into standby, then press the long and short cup buttons together for 6 seconds. This will start an auto descale programme (that they didn't mention in my manual!). A small amount of water will be dispensed through the coffee nozzles, then it will stop and the warning triangle and the prime warning light will come on. Place a large container under the panarello, then turn the knob to the right to dispense water. It will dispense about 50 - 100 mls (cold) water, then stop for about a minute. Just leave it and eventually it will empty the tank. Refill it and start again, but it will stop after a few seconds. Turn the knob back to central position, then it will dispense another small amount of water from the coffee nozzles, then stop with warning lights again. Turn the knob back right to dispense water, if it stops because of empty tank, just refill it. Eventually, the machine will stop and go to standby. Turn the knob back to the centre, refill tank yet again and the machine will start normally WITHOUT that descale warning light. HOORAY !!
Jan 22, 2013 | Coffee Makers & Espresso Machines
Caffitaly coffee machine is continually beeping
The Caffitaly Machine Beeps when it needs Descaling...the reduction in the water flow is an indicator that your machine badly needs this maintenance procedure to be completed. Refer to Page 15 of your User Manual.
Sep 30, 2012 | Dualit Coffee Makers & Espresso Machines
Descale light came on yesterday, have descaled as per the instructions but the descale light is still on
happened to me once this worked for me . had to fill tank 2 more times to allow the machine to flush the descaling mix (think its part of the cleaning process but the instructions are a little vauge)after this it worked fine
Apr 16, 2011 | Philips Senseo HD-7810 Coffee Maker
The red light is staying on, what do i need to do?
The light stays on if you do not follow the instructions when descaling. You must hold the button for 3 seconds to descale. It takes about 20 minutes. If you press the button for less than 3 seconds with the service disc you just run the water through quickly to rinse/clean and the machine doesn't reset the rescale light.
Feb 15, 2011 | Bosch Tassimo TAS4511UC Coffee Maker
When the machine is on and the heating has completed, pressing the buttons to make coffee has no effect. They just blink once and nothing happens. The steamer seems to work fine tho.
This happens to us sometimes and we find that the problem is with the capsule holder. Try taking the capsule holder apart and then twisting it together again. If it's not quite in the right position, the machine will not dispense the coffee!!
Oct 28, 2010 | Gaggia Caffitaly K111 Coffee Maker
Red de scaling light won't shut off
Removing the red descaling light is simple.
1. Fill reservoir with half vinegar and half water (no need for the special descaling product from Tassimo).
2. Turn on machine.
3. Insert yellow cleaning disc found in back of machine.
4. This is where most people have the their problem...You must hold the start button for 3 to 5 seconds for the descaling program to start. Both green and red light will flash.
5. Once started, use a large cup to catch the output of water.
6. The machine will cycle through the descaling program in about 30 to 45 minutes. Be paitent!!!
7. Once completed, run many cups of plain water through the system to remove the vinegar taste.
8. Red light problem is solved.
Hope this works for you.
Apr 11, 2010 | Braun Tassimo Espresso Machine/Coffee...
Coffee Makers & Espresso Machines Logo
71 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
