Question about HP Pavilion dv7-1245dx Notebook
Why would my HP Deskjet Ink Advantage 3525 cause my sony vaio SVT131A11L to crash?
If the printer is hooked up by USB for printing for about 10 minutes, the computer goes blue screen (advising of an automatic shut down)and after another 10 shuts down . . .I have just reinstalled the printer, so that shouldn't be the problem, should it?
    New Friend:
    Problem Solver:
  • 11 Answers
From the description of the problem, this seems to be a driver issue. What Operating system are you using?
Posted on Apr 13, 2017
SOURCE: printer deskjet 3650
Posted on Jul 10, 2008
SOURCE: HP Deskjet 6940 printer - printing but no ink transferred to page itself
I have the same issue, but with a HP DJ 3550, I´ve heard about the data execution protection (DEP) migth help when changing the options, but still have to try it
Posted on Jul 17, 2008
  • 38 Answers
SOURCE: blue screen stating I should disable my BIOS memory options
I have no Idea, except if it using winows, then it could be a case of right clicking a blank desktop, select setings or personalize or whatever, and change you display properties from therw. I do not know your mechine. Windows is a diferent matter.
Posted on Feb 10, 2009
  • 11 Answers
SOURCE: flashing on/off light on hp deskjet 3520 printer
Introduction The printer lights indicate the printer status. These lights can be on, off, or blinking (flashing), depending on the status of the printer. The sections below describe the most common combinations of blinking lights, how to fix the issue, and how the issue is caused. NOTE: The light patterns included in this document are described as blinking or flashing lights. For the purpose of this document, "flashing" means the same as "blinking." Blinking lights Printer lights can can blink for more than one reason, so the solution can vary. These solutions need not be performed in a specific order, but solutions for the most common issues are presented first. Blinking lights are often accompanied by an error message on the computer screen, which might help determine the solution. Issue: Power light is blinking
c00374282.gif Solution
Close the cover.
Printer cover is open. Solution
Insert appropriate media in the In tray.
The printer is out of paper. Solution
  • Change the printer's print mode setting.
  • Change the printer's paper type selection.
  • Use a different brand of label media.
The printer has difficulty picking up label media. Solution
Follow each of these steps until the problem is resolved:
  1. Remove the paper from both paper trays.
  2. Press the power button once. Wait a moment for the paper jam to clear.
  3. If printing labels, verify that a label did not become detached while passing through the printer. If the paper jam was not resolved, continue on to the next steps.
  4. Remove the rear access door.
  5. Remove the paper jam through the opening at the back of the printer.
  6. Replace the rear access door.
  7. Reload the paper into the paper In tray.
  8. Print the document.
There is a paper jam. Solution
  1. Remove and then reinsert the print cartridge(s) into the printer.
  2. Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
  3. Manually clean the print cartridges and print cartridge cradles:
    • Open the printer cover and wait until the carriage moves to the center.
    • Press the Power button to turn off the printer.
    • Disconnect power cord from the back of the printer.
    • Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
    • Lightly moisten a cotton swab with distilled water.
    • Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
    • Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
    • Reinsert the print cartridges.
    • Close the printer cover.
    • Connect the power cord to the back of the printer.
    • Press the Power button to turn on the printer.
  4. Calibrate the print cartridges.
  5. If the light is still flashing, replace the print cartridges.
There is a problem with a print cartridge. Solution
  1. Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
  2. Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
  3. Remove and then reinsert the print cartridge(s) into the printer.
  4. Print the document.
  5. If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
  6. Try printing again. If the problem continues, replace the print cartridges.
The print cartridge has partial loss of electrical interface with the carriage connections.
Posted on Mar 04, 2009
  • 2004 Answers
SOURCE: hp dv5 laptop screen randomly goes blank.
Check your power management settings. Reset to suit your usage. This should fix it.
Posted on Mar 17, 2009
Driver HP 3525 Ink Advantage for Mac OS X 10.5.8
Most Mac have built in driver once you connect your printer to Mac it should recognize it and will download appropriate drive for it
Nov 23, 2013 | Office Equipment & Supplies
I will change ink cartridge but the problem is. I do not know to eject. My printer is HP Deskjet Ink Advantage 2060 all-in one k110. Please help me. Thank you.
Replace the cartridges
To replace the cartridges
1. Check power. Make sure printer is on
2. Load paper.
3. Remove cartridge.
a. Open cartridge door. Wait for print carriage to move to center.
b. Press down to release cartridge, then remove it from slot.
May 30, 2011 | HP Office Equipment & Supplies
HP Pavilion dv7-1245dx Notebook Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
