Question about Garden
My deck isn't engaging and I'm sure I screwed up the electrical. I disconnected the pto and it's not engaging now
Lth 130 kolher 13hp
  • 2,760 Answers
Do you think you dammged the cable or connector to pto clutch as it's electrical ?? if so you'll need to repair/replace this
Posted on Jun 03, 2014
  • 42 Answers
SOURCE: need a diagram for husqvarna model lth-130 mower deck belt
Here is a diagram I have found for you.
convert?ilfn=d%3a%5cempartweb_52%5ccatalog%20data%5cemp_img%5chus%5cimages%5c07%5c36%5c0031.tif&ilsc=16&iliv=0&ilbr=0&ilif=g&ilre=8
Posted on Apr 06, 2009
  • 130 Answers
SOURCE: electric pto won't stay engaged on LT 1045
you have a shortage or your clutch is going bad
Posted on Jul 18, 2009
  • 138 Answers
SOURCE: Engine dies when clutch is released or PTO is engaged
flop the seat forward, locate the seat switch in the middle of the seat, push the connector onto the seat switch firmly, start it up and drive away
Posted on Aug 17, 2009
  • 16 Answers
SOURCE: Cub cadet lt 1050 electric pto want engage??????????
make shure pig tail is hooked right
Posted on Oct 17, 2009
  • 18 Answers
SOURCE: PTO loads engine down and almost quits running!
pto is going bad
Posted on Jun 06, 2010
Why doesn't the PTO engage the blades?
assuming the PTO is an electric clutch engagement ? if so you must not be getting voltage to it. also you may have a safety switch restricting voltage from getting there. i have a rider that has this type of PTO and if my battery gets low mine will cut in and out as i mow. i charge my battery and then it works just fine. check for voltage at the clutch and also you can check continuity of the switch itself to make sure it does work. hope this is some help
Oct 13, 2015 | Garden
Can I get a picture of a 46" deck layout for a black mtd yard machine so I can c how the deck engagement cable go
Only seen one or two H decks here.
if it is this cable
then it connects to the RH brake assembly and the PTO engagement plate. There is also a spring that connects at the same point on the engagement plate to the right hand frame.
Apr 18, 2015 | Mtd Garden
Electric clutch wont engage when when switched on even though I can hear a clicking sound at the clutch.
PTO Clutch will not stay engaged.
There is a very fine one page discussion on evaluating electric clutches at this site:
http://www.messicks.com/Articles/FixingElectricClutch.aspx
My JD tech manual, which covers the entire LA 100 series, agrees with the electrical specifications. It states that the Electric PTO Clutch should show the following:
  • Resistance 3.7 ohms
  • Current Draw 3.25 amps.
It does not give the air gap. It does include a note to check the PTO Clutch Key for damage or if missing. So there is a drive key between the PTO Clutch and the shaft. Additionally, it recommends checking the tightness of the cap screw. That's the screw or bolt that holds the clutch on the shaft.
  • Cap Screw torque 55 lb-ft (75 N.m).
Fixing Electric Clutches
Apr 11, 2015 | Swisher 60" 26 Hp Zero Turn Radius Riding...
Blades won't engage after got stuck in mud electronic pull on blade engagement
Blades would not turn after I got stuck in mud. Electric clutch.
  • Turn the engine off and remove the key.
  • Check for physical damage; anything look bent?
  • Is the deck belt intact?
  • Spin the pulley on the bottom of the clutch. Does it spin freely?
  • There could be mud or grit stuck in the clutch.
  • There is a drive key between the clutch and the shaft. Has this key been sheared?
  • When you pull the PTO switch does the clutch make a "click"? It's possible the clutch was burnt out during the mud incidence.
PTO Clutch will not engage or stay engaged.
There is a very fine discussion on evaluating electric clutches at this site:
  • It does not give the air gap.
Apr 10, 2015 | Garden
Pull switch on blades but they won't engage worked fine until i got stuck in some mud now won't engage
Mowerdeck will not engage...
I own a similiar John Deere model (L130, 23HP with a 48" deck). I would check the electric clutch (called a PTO). To do this check the wires to this clutch and look for something disconnected. These wires (to this PTO clutch) should have twelve volts with the key on and the blades engaged.
Feb 26, 2011 | John Deere 195HP Hydrostatic 42" Cut...
Mower deck PTO switch will engage when pulled but stop when rele
The PTO switch has failed. There is an internal spring and plastic parts in toggle switches that keep them in the actuated position. It's not practical to take the switch apart to fix it, but replacement switches are readily available - probably $12 - $20. It's a good idea to disconnect the negative terminal from the battery before you do any electrical work. Be sure to put the wires on the corresponding terminals of the new switch. Good luck! Please rate if you find this helpful, thanks.
Jun 03, 2010 | Husqvarna 23 Hp 48" Deck Yard Tractor
The engine start running rough when pto in engaged.
Are you sure you engine RPM's are high enough? If so adjust you carbs.high speed screw with the throttle in the wide open position.
May 01, 2010 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Deck belt does not engage blades on riding tractor
Be sure the belt is the correct size and is routed correctly.
If you are not sure, you can download a manual here:
http://manuals.mtdproducts.com/mtd/public/list.jsp
You will need the model & serial numbers.
Apr 18, 2009 | Oregon Scientific Electric PTO Clutch for...
Garden Logo
49 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
