Question about Braun Activator 8595 Electric Shaver
Shaver has lost charge, won't recharge on station, no indicator lights on shaver or station, won't run with cord plugged in, no indicator light with cord plugged in
  • Manuel Medina Martin Apr 04, 2017
    I can fix your shaver Braun Activator 8595 my mail for service is medina604@ gmail.com
  • 10,865 Answers
Here is the link to the manual and the service center http://www.braun.com/us/home.html
Posted on Jun 23, 2009
Why have I got a red light on the bottom of my shaver when I am using it
It is common for many Braun shavers, that if the indicator light flashes red while the shaver is being used (switched on and running), it means the battery is low and needs to be charged soon.
Below is an example from a manual for a Braun model 7526 shaver. You can search that site for other manuals if this is not the correct one.
This model shaver has 3 indicator lights:
1) Green (Charging)
2) Red (Low battery)
3) Blue (Power cord attached and plugged into the wall)
Download the manual for the model 7526 here: http://www.manualslib.com/manual/20281/Braun-5301.html#manual
"The green charging light shows that the
shaver is being charged. When the rechargeable
battery is fully charged, the charging light
flashes or goes off.
If later on, the charging light comes on
again, this indicates that the shaver is
being recharged to maintain its full
capacity.
The red low-charge light flashes when the
battery capacity has dropped below 20%,
provided the shaver is switched on. The
remaining capacity will then be sufficient
for 2 to 3 shaves."
Nov 09, 2015 | Braun Health & Beauty
Green light on DC44 but nothing is happening
Hi Emma, it's Jack at Dyson.
I'm sorry to hear your DC44 Animal doesn't seem to be working correctly. If the green LED indicator on the machine lights up, but the machine itself doesn't run, this suggests the battery is flat. It could mean that it's not recharging correctly when connected to the docking station.
It would be worth temporarily disconnecting and removing the charger cord from the docking station and plugging it directly into the machine - the machine should recharge fully within 3.5 hours. If the machine then works as normal the charger cord may not have been corrected fitted to the docking station.
If you'd like further advice from our experts after you've given this a try, please call the Dyson customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Jan 01, 2014 | Dyson DC16 Root 6 Bagless Handheld...
How do you recharge jump start system
put a battery charger for a car on the + and - leads and this will recharge it if you do not have the correct power pack recharge transformer
Jan 09, 2012 | Stanley Black & Decker Stanley J5c09 500...
My shaver does not work even when i plug in the cord. The charger light comes on but I do not know if it is charging. i have opened the back and saw the battery contacts corroded. Is the battery dead?
Model 6616X is a rechargeable shaver only. It is not designed to run directly from the cord. Probably, the battery is dead and needs to be replaced. You will find the correct bttery at shaveroutlet.com. See link below. Scroll down the page for helpful installation videos
http://shaveroutlet.com/shaver-replacement-parts/batteries/shaver-battery-pack-for-most-shavers-p-211.html
Aug 28, 2011 | Norelco 6615 X Electric Shaver
Hello i have phillips cool skin shaver cant remember proper model of it but its the one with stand charge which fills up shaver with this skin balm and also there i small stand charger as well and none of...
Hi pi finch,
Below are some troubleshooting steps for this issue. If you have any questions or need additional assistance, Consumer Care can be reached at 1-800-243-3050.
Question Why does the shaver not charge when I place it in the refill & charge station? Answer
  • The adapter has not been properly inserted in the wall outlet
  • the small plug has not been inserted properly in the refill & charge station.
  • There is no electric contact between the refill & charge station and the shaver because the shaver has not been placed properly in the station. First put the bottom of the shaver in the station. Then push the shaver backward till it locks into position with a click. The indication lights on the shaver and the station light up to signal that there is proper contact between shaver and station.
  • There is no electric contact between the refill & charge station and the shaver because the contact strips are dirty. Clean the strips with a damp cloth.
Hope this helps. If so, let me know by rating this solution.
Aug 05, 2011 | Philips Health & Beauty
WILL NOT GHARGE RIGHT...VERY WEAK MODEL R845
Rechargeable batteries can become weakened over time by light use and light charging. Try running the shaver totally flat and then charge the shaver over night. If this gives you back your batteries back their charge then in future run the shaver until flat each time before charging.
Jun 11, 2010 | Remington Microflex R-845 Electric Shaver
Razor will not take a charge, will only function when plugged in.
Sounds like the batteries are shot. They can be replaced if you're handy with a soldering iron.
Apr 30, 2010 | Norelco Rechargeable Cordless Men's Razor...
I have a 3805 Philips shaver - no low battery indicator - how do i know when charged?
The 3805 has only a green charging indicator. This light will illuminate solidly when plugged in. Charging takes a full 8 hours. There is no indicator to tell you when to recharge. If the batteries are in good condition, you should be able to use the shaver for 7-10 days on a full charge
Mar 13, 2010 | Philips Health & Beauty
Braun 5614 rechargeable cordless shaver light flickers
Your batteries are starting to degrade, but the good news is they're still holding a charge for a week, so you really don't need to rush to replace them at this point.
The flickering of the charged indicator is normal, as the shaver is still plugged in and the batteries are fully charged. The flickering is due to the batteries chemicals breaking down, and as such, the charge cycle keeps "topping" them off while it's still plugged in.
When you finally aren't able to get a decent amount of cordless operation and run times from your shaver, then you'll want to get them replaced, whether you decide to do that yourself or have it done by a professional service center, is up to you.
Here's a reference for your future use. www.electricshaver.com carries replacement (factory OEM) batteries for most brands of shavers and they also will provide the repair/replacement service for you, should you decide you don't want to do it yourself. You can also give them a call at 1-888-476-1785 and request a price quote, etc.
Anyway, your shaver is working fine and all you need to do is make sure you're not letting the shaver stay plugged in and charging constantly for more than a day, since any "extra" chargind isn't doing anything except keeping the batteries at a constant state of charge. Heat is a byproduct of charging and discharging any battery and as such, you want to allow for a cool down period before recharging them.
I tend to use my shaver until it is almost completely discharged before recharging it. By doing this, you can get the longest working life out of your batteries before you'll have to replace them.
Hope you find this Very Helpful and best regards!
Oct 21, 2009 | Braun Flex XP 5614 Electric Shaver
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
Braun Activator 8595 Electric Shaver Logo
724 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
