DVD screen won't stop blinking. - Televison & Video
    Loyalty:
    Visited the website for 30 consecutive days.
  • 372 Answers
Have you tried removing the disk and unplugging it, and then trying a new disk??
Posted on May 18, 2014
Monitor won't turn on after a few hours of being shut off
If it EVER works, then the problem is not a failed part, but a weak part. The most likely component type to give you such problems are capacitors. But very few repair techs know how to find such problems, and even fewer have the equipment needed to find the bad one(s) in-circuit. The failure mode is high ESR (ESR means Equivalent Series Resistance). The lower the ESR, the better. Capacitors with high ESR cannot stabilize circuits which demand high pulse currents, such as in switch mode power supplies.
Apr 24, 2017 | Generic Computers & Internet
Acer am1100 won't start up
Discribe what happens when push the on/off button and you try to boot, fan spin? LED's blink? HDD/DVD light blink? Sound? Any thing on screen at boot? What blue light?
Feb 26, 2013 | Acer Aspire AM1100-B1410A Refurbished AMD...
Unit is off and displays blinking stop and won't come on...
My unit shut down in the middle of the night and had the blinking STOP on a dark screen, would beep 10 times when plugged in aswell. I set the unit on top of a pan and opened the bottom water drain plug. After draining alot of water out the unit allowed itself to be turned back on again. Guess its either extremely humid or the dual hose setup doesn't evaporate the water as fast as they made out. Anyways, I haven't found anyone else post this so I hope this helps someone out there.
Sep 26, 2012 | Haier 14,000-BTU Commercial Cool Portable...
Sony trinitron 2001 32" blinking red 4 times,
Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505.
The vertical output IC and its related circuit parts should be checked. If you are handy in elelctronics, visit this site 'Electro-help'. All details about this fault are given here. Type in 'electronicshelponline.blogspot' into your browsers' search box, and click search. Pull up older posts there.
Jun 24, 2012 | Televison & Video
Vsonic flat screen monitor need blink codes
hi do you mean you are asking for the blinking codes on your viewsonic pc monitor?. usually lcd monitor for pc has no blinking codes, if your monitor just only a blinking indicator and won't turn on, you must check first the source from your pc if their is a signal to turn on the monitor. if just blinking only then won't turn on you must check the power supply of the monitor usually the main cause is bulging capacitor. just replace it with the same value and rating thanks for consulting the fixya good luck.
Feb 26, 2012 | Computers & Internet
Hp dv5020us won't boot. upon power up I get some brief hard drive activity and fan noise. No blinking LED error codes. Caps and/or Num lock LED's do not light. Power LED will glow and HD...
step one, big battery out? skipped that?
step 2, a good power pack , that means 19vdc on those 2 pins.
bingo BIOS screen now work ,yes?
step 3, try an external VGA screen at the P15 VGA jack there
screens work now (BIOS first) yes/no?
remove DVD, drive
and all USB devices
there booting with only 1 memory stick. (got more?, try each 1 by 1)
black screens of *****'.
the lack of flash codes, Implies Power pack is dead. or CPU overheated, and selfshuts down. that fan going dead tells
me the power park is dead.
http://pcdied.com/#black-screens
May 01, 2017 | HP Pavilion dv5020us Notebook
Lg. screen tv mitsubishi HDTV 1080 SERIES INTEGRATED
i went to turn on the tv and the power button don't work
Jun 02, 2008 | Televison & Video
DVD stopped playing all DVDs
Reset you player by doing the following:
With the player on, hooked properly to your television, and on the correct station:
Open the tray
Close the tray (with no DVD inserted)
Hold the stop button down for a full 5 seconds
The CyberHome screen should appear. You should be able to play your dvd's now.
Feb 20, 2008 | Cyberhome CH-DVD 300 DVD Player
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
