Question about Dynex Computers & Internet
How to factory reset DX-801F - Dynex Computers & Internet
I have a Dynex DX-55L150A11 and it scrolls through the inputs non stop can mine be fixed possibly no main boards availanle
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Aug 06, 2016 | Dynex Televison & Video
Why won't my dynex tv stop changing channels?
Just try a reset to this set, and check. If it do not help you, the main system control memory IC is faulty. Check and replace it. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Feb 24, 2016 | Dynex DX-LCD37 TV
Dynex dx-26ld150a11 input trouble
Do a factory reset to this set. You've to enter its service mode to do this. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 24, 2014 | Dynex DX-L32-10A 32" LCD HDTV
How do i reverse reset to factory defaults
go to syetem restore and restore systwm
Jun 29, 2012 | Amazon Kindle DX
I'm trying to to configure my dynex DX-E402 router. when i put the IP# in the web browser, I did not do it right. now i'm tryin again and i can't do it
Hi.
The number you need to put in is 192.168.1.1
That almost always is the default gateway address to the router that you are connected to.
Once in a while, it will be slightly different...i.e. 192.168.0.1 or 192.168.2.1 or something similar to that.
If you type the ones I have listed into your browser, it should connect to your router.
Now, as far as passwords go, if you didn't write the correct one down, then you will have to reset the router.
To do that press and hold the reset button in for 15-20 seconds with the router powered on.
After that the router will be reset back to factory settings.
Then type in 192.168.1.1 in your browser, and it will ask for username and password.
In both those blocks type in the word ADMIN.
These are the factory user names and password combination set by the factory.
I hope this helps you out.
Good luck, and have a good day.
May 04, 2011 | Dynex DX-E402 Router
How do i reset my yamaha dx 100 back to original factory settings
yamaha dx100 reset. Press voice switches 1 and 2 while turning power switch on. Display will say test entry?. press the plus/yes button. This will reinitialize all memory to factory settings. Also the lithium ram backup battery voltage will be displayed as check level with a number representing the battery voltage. The number will be 10 times the actual battery voltage. A new battery will display 33 representing 3.3 volts. If your reading is below 22 then your battery is shot and will need replacing and if you turn the unit off it will probably get a scrambled memory again.
Aug 28, 2009 | Yamaha Computers & Internet
Cobra 150 gtl dx nightwatch
You can send it into a factory authorized repair center, one is in TN that is highly recommended. This is an excellent radio if it has been adjusted properly and the factory mods have been done. Take a look at cbtricks.com for full info on the problems with these radios. Do not take to a regular repair shop; this is a SMT design(surface mount technology) and requires thousands of dollars of equipment and expertise to work on. Trust me I tried to adjust mine and messed it up and had to wait to have them reset it. This radio is very difficult to work on and should be sent into a factory rep. Contact cobra for repair station.
Aug 10, 2008 | Cobra 150 GTL DX Base CB Radio
No connection
Try resetting the router to factory , should have a button on the back to do this .
you will have to log back into it with the default factory password
see their site for more info.
Jan 26, 2008 | Dynex DX-E401 Router
Computers & Internet Logo
35 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
