Question about Brother MFC 490cw Color Inkjet Multi-Function Printer
Can anyone tell me why my Brother MFC-J630w wont turn on. I was using it earlier. When I unplug it & plug it back in, the light doesn't come on. It just makes a ringing sound.
Did it quit & I need a new one?
  • 26 Answers
1. Unplug the power code then plug it in again. Do this where it plugs into the wall and also do it where the cord plugs into the printer.
2. If the printer is plugged into a power strip, switch to off then to On.
3. If nothing else is plugged into the same wall outlet or power strip, plug in a lamp, for example, to see if it works. If not, the circuit breaker for the wall outlet probably needs to be reset. Circuit breakers are in the main electrical panel/box for your house. There should be one that is moved to the left. Push all the way to left and then push to right firmly until it makes a loud CLICK.
Posted on May 21, 2014
  • 3 Answers
SOURCE: Brother MFC-8400
I found out what the problem was with my machines. It is the gear at the end of the fuser roller. I was able to buy the part at Agson.com and I repaired 3 machines myself. It was quite complicated, but after I did the first one, the other two took only minutes.
Posted on Jan 14, 2009
  • 7 Answers
SOURCE: "brother mfc 7840w printer goes offline and i cannot print need turn printer on and off.
The solution, and it took me a long time to find the simple solution, is to right click on your printer, click properties, click the ports tab and click on your Brother printer and click on configure port (or you can delete the existing one and then add another one). What you want to do is update the IP Address. The problem is that the printer does not have a static IP address, it is dynamic. If you want to confirm that, go to your printer and press the reports button and print out the network configuration report. Your IP address will show on that. It's really the last digit in the IP address that changes. This will absolutely solve your problem. Good Luck!
Posted on May 17, 2009
  • 68 Answers
SOURCE: black print won't work on Brother MFC-845CW
Open the case,i don't sure were the cartridge is located but i think is easy to you to find it.When you found it, wipe the botton part of your cartridge use soft clothe for cleaning.Look at mannual to locate the cartridge.
Posted on May 20, 2009
bob_computer
  • 3153 Answers
SOURCE: not detecting ink cartridge - or saying empty - Brother MFC 240c
Is it an ORIGINAL BROTHER cartridge ? ?
OR
A cheaper version ? ?
Posted on Aug 22, 2009
Jimsta01
  • 405 Answers
SOURCE: MFC-440cn brother printer error unable to print 4f
Problem with printer head or main board
Posted on Mar 29, 2010
Why doesn't my printer print the black text?
With the printer in the ON position take out the black cartridge and put back again and make a sample test text page and see if its recognized and printed,.
Jul 24, 2014 | Brother MFC Office Equipment & Supplies
I want to hook up a printer/fax machine to my Wireless computer. HOW
check whether the wifi function of printer is on or not, there is utility of brother which searches the printer on pc after installation of the software , check it
Feb 01, 2013 | Brother Usb Cable/cord 4 Mfc-8840d...
Mfc-j630w error messagfe 4f
I don't know but I can't enter into maintenence mode I pressed just as its said but it's won't go and I really need my printer??
Jul 15, 2012 | Brother Multi-Function Center MFC-3360c...
Problem with Brother MFC-9840CWD
Hi,Check to see in the connectioncables are all plugged in correctly.Open the printer and see if drumunit and toner cartridges are installed correctly. Sometimes not well installedconsumables are the cause of that particular problem.See if the print driver on yourcomputer is correctly installed. Try and reinstall the driver.Check if your printer is working in onlinemode. Sometimes printer changes online to offline method. If printer is atoffline mode click Start button on your computer, enter Control Panel. Click onHardware and Sound and choose Printers. Right click on Brother MFC-9840CWD andmake sure that the Use Printer offline is not checked.Hope this helps.
May 09, 2012 | Brother MFC-9840CDW Laser Printer
I have a Brother all-in-one printer MFC 420CN and it displays unable to clean...see troubleshooting and routine maintenance in user's guide. Itried turning off and back on but it does not reset...
Try this and see if it works... It works for my Brother MFC-6490CW and I am sure the same process probably will apply to your machine. If it doesn't contact customer service and let them know you need to know how to Power Purge your machine. Good Luck!
Hold down the menu key. While still holding the menu key, unplug the machine and plug it back in. Do not let go of the key until the machine reboots and the screen says "maintenence". Hit the following keys: 7, 6, 4,black start. The machine will then go into "power purge" or deep clean mode for about 5-7 minutes. When complete hit: 99 to get out of maintanence and reboot. Be sure to have extra ink cartidges on hand as it does use up a lot of ink but this process works the best every time when the printer wont print
Jun 04, 2011 | Brother MFC 420CN All-In-One InkJet...
MFC-J630W driver will not install arguments invalid dell E1705,XP pro, installed ok on two other computers
You mention two names of your printer above..
The Brother MFC-490cw and also a MFC-J630W
which printer do you have. or is it both?
Aug 16, 2010 | Brother MFC 490cw Color Inkjet...
Problems with Brother MFC-7820N Laser Printer turns itself off
I just had same issue, it shared an outlet with a large volume work group copier, I unplugged it, opened and closed all compartments to make sure something open was not causing issues. I plugged it into different outlet and it appears to be back online. I have read some postings that this model has been known to draw over 15 amps. Its possible its starving for power. To test take to another room, plug in outlet by itself and see if it boots up.
May 29, 2009 | Brother MFC-7820N Laser Printer
Brother MFC-210 Printer Trouble
unplug for at least 20 minutes, then disconnect all the cables from the printer, plug power cable back in and turn back on
what happens?
look in your manual, is there anything to set back to factory default? if so do this if the first steps don't work
Jan 04, 2008 | Brother MFC 210C All-In-One InkJet Printer
Same problems as others...
the brother printer is not a good brand i also have a brother mfc 3220cn and it gives the same problem, what you have to is unplug the machine and let it stand for about 2 days take out the cartridges and clean the printing with air replace back them and plug in.that should remedy your problem.i urge on you never to buy brother printers.if you buy them get a bottle of phensic along with it.good luck my brother*
Apr 27, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 490cw Color Inkjet Multi-Function Printer Logo
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
