How to unlock sumura cable converter - Televison & Video
Hi my mini convertible roof it not working . hooks will not lift
If the hooks unlock on one side and not the other the cable that pulls the hooks is broken on one side. This requires the front section of the convertible top to be replaced. Unfortunately there is no way to fix the cable that connects to the hooks.
Sep 12, 2014 | 2004 Mini Cooper
How to unlock locked channels in our ty-187 cable converter through the remote control
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Unlock procedure to many popular brand TVs are given.
May 25, 2014 | Televison & Video
01 chrysler sebring convertible dead battery car wont unlock with key
try to reach up under the front of the car with your arm and try to locate the latch with the hood release cable attached to it. Use your fingers or plyers to manipulate the latch to release-pull on the cable. You may have to remove the grill to access it.
Dec 16, 2013 | 2001 Chrysler Sebring
How do I unlock a torque converter on a 99 jeep Cherokee
cant unlock torque converter when internal malfunction occurs torque converter has to be replaced. sound like you have faulty TRANSMISSION TCC SOLENOID SWITCH. if torque converter stalling out the engine.
Jul 09, 2013 | Cars & Trucks
Hot to unlock channels for the TY-187 Tv cable converter?
i want know the unlock code for ty-187... plss help me
May 03, 2011 | Televison & Video
C71/DIN UNLOCK
The definiton in the manual suggests you are trying to record a digital bitstream that is either dead or incompatible with the recorder. Go analog.
What happens if you skip the receiver? Be advised that anything coming in digitally through a cable/satellite box may be muliti-channel and convertible by the player to its native 44.1 khz sampling rate.
Mar 31, 2010 | Sony RCD-W500C 5-Disc CD Recorder
Sony Ericsson K800i - convert to Network open line
no codes as only networks use these and charge hey over the odds for it but you may want to look here http://forums.se-nse.net/topic/20668-who-wants-to-unlock-k800-db2020-cid52-for-free-with-supplied-dcu-60-cable/
Mar 31, 2010 | Sony Ericsson K800i Cellular Phone
Transmission converter seems to lock and unlock
Hello;
You may have two problems at the same time. The speed sensor is the easiest to replace. I would check and or replace the sensor. Then if the test drive shows the lock up fluctuating, I would replace the lock up switch in the transmission. Let me know if you have questions. Hope this helps. Rate me highly, please.
Thanks;
Rich
RPM Northwest
Mar 21, 2009 | Chevrolet Suburban 1500 Cars & Trucks
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
