Question about Dishwashers
Reset adora control panel - Dishwashers
Fan and light on my GE Adora microwave oven will not go off.
It may be a door switch / door switch mount issue or a shorted relay on the controller.
I regularly repair these microwave controllers and details are here.
If you have other questions, it's best to follow up with me directly.
(FixYa does not notify us directly when follow-ups are posted, so we have to log in to the site to see them.)
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 08, 2017 | GE Microwave Ovens
Control Panel failure GE Adora refrigerator
disconnect from the mains, count to 10 and plug back in.
Oct 16, 2015 | Refrigerators
Ge adora French door refrigerator has 88 on front panel and buttons do not work
Try removing all power for 1 minute, see if it resets.
88 on a display is a "test" display usually....all lights lit
also check if the controls are locked....top right button
Mar 12, 2014 | Refrigerators
Error code E70 What is it?
E70 Stuck key Continuous key read for 60 seconds. Power down (unplug) machine, wait 30 seconds and retry. Use t04 test to test keys. Separate control and control housing from front panel - clean and remove foreign debris. Ensure all keys can be operated freely without sticking. Replace control panel if actions do not resolve. Maybe this will help
Oct 27, 2013 | GE Adora Front Load Washing Machine Washer...
Gas flow problem with stainless steel GE Adora stove.
If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
Dec 19, 2009 | GE Adora JBP77SMSS Stainless Steel Kitchen...
I think I need to reset my front loader (adora GE) How do I do that?
Unplug unit, Plug back in.Rotate control knob to correct Model number.Press and hold start key till beep is heard,press power key to reset
Oct 22, 2009 | GE WSXH208A Front Load Washer
Door panel doesnt work
Check circuit fuse,electrical connections,check your door circuit & buttons.
Feb 21, 2009 | GE Adora (DSF25KGTBG) Side by Side...
GE Adora Griddle Top replacement
part number for the griddle is WB31K10140
partstore.com has it for $87.95 hope it helps
Dec 23, 2008 | GE 30" Self-Cleaning Freestanding Gas...
Dishwashers Logo
23 people viewed this question
Top Dishwashers Experts
