Question about Panasonic FP-7735 Black and White Copier
Copier panasonic fp 1670 corona error code - Panasonic FP-7735 Black and White Copier
  • 163 Answers
SOURCE: fp-7713
press and hold paper tray,zoom down,1 simultaniously you will enter in programe.F will come on display press 6 it will appear F6 press stark key change the value and then start key to exit the program press and hold these keys paper tray,zoom down stop key
Posted on Sep 14, 2007
goodgold
  • 389 Answers
SOURCE: Please help. Panasonic copier FP-7728 error code E 1 41
E 1- 41 Optics fan B not working
Posted on Mar 23, 2009
SOURCE: ERROR CODE E340 BLINKS WHEN MY COPIER ON
clean sensor beside drum then switch on machine with white paper on glass.
Posted on May 11, 2009
  • 92 Answers
SOURCE: Panasonic FP-7722 Drum Installation
disingage dv unit lower transport assembly remove blue screw from drum unit take drum unit out remove drum lock towards the front remove charge assemby remove drum reinstall drum remember to apply drum powder and replacement of drum blade is recommended reinstall
Posted on Jun 29, 2009
  • 149 Answers
SOURCE: ERROR CODE E3 -50 (PANASONIC FP 7742)
E3-50 is the malfunction of the transfer wire cleaner. The transfer wire assembly is under the drum. The transfer wire is on the right. The cleaner moves back and forth. If you feel comfortable taking it out, respond. There are fine metallic wires in each slot, so don't break them
Posted on Oct 10, 2009
My Panasonic FP 7850 is showing the e3-11 error code. I cannto get it off from that, what do i do?
E3-11 means a problem with a High Voltages Power Supply Leak..... this most commonly is caused by a dirty corona unit,..probably covered with spilling toner from within the machine.
Open the front door, realease to the left the Green handle in the middle at the bottom...this will lower the Transfer corona unit. You can then pull it out... you will see inside 3 wires, this unit is supposed to be "clean" ...if there is toner on it try cleaning it off with a soft brush or compressed air...DO NOT BREAK THE WIRES.....if you break them you will most definately need a serviceman to replace them because it will not work if you break them!!
Once you have cleaned the corona unit put it back into the holder that you removed it from...reverse your actions and close the machine back up...hopefully that will get rid of the error code.
Feb 28, 2011 | Panasonic FP-7850 Copier
My Panasonic FP-7160copier is showing code: c0210. What does it mean?
C0210 indicates a problem with the Transfer/paper separator corona unit.( the one below the drum)..it is either dirty, not installed properly or may need replacement.
Nov 05, 2010 | Panasonic FP-7735 Black and White Copier
I HAVE A PANASONIC FP-7760 THAT SHOWS ERROR CO1OO. WHAT DOES THIS ERROR MEAN/
C0100 indicates a problem with the PC Drum charge wire cleaning motor(M21's) failure to turn.
M21 is the motor attached to the corona unit itself...you will see this when the drum unit is slid out of the copier.
Oct 25, 2010 | Panasonic FP-7760 Copier
E3 100 error FP 7815
the error would be E3-10. this occurs with a high voltage power leak on charge corona unit. either the corona wire is broken or the unit is dirty resulting in high voltage loss. clean or replace as neccesary
Jul 19, 2010 | Panasonic FP-7750 Black and White Copier
How to solve a problem with a fp-7728 copier with an error e3-11
check hvt or corona wire maybe there is leak in corona wire assembly try to clean or replace corona wire, if same trouble appear replace hvt board
Jan 02, 2010 | Panasonic Office Equipment & Supplies
Error code e30-50 display on fp 7845 panasonic copier
Error code means that the cleaner for the transfer corona unit is not working correctly.
Oct 20, 2009 | Panasonic FP-7845 Black and White Copier
I have an FP 7735 Panasonic copier but I keep getting a blamk line running down the page. I just replaced the corona assy.
You need to clean the charge corona.An eraser will work.I use a folded piece of scotch brite pad held with a pair of hemostats.Be careful not to break the wire.Good Luck!
Apr 21, 2009 | Panasonic FP-7735 Black and White Copier
Panasonic FP-7735 trouble shooting
That could be a few things. Your corona wires might need replacing. Something with the middle transport section, where one of the corona assemblies is at, is not making contact properly. Or it could be the high voltage power supply.
Nov 05, 2007 | Panasonic FP-7735 Black and White Copier
Service code on Panasonic Copier
Your sep/trans corona is either shorting out,or the wire is broken. AFTER FIX IS DONE IT WILL AUTOMATICALY RESET CODE.
Oct 18, 2007 | Office Equipment & Supplies
Panasonic 7735 problem
did you tried to restart the copy machine or to disconnect it from electricity for few minutes?
Jul 15, 2007 | Panasonic FP-7735 Black and White Copier
Panasonic FP-7735 Black and White Copier Logo
20 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
