Question about Ricoh Aficio 2022 All-In-One Laser Printer
Why RICOH Aficio MPC2030 display SC452 error?
2 Suggested Answers
joel_baleta
  • 155 Answers
SOURCE: Ricoh Aficio 3006 error sc452
SC326, First of all check that the laser slitglass is still there, I've seen a couple of machines where the slitglass has been missing completely and it's been throwing up laser SCs. Remove the laser unit. Clean all the toner and dust out of it. Clean the synch sensor very carefully. If codes continue replace the LD unit. They tend to fail on these machines due to excess dusting
Posted on Sep 23, 2011
I want ricoh mpc 2030 printer serial number
The serial will be on the configuration or counter pagel
Mar 23, 2017 | Ricoh 841502 Aficio Mpc2030 Mpc2050...
What is the error code sc400 in ricoh c2030 printer copiers
Ricoh Aficio MPC2030 Code: 400
Description
ID sensor adjustment error
When the Vsg error counter reaches "3", the machine detects "SC400". The Vsg error counter counts "1" when the Vsg detected by ID sensor is more than the value (default: 4.5V) specified with SP3324-005 or less than the value (default: 3.5V) specified with SP3324-006.
Causes
• Dirty or defective ID sensor • Defective ID sensor shutter
http://www.printcopy.info/?l=en&mod=erc&brand=Ricoh&model=Aficio%20MPC2030&code=400
Sep 11, 2016 | Ricoh Office Equipment & Supplies
Error sc 565 mp c2030
Hi
The first thing I tend to do with any fault on a computer or related hardware, is to turn it off, unplug it from the power supply, turn off and unplug the rest of the system components. Wait for a few minutes, plug the equipment back in and turn all components on and then reboot the computer. After this I start to look elsewhere for fault diagnosis and repair.
In your case I found a list of codes for your machine here:
Error Codes Ricoh Aficio MPC2030
Here you can view the specific codes by using the drop down menu in the middle of the page. You can also change the make & model of machine by using the drop down menus near the top of the page. Also you can download a pdf format Service Manual for the machine by using the link just above the error table.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 31, 2014 | Ricoh Office Equipment & Supplies
Ricoh NRG MPC2030 does not print PCL windows 8.
Guess youll have to wait a little until its offered. It seems Windows 8 is having many dislikes. Try contacting Ricoh for new Windows8 drive.
Jul 24, 2014 | Ricoh Aficio Office Equipment & Supplies
MY RICOH AFICIO MP C6000 IS SHOWING AN ERROR CODE SC326
That is a "second laser synchronization error". Try this: Hit the yellow button, press numbers 1, then 0, then 7, then hit the orange key. When it goes into SP mode, turn off the copier and unplug it. Wait 15 seconds then plug back in and turn on. If that does not fix it then you need to call a tech to service the machine.
Mar 05, 2011 | Ricoh Aficio 1035 Copier
How to solve error SC452 for colour copier
sc 542 is the fuser error code. please check with a ricoh tech to fix it.
Jan 03, 2011 | Ricoh Office Equipment & Supplies
Ricoh Aficio 2035 wont duplex, displays error message error: Duplex unit is not set. Set it properly
there is a sw on the duplex unit that tells the copier it is closed my guess is that its broke
Nov 04, 2010 | Ricoh Aficio 2035 Copier
The SC 326 is -- 2nd laser synchronization error. Meaning, the 2nd laser synchronization signal cannot be detected by the main scan synchronization detector board even if the laser diodes are activated.
Basically your polygonal mirror motor unit is bad and needs to be replaced. You can replace the whole laser unit but that is expensive. When you replace the PMM unit, do so in a still air area -- as to not get anything in the unit. When you get the PMM unit -- contact me and I can walk you through the steps to replace.
The SC 452 is --- Transfer Belt Mark Detection Error. Once you fix the SC 326 error this one should be fixed also.
Jul 17, 2008 | Ricoh Aficio Colour 3006 Color Copier
Ricoh aficio 200
Ricoh Aficio 200 copier has stopped copying from side tray. Can you help?
jimgoatley@slingshot.co.nz
Feb 17, 2008 | Ricoh Aficio 180 Laser Printer
Ricoh Aficio 2022 All-In-One Laser Printer Logo
74 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
