Question about Scunci 52067 Handheld Steam Vacuum
How to fix a hand held steamer ?
Little or no steam how to take apart
2 Suggested Answers
SOURCE: Need a manual for the hand held Scunci steamer
Try this:
http://www.ehow.com/how_4811845_use-scunci-steamer.html
Posted on May 15, 2010
I have a scunci ss 1000 hand held steamer cleaner. Its been used and given to me from a friend. The steam comes out the trouble is the steam is not hot, just luke warm. how can I fix it myself.
Try descaling it with CLR. Add CLR and water, turn it on but not fully to produce steam, just get it hot. Leave it for an hour. Empty that out and out some more in. Get this up to steam for 10 minutes, switch off, leave it for an hour and empty it. Fill and rinse out twice. Fill with water and see if it is fixed.
Nov 09, 2015 | Scunci SS1000 Handheld Steam Cleaner
Why is vax s7-a+steam mop steamer dripping water and cuts on and off
I managed to fix mine after a little effort. It was blocked well up in the nozzle into a small pinhole where the steam comes out of the 'small kettle' in the steam mop.
To fix:
  • take the blue side bit off by unscrewing the two small screws
  • Undo the screws inside (there are about 11)
  • Once these were undone there was two screws holding the nozzle cover.
  • After unscrewing these pull the nozzle cover of and scrape limescale from inside the small hole where the steam comes out
  • Put it all back together and it should work much better
You should only really do this if you are competent as there are lots of wires etc. and if your steam mop is not covered under warranty as messing around with it will void this.
Hope this helps :)
Jul 04, 2014 | VAX Appliances Vacuums
Hand held steamer not working
make and model please
Nov 14, 2012 | Vacuums
I have a turbosteamer 220 hand steamer. It heats up but won't spray steam
It's most likely the trigger not engaging the piston that releases the steam. Due to the fact that the plastic inside the 220 holding the trigger in place has cracked on both sides.It will need to be taken apart.That's another issue.Be easy on the trigger press down gentle.....
Jul 27, 2011 | Vacuums
Try this:
May 15, 2010 | Scunci 52000 Handheld Steam Vacuum
Steamer filler cap is sealed
You need a little more leverage--either a strap type tool or a pair of adjustable width pliers that span the width of the cap. Try running hot water over the cap first which may loosen it enough to remove by hand.
Sep 09, 2009 | Euro-Pro Shark SC-505 Handheld Steam...
MY hoover steam vac hand held hose cleaner leaks profusely
try taking a sharp knife and shaving a little off the edge of the plastic, or a small file if you can get to it, see if it is getting binded. If its getting stuck internally, you will have to replace the switch instead of risking takin it apart.
Jul 09, 2009 | Hoover F5810 SteamVac Upright Vacuum
Does not give steam.
Actually there was no category for clothes steamer, and before entering information I was prompted to pick a category so I chose vacuums hoping that when my problem was diagnosed it would be understood that the problem is a clothes steamer that has stopped giving off steam. Please help if you can. I appreciated your time.
May 20, 2009 | Westinghouse Vacuums
Scunci 52067 Handheld Steam Vacuum Logo
94 people viewed this question
Top Scunci Vacuums Experts
Craig Butler
Craig Butler
Are you a Scunci Vacuum Expert? Answer questions, earn points and help others
