Question about Freezers
I bought a soft serve taylor 754 machine. when shipping arrived, the wheels are broken off. Now I need to replace wheels. do you carry those wheels for that machine? and if so what are the prices
  • 3 Answers
I HAVE WHEELS IF YOU STILL NEED THEM.
Posted on Jan 21, 2010
  • Freezers Master
  • 1,262 Answers
I use Restaurant Parts and More out of Ohio. Very reasonable on prices. Usually contractor prices. Talk to Rick. He know to ask the right questions should there be some clarification needed.
1-888-814-1110.
I've been buying parts from them for years w/o any problems.
Posted on Jun 25, 2009
Just bought a Woods Upright freezer, not sure when it was last used, but when I got it home, i turned the knob to the cooldest setting (7) and it kiced on. how long should it take to start freezing. I have...
Freezer should not take more than 2 hours to.be at minus 10celcius. If only cold and not seeing any ice on the inside wall this could mean that there is missing refrigerant in the lines. Other way to check is to feel the pipes on the back if hot to the touch. There is many signs to see if your refrigerator is working or not.
If the compressor is running non stop and is very hot it will tell you that there is missing gas in the system.
If compressor is mot warm and is cycling on and off this could be only thermostat issue.
Good luck
Dec 29, 2017 | Woods Upright Freezer V1613RW3
Not freezing enough
You might have ice building up on your evaporator coil. That ice serves as an insulator and prevents the internal freezer temps from going down to design parameters. The ice buildup is caused by the defrost mechanism not working - check the timer or the defrost heating element.
Jan 07, 2014 | Summit 12.6 Cu. Ft. Frost Free...
How do i replace a wheel on a beverage air freezer
For Service Call (877) 866-1223 Beverage-Air Corporation Offices: 3779 Champion Blvd., Winston-Salem, PA 15825
_________ Manufacturing/Shipping/Receiving: Brookville, PA 15825
Contact with Model Number and Serial number for assistance
Beverage Air
Sea Breeze
Feb 26, 2013 | Freezers
Have a 17 cu ft upright manual defrost freezer. Started to notice that items in door were soft a week ago. Warning light was on but the rest seemed ok. Today noticed a puddle from thawed meat. Sounds like...
Good day,
Serious problem. Either there is a freon leak or a restriction inside the tubing that carries the refrigerant.
Needs the attention of a pro.
Note. If the unit is under 5 years, leave it alone. It is still under factory warranty. Call for warranty service.
May 12, 2010 | Freezers
I have a Taylor Ice Cream Machine 754-27, how can I tell if it is water cooled or air cooled and 1 or 3 phase?
If you remove the side panels and there is a fan motor and blade next to a coil that looks something like a radiator in a car, it is air cooled. If water cooled, it will have fittings so water lines can be attached. Also, look at the beater motor and compressor. On their name plates it will say whether it is single or three phased power.
Hope this helps.
Mar 20, 2010 | Freezers
Beater stuck in Taylor Ice Cream Machine Model Number 168-27
these units are usually set up to have the beater rotate in a clockwise direction facing front. If they get stuck, it is usually due to excessive wear or the hexed end has been lubed and has created a suction seal in it's counter part. Try rotating the beater in a counter clockwise direction while holding the drive wheel pulley stationary. Be sure to unplug unit first. this has worked for me in the past but can be very difficult at times.
Feb 18, 2010 | Freezers
ICE MAKER WILL NOT MAKE ICE
Check for power supplied to unit.
Check that the bin stat has not been broken and has no ice sitting on it. If the bin stat is clean and doesn't appear to be broken, you can attempt to jump out the bin stat and see if the machine comes on.
If the machine comes on, replace the bin stat. If the machine does not come on and you have shut the machine off and back on, then you will need to call for service.
The check valve is a common issue with the Hoshi line-up. If you know where this is, take it apart, clean it, and re-install it.
Jan 08, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Taylor 1999, series 754, 3phase ice cream dispenser freeze up
I have had this with other Taylor machines. The rear drive bearing has a pin driven into the coupling that turns the beater bar. This pin will shear off. The pulley will turn and give the illution that the beater bar is turning but it really isn't. With the unit unplugged, try holding the beater bar still and try turning the large drive pulley.
I have also had situations where the hex piece that the drive shaft goes into, was rounded out. As soon as the mix go a little firm, the beater bar would stop turning but the rear drive assy didn't.
Check this out and let me know.
Jul 07, 2009 | Freezers
Lubricant in gear case electric motor drive
Perhaps there's been some problems with the White Mountain machines since the company was bought out by Rival, the company that makes the cheap *** 30 dollar freezer machines. We have had great success using them to make lots of home mead ice cream and the last time I took the transmission apart, ours had a "dab" of grease in there. I cleaned everything out and used Mobile 1 red synthetic wheel bearing grease. Not filling it full of grease mind you, but using a q tip and making sure all moving parts had lube. As to why yours didn't have any on it, can't help you there unles it had been used so much that it was all gone, but a ne wmachine?; that's a problem. Their warranty dept will give you a new motor within the first 5 years of ownership if you can send them a copy of the recelipt and $10 for shipping. they don't even want the old motor unit back!!!
Good luck
Max
Dec 24, 2008 | White Mountain Freezer F69206-X 6 quart...
Freezers Logo
147 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
