Question about Konica Minolta bizhub 250 All-In-One Laser Printer
Network setting of konica minolta copier - Konica Minolta bizhub 250 All-In-One Laser Printer
  • Konica Minolta Master
  • 6,161 Answers
  • 8 Answers
SOURCE: Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Posted on Feb 02, 2008
Nitrotrike
  • 589 Answers
SOURCE: copier malfunction
Code C0F36 is a low toner density error on the black developing unit.
Was it asking for black toner before this code appeared?
Posted on Feb 10, 2008
  • 60 Answers
SOURCE: Konica Minolta C450 User Manual
http://kmbs.konicaminolta.us/content/products/models/bizhubC450.html?info=Manuals
Posted on May 27, 2008
Kevin Hayes
  • 167 Answers
SOURCE: Print Booklets with Konica Minolta Biz Hub C650 Printer
Select Print, and then "Properties"
Layout Tab - select Print Type: Booklet
Basic Tab - Select original size and then size of PAPER to be printed. 11x17 is standard 8.5x11 book when folded.
Finish Tab - select saddle stitch.
Thats it, easy as pie.
Posted on Feb 17, 2009
  • 3 Answers
SOURCE: Konica Minolta copier model C252 code C6102 any idea
C6102: Drive Home Sensor malfunction
1.Correct or change the Scanner drive
(cable, pulley, gear, belt) if it is faulty.
2.Correct the Scanner Motor set screw if
loose.
3.Adjust [Image Position Leading Edge] and
[Feed Direction Adjustment].
4.Check the PC201, M201, PWB-IC and
PWB-C connector for proper connection
and correct as necessary.
if all that doesnt work Change PWB-IC.
Posted on Mar 19, 2009
Problem scanning with Konica Minolta bizhub C220
does the copier have a static or dhpc ip address? All copiers love static. ensure one is issued.
Apr 19, 2014 | Konica Minolta Minolta Bizhub 220 Color...
Konica minolta magicolor 4690 mf won't print after changing network setting
I would recheck the network setting first why where they changed???
Jan 30, 2014 | Konica Minolta Magicolor 4690MF...
Konica Minolta bizhub 224 network connection
u have to configure network settings of machine and then try
Jan 07, 2013 | Konica Minolta Bizhub C224 Color Copier...
How do you reset the konica minolta bizhub c451 photocopier/printer to get access to network settings?
Network settings are accessed through the Administrator menu. Press Utility/Counter, then choice #3 should be Administator Settings. Enter your admin password and Network Settings should be choice #5.
Also, if the bizhub is already on the network, you can enter the IP address into your web browser and log in as an administrator to get to the network settings.
Dec 10, 2009 | Konica Minolta Office Equipment & Supplies
Feb 01, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta bizhub 250 All-In-One Laser Printer Logo
35 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
