Question about Kenmore 79383 Dual Fuel (Electric and Gas) Kitchen Range
Where is the fuel pump relay switch located on a 1988 ford ranger.
    Master:
  • Kenmore Master
  • 460 Answers
Right hand kick panel on passenger side
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Posted on May 18, 2014
check fuses relay on left inner fender in black box take on lid inside of box they are marked if all fusses & relays are all right, then your fuel pump is went bad
May 18, 2014 | 1988 Ford Ranger
1988 Ford Ranger 2.9L A/T, 2wd, A/C. Won't Start. Fuel pump does not come on. Scan tool cannot connect to the ECM. Verified Fuel pump Relay good. Ground to STO Fuel pump pin will engage the fuel...
The engine computer must be working to get spark and fuel injector pulse. I would want to know if the computer has power and is functional. The computer grounds the EEC relay and the fuel pump relay as well as the injectors.
Aug 26, 2013 | 1988 Ford Ranger
Where is the fuel pump relay on a 1988 ford ranger
its a little black box under the hood ...
TIP
on these older (1988) rangers , they have a fuel shut off (incase of roll over) that needs to be reset on occasion.
This shut off is located in the passengers foot area just forward of the passengers door on the floor.
remove that kick pannel and press the red button on top of that to reset it.
Sep 28, 2011 | 1988 Ford Ranger
Can not find the location of the engine computer in my 1988 Ford Ranger supercab
It's the black box under the hood not to be confused with the fuel relay switch box and so on
Jan 29, 2011 | 1988 Ford Ranger
2000 ranger fuse diagram
Fuel Pump relay switch is in the main box usually located on the drivers side Fender in a black box. According to the owner's manual in the power distribution box in the engine
compartment (Ford recommends disconnecting your battery)
Relay # 5 is the fuel pump relay , and also in the PD BOX is a 20 amp mini-fuse
for the fuel pump relay + RAP module in location # 9
( P.S. - don't forget your fuel pump inertia switch , in the right front passenger area ,
by the right front kick panel )Sometimes this gets kicked by passenger or if the car is bummed hard it could set this item to shut down fuel system. Best of Luck
Aug 28, 2009 | 2000 Ford Ranger SuperCab
1988 ranger 2.9 no fuel pressure new pump
check the pulse on the injector wire with a noid lite or a meter. If no flash then you most likely need a computer. Its called a quad driver in the PCM thats fried. You may have a shorted component that caused it to fail.
Since you say it will run if you add fuel manually I don't suspect the crank sensor because you have spark.
Aug 15, 2009 | 1988 Ford Ranger
Ford ranger fuel shutoff switch
i bet its the ecm relay if it starts cutting out then dies then it is the ecm relay i had one that did the same thing if its your fuel relay unplug it clean the terminals and plug it back in if it still does it buy a new one and replace if you bypass it you take a chance of burning the truck too the ground and if ya dont really care about that then find your positive wire in the plug with the key on and hook it too the one that runs your fuel pump so its hard wired
Jul 22, 2009 | 1988 Ford Ranger
Kenmore 79383 Dual Fuel (Electric and Gas) Kitchen Range Logo
27 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
