Question about Panasonic Microwave Ovens
Nn sd466m Why does it stop after a few seconds and not heat?
SOURCE: Panasonic NN-T994SF Microwave Oven quits after 15 seconds
my microwave shuts off after a few seconds. is there a fuse that needs replacing?
Posted on Nov 24, 2010
heatman101
  • 43501 Answers
SOURCE: Panasonic NN-H665BF starts and will
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 [
Posted on Aug 13, 2011
MicrowaveSvc
  • 9047 Answers
SOURCE: My panasonic microwave NN-S954WF will run a few seconds and then stop. What should I check?
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter, controller, magnetron, or a bad connection from one or the other.
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
If it stops after 7 seconds, it has a problem with the inverter.
If it stops at 2-3 seconds, see if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://031d26d.namesecurehost.com/mwd/safety.txt http://031d26d.namesecurehost.com/mwd/disassembly.txt http://031d26d.namesecurehost.com/mwd/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Posted on Nov 26, 2011
  • 6771 Answers
SOURCE: NN-T945SFX
The thermal fuse may be defective, monitors temperature of the magnetron, or the internal fan may not be operating properly, it is possible the magnetron may have a shorted winding.
Posted on Mar 23, 2012
  • 6771 Answers
SOURCE: my panasonic microwave NN-772SBBPQ works for about 12 seconds does not heat and stops
This indicates a short in the keypad membrane that is attached to the control board, depending on age, replacement of the microwave oven might be a better option.
Posted on Apr 01, 2012
Panasonic NN-H665BF starts and will run for about 5 seconds and then stops without heating up anything.
heatman101 [
Aug 07, 2011 | Panasonic NN-S541 Microwave Oven
Where is the second fuse in my panasonic nn-s963bf the one for the heating and what does it look like?
There is no second fuse. Look for a thermal cutoff there are a few of those. Test it for open circuit and replace.
Aug 11, 2010 | Panasonic NN-S963BF Microwave Oven
Feb 01, 2010 | Panasonic NN-T994SF Microwave Oven
Microwave NN - T290SA starts but shuts off after a few seconds. Is it worth repairing?
usually this is the temeperature sensor that is faulty or that you have pushed the unit back against the wall too far and not enough airflow to allow it to remain within the tolerence levels of heat generation.
New sensor is about $30.
Please rate our help to keep Free service online ++++ Thanjks for using Fixya
Sep 02, 2009 | Panasonic NN-T790SA Microwave Oven
Intermittent heat in microwave
heatman101
fgssg
Jul 14, 2009 | Panasonic NN-SN657SMicrowave Oven
Stopped heating, shuts off before time expires
My panasonic microwave model # NN-S540BFW stops after 4 seconds after you hit the start button and cuts off on its own. What is wrong with my microwave?
Jan 12, 2009 | Panasonic NN-S763BF Microwave Oven
Panasonic Microwave Oven Stops After 15 seconds - Never Heats
You can order Panasonic parts from Tritronics.
If you reconsider, you can find an authorized Panasonic servicer here.
Oct 21, 2008 | Microwave Ovens
Microwave Ovens Logo
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
