Question about Acer AZ5610U9072 Allinone PC 23' Touch Screen Full HD Wide LCD Pentium dualcore E5300(260GHz) 4 (PWSCY02032) PC Desktop
Why does my pc overheat could be fan ?
I play for hour on a game and then it turns off wont turn on till the heats gone does it all the times cant b on pc for too long or it will turn off and lose all my data
    Problem Solver:
  • 79 Answers
Also check the power supply. This is where the other end of the plug plugs into your computer. When you turn on the computer watch this fan. Continuie to let computer run and see if you notice any changes ( fans stopping), while looking into the case of you see a lot of dust it will help to take the computer outside and using compressed air blowing the inside out. If all this doesn't work unplug the main plug from the power supply to the computer. Leave it running or simply the power supply on and see if there is some type of thermal problem. If that works I would down load some trial software "burn it in " after installing it turn some stress tests on the computer paying attention to temputures. If you find anything with that then take the heat sink off the do I and clean the thermal paste off with cuetips and alcohol. Don't get alcohol all over just a little, not dropping. Re apply thermal paste and try.
Sorry for so many things to try however there can be so many things that cause this
Posted on Apr 03, 2015
    Problem Solver:
  • 14 Answers
Hoover out cpu heat sink it clogs with dust do mine regular
  • 1,087 Answers
Pc overheat for a cpl reasons the most common is ventilation issues. Check the exhaust fan see if its clogged if its ran in a house with smokers the tar sticks to the plastic blades and attracts dust and lint. The proper way to clean them is pulling the panel off and using a clean soft tooth brush to clean the blades "NO WATER" The temp fix is to use compressed air can and try get as much off as you can see. The other thing is the heatsink fan burned out or came unplugged however thats a little harder to get to in an all in 1 pc.
Posted on Mar 31, 2015
2 Suggested Answers
buvhoy2
SOURCE: how to fix overheating issues when playing games
you should have proper ventilation on your pc or buy special PC Casing that has cooling system specially on high end pc's.. hope this help.. thank you.
Posted on Jul 18, 2012
Toshiba satellite p505d s8935 overheats when playing 3d games after about an hour or so. Not every time but often enough to be frustrating. I then have to let it cool off for about 15 minutes and then...
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Sep 19, 2012 | Toshiba Satellite P505D-S8935 Notebook
I was playing my ps3, for about 6 hours, and it shut its self off, now when i turn it on, i have a green light then it turns yellow, can you tell me whats happened please ? and i cant retrieve the game...
Yes this is the YLOD the (Yellow light of death) it happens when the GPU and the CPU overheat and you will need to fix this by stopping the heat build up, you can sned it in and they will fix it for you for $130.
Or you can fix it yourself using a good PS3 Repair guide in under an hour!
It is much the same as the xbox 360 error.
Feb 14, 2010 | Sony Playstation 3 (PS3) Console
My acer aspire 5738g shutdown while i plaay agame
You either overloaded the processor or the available RAM. Also with these laptops and high end games...it is very easy to overheat them unless they are on a cooling pad with another external fan blowing cool air over them, without it they will shut down due to thermal overload....this is to keep them from melting something. Try checking with the support driver page for your laptop and see if there is a BIOS update that addresses the algorithym for fan speed, then pull the heat sink from the processor, clean everything up and apply a good thermal paste compound, then blow out all the airvents and make sure there are no restrictions.
Sep 18, 2009 | Acer Aspire 5720-6661 Notebook PC
My PS2 can play games,but at some time the console would turn off/shutdown automatically with the red light blinking/turning on and off
this is probably an overheat problem. you could remove the heat sync and apply thermal gel to the processor, also check that the case fan runs.
Aug 17, 2009 | Video Game Consoles & Games
My xbox overheats every few minutes. ive tried intercoolers, laptop fans. ive waited a few days to play it. i cant do anything on it or it willl overheat.
HERE TRY THIS I DID THIS VIDEO ON YOUTUBE AND IT NOT OVER HEATING. IF UR XBOX360 IS NOT ABLE COME BACK AND U ONLY GET THE 3 LIGHTS STOP THE FANS FROM SPINING TILL TWO RED LIGHTS TURN ON THEN DISCONECTED FOR 20 MINUTES BUT TRY THAT MOD I DID ON MINE TOO AND LET ME KNOW IT IT HELPED A LITTLE HOPE THIS HELPS A LITTLE
http://www.youtube.com/watch?v=BDEL3orLGq8
Jun 30, 2009 | Microsoft Xbox 360 Console
My cpu overheats and cuts off after i play a online game
try to unplug it for a while and put it back again, make sure you have a fan facing your computer.
Nov 09, 2008 | E-Machines eMachines Desktop PC
My laptop Acer Aspire 5720ZG turns itself off while playing a game
as i think maybe its the graphic card acting up because its getting over heated.
make sure that all the fans are working properly and u might need to replace the graphic card.
for now just make sure that its not over heating and if u want u can download drivers and reinstall them.
most likely its overheating problem
cheers
Aug 13, 2008 | Acer Aspire 5500 5570-2609 Laptop
Compaq presario700
you have missing data files/sys files ;u need to reinstall windows.It doesnt sound like any hardware faults.
when ur done ;theres a option in bios to have fan on constantly when not powered by battery.
if u play games often it would be a good idea to enable it.
Apr 08, 2008 | Compaq Presario 700 470024-192 Notebook
After watching HDTV the tv will not switch back on when left for a few hours.
i'm afraid i have no solution for you, but i thought it might help to know that i have the same problem, mine will sometimes take up to half an hour to turn on, while i have to sit and listen to the clicking sound, and watch the power led flash on and off! YOU ARE NOT ALONE!! sorry i couldn't help though.
May 29, 2007 | Samsung LN-S3241D 32 in.LCD HDTV
Acer AZ5610U9072 Allinone PC 23' Touch Screen Full HD Wide LCD Pentium dualcore E5300(260GHz) 4 (PWSCY02032) PC Desktop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
