The air conditioner only produces hot air.
The air conditioner blows hot air. All ducts are connected and where checked for leaks. Freon was checked and found to be alright.
  • 38 Answers
Possibly a dirty filter, dirty coil, or your outdoor unit is not working properly
Posted on Jul 01, 2009
Why dose air blowing out dash hot when in cold a/c position
Hello, There are a number of reasons that may cause your A/C to blow hot air. The compressor belt could be loose or broken, the A/C system could be low on freon, the A/C compressor clutch could be defective or the fuse could be blown, or the A/C mixing door could be stuck open just to name a few.
Jul 30, 2014 | 2004 Ford Excursion
2.5 ton goodman coming on but the fan isnt blowing air throught the ducts smoke
>check for the content of refrigerant from the accu-chiller maybe the refrigerant pipe has a leak that is why the condensation of the basic refrigeration cycle does not takes place so in return high temperature is producing on the fan coil unit to which the air duct to supply fresh air to the room is discharging a smoke instead of a fresh air.
>check if the accu-chiller has an air restriction from its condenser fins because if it has an air restrictions the hot air from this unit cycling around cannot discharge to the atmosphere that is why the FCU to which the airducto to supply fresh air is connected will be producing a smoke.
>check for the FCU fan motor overloading to which the airduct to supply fresh air was connected that is why it is producing a smoke.
Jun 18, 2011 | Goodman Heating & Cooling
Air conditioner blowing hot air on 2002 monte carlo and it has freon in it
car air conditioner blowing hot air is cause by either a leak or a clogged condenser, since it has a freon in it then it might be a case of clogged condenser but this is just a contributing factor, it is possible that the leak is small that you wont even notice that the freon is not enough for the a/c to blow cold air.
Jul 25, 2010 | 2002 Chevrolet Monte Carlo
AC ran for a couple of hours and started blowing
If it is icing over, it is low on freon. You might have a freon leak if the system is relatively new. It will take a licensed tech to check, fix leak and recharge.
Aug 25, 2009 | Fedders AEQ07FBG Air Conditioner
Air conditioner blows out hot air
Hi, my name is Ron,Is the freon level right or to much or to little amount of freon?Does the ac accumilator get really cold?The pipe coming off the accumelator ?If so,look for a vacuum line to be colasped or leaking,and check vacuum resorvoir to see that it is not leaking vacuum...any more help...roniecon@gmail.com
Jul 19, 2009 | 1994 Oldsmobile Cutlass Ciera
Air conditioner blowing out hot air
Sound like your freon is low or you have a leak. You can purchase a reload kit from your local auto parts store which will contain the connecting hose cans of freon and instructions to do it yourself or you can have your local A/C Tech do it for you and have him check for leaks also.
May 26, 2009 | 2001 Chevrolet Cavalier
Car ac blowing hot air
pls the qty of freon is depending of the size but you can not add freon any time since no leak so chek may be
- thermostat
-hot water coil is on
- selector on heating
- compressor is defective or the clutch or coil
- low pressure swith open
-high pressure switch isopen
Apr 21, 2009 | Heating & Cooling
My blower motor doesn't blow air out the air ducts why
Friend,
Happy to assist you!
Perhaps a bad blower.
But sounds like low freon!
If freon is low unit will not go on!!!!!!
Could just be low or could be a leak!
Words alone will not remedy the situation!
Dop not wait to fix it next year!
The cost will be more then Bad Infaltion!!!!!!!!!
You need to call service !!!!!!!!!!!!!
Aug 29, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
88 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
