Question about Toys
Jetsort 1000 coin sorter
How do I fix error msg saying sensor is blocked but cant see any blockage What do I do please
Cogz
  • 1326 Answers
SOURCE: Jammed paper at the Sorter Unit
Do you get a paper jam or is the finsher not showing that is empty? You may have a broken bin or a miss alined bin or you have a lazy sensor flag. The copier should give you a idea where the paper jam is... May need more info. on this one..
Posted on Jun 07, 2008
SOURCE: microsoft live webcam shows error msg
I have a Work-A-Round so that the end result will provide both sound and
Video using the LifeCam NX-6000 with Windows Live on a
Windows Vista ULtimate 64 bit system, please post your system if
this solution works for you.
I guessed that the error messages, the BLUE SCREEN OF DEATH, and
a long list of conflicts that I discovered with this camera shown that
the sound was conflicting with the video.
Overview
I used manycam for the video and I configured Windows Live to handle sound.
I assume that you can get it to work as long as you split the video and sound
on two different programs.
What I did
I installed the vista driver
http://www.microsoft.com/hardware/download/DownloadResult.aspx?category=ICE&type=Webcams&name=NX6000&os=WVista_32&lang=en
I installed windows live 8.1 (I did configure until after ManyCams)
http://www.microsoft.com/downloads/details.aspx?FamilyID=d78f2ff1-79ea-4066-8ba0-ddbed94864fc&displaylang=en
I installed ManyCams
ManyCam Virtual Webcam 2.3.21
http://www.download.com/ManyCam-Virtual-Webcam/3000-2348_4-10593500.html
Configuration
I started ManyCams and configured it to (optionally start on boot) and to
USE LIFECAM NX-6000 as the source.
I then started Windows 8.1 Start > Tools > Audio and Video setup
and configured it to use my
(1) speakers for output sound (Realtek HD Audio) [next]
(2) Microphone Microsoft Lifecam NX-6000 [next]
(3) ManyCam Virtual Webcam [finish]
Reboot, start ManyCam and then start Windows live.
If your still having issues, you may try to disable this service and try again
using the following instructions.
start -> run -> services.msc
then go to Messenger Sharing Folders USN Journal Reader service
click on proprieties and disable it
Ok, thats is what I did and I truly hope that it helps you.
Posted on Nov 26, 2008
PCHelp4U
  • 13 Answers
SOURCE: PC wont boot to windows xp
This seems to Be a common problem with dells, The only way to fix it is to buy a new HD, And all data is Unrecoverable. Sorry for your loss
Posted on Jan 11, 2009
Geekman
  • 32281 Answers
SOURCE: D610 DST Short Status Test Fail
It appears your hard disk has died and it may not be possible for you to retrieve your data.
Remove your hard drive from the laptop and insert it into an USB harddrive adapter, (they are not expensive and you can use it later as a external hard drive). Then plug it into the USB port of a working computer. The computer should/may see it as an external drive, if you are lucky you will be able to copy your data, if not, you are out of luck.
There are companies that can recover data from faulty hard drives, but it will cost you an arm and a leg for their service.
Posted on Feb 17, 2009
SOURCE: I have DELL color laser printer 2130cn error msg load SSF ??
Its not a printer problem more of the paper source of that document is selected as SSF. So in most programs go FILE>PAGE SETUP. Select the paper tab and make sure the correct tray settings is selected. I.E "Default tray" instead of "SSF". cLICK "Default" at the bottom to make this the standard document settings and the problem shouldn't crop up again.
Posted on Oct 20, 2009
C100 Coin Sorter & Counter C-100
Coin sorters have to be able to handle a variety of coins in a variety of conditions. The one intended for home use are not very accurate even when new and sorting accuracy declines with age. The only practical "fix" is to take a technological step backward and sort coins manually.
Nov 12, 2013 | Cassida C100 Coin Sorter & Counter C-100
Model SF2530 photocopy Erroe F1 how to reset
F1 00 Content Sorter communication trouble Detail Communication line test error occurs when power is turned on or after the exit of a simulation mode. Improper communication with sorter Cause Improper connection or broken wire of connector or harness between copier and sorter Sorter control PWB defective Control PWB (PCU) defective Malfunction due to noise Check and remedy Clear by turning the power supply OFF/ON. Check communication line connector and harness. Replace sorter control PWB or PCU PWB. F1 02 Content Sorter transport motor error Detail Transport motor drive trouble Cause Motor lock Check and remedy Check transport motor operation with SIM3-3. F1 03 Content Sorter guide bar rocking motor trouble Detail Sorter guide bar rocking motor drive error Cause Motor lock Motor speed error Overcurrent to motor Sorter control PWB defective Check and remedy Check guide bar motor operation with SIM3-10. F1 04 Content Sorter indexer lower limit detected Detail Indexer has exceeded lower limit. Cause Sensor defective Sorter control PWB defective Check and remedy Check sensor with SIM3-2. F1 05 Content Sorter indexer upper limit detected Detail Indexer has exceeded upper limit Cause Sensor defective Sorter control PWB defective Check and remedy Check sensor with SIM3-2. F1 06 Content Sorter bin shift motor error Detail 1) Bin shift is not completed within 2.5 seconds after bin shift request Cause Motor lock Improper motor speed Overcurrent to motor Sorter control PWB defective Check and remedy Check bin shift motor operation with SIM3-4.
Jan 11, 2010 | Sharp AR-5316 Advanced Digital Imager...
E540 Error
the sorter bins are not lifting equally. find a tray to use on the side of the machine or find a table the right height to use to catch the copies. that sorter is not worth fixing.
Jun 02, 2009 | Canon NP 6551 Black and White Copier
Serice code 792
E721 Sorter stapler bin lift sensor E722 Sorter stapler jogger sensor E723 Sorter stapler grip sensor E792 Sorter stapler error
Mar 20, 2009 | Office Equipment & Supplies
Wrench - Toshiba Studio E-28 error code C82.
could be a sensor blocked and the machine thinks there is paper present follow the small holes on the tray to locate sesor also keep in mind u can unplug the sorter and ur copier will work
Mar 20, 2009 | Toshiba e-STUDIO 282 Black and White...
Feb 17, 2009 | Dell Latitude D610 Notebook
Np 6050
Disengage the finisher from the copier and check that there are no paper fragments blocking the inlet sensor arm. Check all areas that have a green flag attached to them, i think there is one between the copier and finsher.
Aug 27, 2007 | Canon NP 6551 Black and White Copier
Toys Logo
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
