Question about Pool & Spa
Hi, I just purchased a new aqua flo pump. The previous pump only had 3 wires blue (Neutral), brown (active) and green/yellow (earth) now my new pump has these three plus a black wire labeled "low". Now to my knowledge I'm guessing the old pump was a single speed and the new pump is a 2 speed, now due to the plugs not being the same I've decided to hard wire the pump to the hot tubs control center, now I'm wondering what I need to do with the black wire ?? Can I just join it to the brown (active) wire ?? Or can I just disregard the black wire all together ?? Thanks in advance.
    Loyalty:
    Visited the website for 30 consecutive days.
  • 372 Answers
The black wire is most likely a Common ground wire, I suggest googling a schematic on the new pump before trying.
Posted on May 18, 2014
  •  johnny rebel
    johnny rebel Apr 08, 2015
    get a 2 speed switch and wire it yourself for low and high
  • 372 Answers
Just cap off the black wire, That connects to the low speed windings. Is this motor 115v or 220v?
From your supply power 115v will have a common, a hot, and a ground. Orientation to motor wires/ poles matters.
A 220v will have 2 hot and a ground. Since both line wires are hot, the orientation does not matter.
Make sure you get it right!
Posted on Apr 09, 2015
TheSpaDoctor
  • 10 Answers
SOURCE: electrical connection to pump
can you photograph the new connections for me? if you look at the connections, the neutral normally has a solid link across it, the earth will be to the frame and the other two are the high and low speed live connections.
info@the-spa-doctor.co.uk
Posted on Mar 25, 2009
  • 3600 Answers
SOURCE: Replacement pump for spa (Waterway Executive Euro 2 speed 2 hp
V1 would be low V2 would be high U1 would be line and then ground. A picture would be helpful to be sure.
Posted on Jul 05, 2009
  • 990 Answers
SOURCE: Removal of Aqua-Flo pump from motor
You will need to pull the front of the pump off then unscrew the impeller. The impeller will be set on the shaft and will take some force to break free. Hold ing the back of the shaft and using water pump pliers on the face of the impeller will usually work but sometimes I will wedge a screwdriver in the fin of the impeller and hit it sharply (not hard) with a hammer to break it free. Then the housing will just pull free of the motor. When replaceing, the impeller just goes on hand tight. Hope this helps and good luck.
Posted on Apr 16, 2010
  • 5 Answers
SOURCE: How do I go from a 2 speed hayward pump to a
Wire the red and black to the Line 1 connection on the motore, and the blue on the Line 2, Make sure your motor voltage is correct and turn on.
Posted on Dec 19, 2010
  • 8404 Answers
SOURCE: I bought a new Aqua flo single speed pump but it came in as a 3400 RPM unit instead of a 1700. Can I wire the pump to a slower speed and if so how?
Probably not ... 1725 and 3400 <> are standard speeds for electric motors. See if your dealer will make an exchange for you for the proper speed pump.
Posted on Dec 10, 2012
Want wiring connections to power cord
if 2 speed you need a 2 speed relay can do damage without
Jul 08, 2014 | Aqua Flo Aquaflo Flo - Master Xp2 2 Speed...
My Bryant 561c airconditioner I need to know what wires to attach to my outside A/C is it blue on blue and yellow on brown
Brown is always active, blue is always neutral. But yellow or yellow/green is usually an earth. Sometimes on appliances yellow is used as a signal wire so if that is your only option then I would just run with that. If you trip your circuit breaker after turning it on then it was a earth and your back to square one
May 17, 2014 | Bryant 561CE060-A 561C Package Air...
My terim cooker has 3 wires - black, blue and brown. Do you know which is live, negative and earth?
green or green and yellow is the ground (earth), blue is neutral, black and brown are both lives. this is the standard european wire color code since 2004. If it is older than that, black was used as a neutral, and blue as a live. very confusing.
Jul 21, 2011 | Ovens
With a new Ceramic Glass Induction Hob EHD68210P which coloured wire is the neutral? Brown, Black, Blue or Green.
Standard wiring colour:
Active - Red or Brown
Neutral - Blue or Black
Earth - Green/Yellow.
Best thing is to call an electrician as you do not want to damage your appliance.
Nov 04, 2010 | Electrolux Ovens
Satchwell cylinderstat has brown, blue and earth (green/yellow) wires. which is te common and which is connected to the orange on a Honeywell V4073A 3 port valve. I presume the green yellow goes to the...
The colour codes are as follows:
Brown = Line / Active
Blue = Return / Neutral
Green/Yellow = Earth / Ground
It is likely that the Brown and Orange would be connected together but not 100% sure.
Sep 21, 2010 | Plumbing
I need to know what wires go to each marking
com=common= [ L ](live)same, the one that kills you. =red/brown N - neutral=black/blue Earth=green or green&yellow striped old colours= red, black, & green. new colours= brown, blue & green/yellow. L,N E.......... If you are uncertain of your abilities to wire up ,ask a competent electrician .........your life is worth more than £50.00.
Mar 08, 2010 | Water Heaters
Heath-zenith sl-6107 wiring diagram
hi there the wirings colour codes for nz are as follows
OLD WIRING CODE
Green = Earth
Black = Neutral
Red = Phase Or Live
NEW WIRING CODE
Blue = Neutral
Brown = Phase or Live
============DANGER 230VOLT ===============
Electricity can kill.
You should use an Electrical contractor for this repair job,
Caution always turn off power first before touching any wiring,
The Live wires always carry power,from one point to another,
the black neutral is your return path from the live phase wire
the green wire is always the ground ,
In this example
the sensor will have four wires as follows
Green = Earth Wire
Black = Neutral
Brown = Phase (incoming supply) 24 hrs
Red = Phase Load (outgoing supply) from sensor to lights triggered
Notice there are to phases in the circuit.Brown and Red
Always treat them as LIVE or Active Power.
Brown will normally be the Live incoming power and
Red will be the load side of the sensor,
Check the brochure supplied by manufactuers or their website to confirm the wiring order is correct before commencing any installs or repairs,
Always Safety first.
Safe a live today and you'll remembered forever.
Jul 06, 2009 | Heath Zenith Occupancy Motion Sensor Wall...
Cable Wiring Colour Coding
European color codes are black or brown for hot, blue for neutral, and green-yellow for earth or ground.
Nov 17, 2008 | Electronic Specialties ESI 385A Digital...
Washing machine
green and yellow is earth so wire the earth wire to this. brown is live in and blue is neutral in. brown/white is live out and blue/white is neutral out. usually a suppressor capacitor has a diagram printed on it
Oct 15, 2008 | Washing Machines
Pool & Spa Logo
131 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
