Question about JVC GZ-HD3 HDD HD Camcorder - 60 GB USB Hard Drive
My inoi hdd is not detected by my laptop. how to i get the pc to detect it. plz help
  • 107 Answers
Can you see the player under “Disk Management”?
If not change the jumper setting on the hard drive to “Cable Select” and see whether it works.
All the best!
Posted on Aug 13, 2009
  • Christy Rajasoundram
    Christy Rajasoundram Aug 13, 2009
    All the best!
    Christy Rajasoundram Sep 02, 2009
    · Can you please try on another USB port on the computer and see whether the player is recognised by the PC?
    · Can you see the player on “Disk Management” If yes it should be not partitioned? Please partition it. If not the hard drive in the player should be faulty. You hear a clicking noise when the player is powered. If you are under warranty return it for a replacement
    · Please try another USB2 cable and see whether the player is recognised.
    · Try on a different computer and see whether it is recognised
    Good Luck!
3 Suggested Answers
Solix
  • 5 Answers
SOURCE: HDS728080PLAT20
Theres a multitude of areas you could look at. Being that it is a Parallel-ATA Drive, I'd start by making sure your BIOS is supporting/set correctly. Second, have you Already installed an OS? for that matter, is it a new or used HDD? Has it booted for you before? (on your system), the HITACHI drives are usually pretty good. More info would be helpful if you can.
Cheers.
Posted on Dec 09, 2007
JulesPCaut
  • 702 Answers
SOURCE: hard drive detection
You should not need a driver for it. Assuming you are using XP or Vista, the disk should be supported directly by the OS.
Have a look at external HDD troubleshooting.
Jules
Posted on Apr 23, 2009
I have a hp elitebook 2530p laptop problem is the hdd is not detect so i change the hdd connector for example - to + +to - problem create display is gone but laptop is on so what we do plz send the...
Hi Friends,
First of all HDD inducted connection, No any - or + option. simple hdd and cable same option given. If you are - to +, or + to - connection may be you HDD damage. So you check it you HDD wall conduction or not. If wall status then you change HDD cable and port and open bios and see you HDD show or not. change you SMPS power connector used different port connector. Nest problem is Display not then you check SMPS proper power comming, No any beep sound in PC, RAM, etc. Finally Change HDD and then check it.
Thanks..
Aug 30, 2013 | HP EliteBook 2530p Notebook
Hp pavilion dv6-2113ax i installed xp but hard disk not detected plz give solution/stata drivers
Hello Shubha,
If HDD not detected then how you install XP. Or this is a secondary HDD.
Normally windows automatically install the SATA drivers no manual intervention needed.
Please clarify.
With regards
Pankaj
Sep 22, 2010 | HP Computers & Internet
My Toshiba satelite e-100 wont go passed the toshiba screen I think it is locked. Is my laptop ruined?
No, the laptop is not ruined. Only a little sick. At bootup press F2 and enter the BIOS. On the first screen you will find an option for Auto detecting the HDD. Use it to detect the HDD. Once HDD is detected, save the settings and reboot.
Aug 24, 2010 | Toshiba Computers & Internet
XP on HP Pavilion dv2000
i think you have a sata hard disk drive.so go to cmos setup and in the cmos setup and please disable the sata drive there
Jan 04, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
My brand new ASUS ee PC notebook won't boot up. Any suggestions?
check in the bios settings if the hdd is detected..if detected,you need to re-install the windows..if not detecting,you must replace the hdd...ahh! i think the hdd for this laptop is expensive..coz i know its something special..not same like normal hdd in laptop,like ide or sata..its small hdd inside the board...half size for the 2.5" hdd sata or ide
Nov 23, 2008 | ASUS Eee PC 900 16G Notebook
Cannot Detect Hard drive Winxp On Toshiba Satelite L200
Hi ,
u can not detect HDD during installing win-xp coz in u r laptop u have SATA hard drive.
to detct hdd in setup u want to make sata netive mode diseble in COMS setup
Plz check COMS thereis sata netive mode is available ....
if this information is useful for u please rate me......
Jun 14, 2008 | Toshiba Satellite Pro A200-EZ2204X...
Acer laptop is not detecting harddisk
kiran,
i thought you have SATA interface, in that case your XP will not be able to access your HDD. But now as you told there is no option for SATA means you don't have SATA interface in your motherboard and the problem might be in your HDD.
  1. So, check out your HDD connection from motherboard and try to install again if no luck then do the following step.
  2. If you have important data/files on your HDD make a backup copy. Then make try to delete all partition and make new partition, then proceed further installation OR if you have recovery disk try to use it to recover your system as factory setting.
Thanks
Iqbal
May 17, 2008 | Acer Aspire 5004WLMi Notebook
Help! Asrock MOBO P4VM800...
There may be something wrong with the HDD. Try it in another computer to make sure it is functioning properly.
May 05, 2008 | Asrock P4VM800 Motherboard
HDD not detected
plz try in another pc, if the problem remains then you contact the vendor
Apr 23, 2008 | Seagate Notebook Hard Drives: 40GB...
No detection
unhook ext drive from laptop...turn off hd...then reconnect to laptop..then turn hd back on..see if you can see it then.
check your computers warranty here 4 FREE
Mar 09, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
JVC GZ-HD3 HDD HD Camcorder - 60 GB USB Hard Drive Logo
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Marvin
Marvin
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
