Question about West Marine Inverter 3000 Watt Continuous Power
IT IS MAKING A BUS SOUND AND DOSE NOT WORK
WHEN I TURN IT ON I GET A CONTINUEING BUS SOUND WHATS WRONG
    Loyalty:
    Visited the website for 30 consecutive days.
  • 372 Answers
Unit is deffective most likely.
Probably has a bad Coil (transformer)
Posted on May 18, 2014
What time is bus from whitegate to rosegrove & lowerhouse lancashire
call the bus depot direct
fixya site is not a travel agent
Jun 20, 2017 | Cars & Trucks
What is Pulse Flow and how is it different from Continuous Flow ?
Pulse and continuous flow (or pulse dose and continuous flow dose) refer to how the oxygen is delivered to the patient. A pulse flow machine delivers oxygen only when the patient inhales and is triggered by inhaling. A continuous flow machine delivers a continuous flow of oxygen. Most continuous flow machines will deliver BOTH pulse and continuous flow. Here is oxygen tank process
Portable Oxygen Concentrators How They Work How To Choose Them
Dec 19, 2016 | Cars & Trucks
What dose no bus on instrument panel where milage is means
may be static ,,, so turn off ign and all electrics and disconnect battery for ten minuites ,,,,, then reconnect and make sure you have a radio code before you do it ,,,,
Dec 06, 2013 | 1999 Jeep Cherokee
I have a 04 durango hemi and havin a problem with the horn I turn off my truck lock it by the remote in the door not using the key because my dose not work ok everything its lock and close then after a...
Do you know what a relay is an how they work ? Relay contact's could be stuck closed ,or security system could be turning it on .
Watch this video an check it like a pro.
VEHICLE RELAYS Operation Diagnosis
Do you know what a wiring diagram is ? Free one's here http://www.bbbind.com/free_tsb.html Enter vehicle info. Year , make , model and engine . Under system click on interior & driver amenity , then under subsystem click on horn . Click the search button then the blue link . You will see by looking at the diagram the horn relay is controlled electronically . The horn switch on the steering wheel is an input to the insturment cluster . The cluster then sends a message on the CCD communication data bus to the front control module . Do you know what the chrysler CCD bus is ? CCD Chrysler Collision Detection Data Bus
The relay is located in the under hood fuse / relay box.
Sep 08, 2017 | 2004 Dodge Durango
The microwave turns on and sounds like it is working but dose not heat up anything. GE 11660bb
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 17, 2011 | Ovens
I got the foxconn G4M1MX-F 2.0 and i put it into my computer... but the computer turns on but nothing loads... screen dose not turn on or anything any ideas.....
do you hear any bios beeps at all? is the cpu fan running? and make sure you got the power coming from the power button hooked into the right header on the mobo
Mar 26, 2011 | Foxconn G41MX-F 2.0 Socket 775 Celeron...
My car starts once then wont start again. Its a 92 Subaru. We tested the starter and it tested fine. Could it be the armiture?
What dose it do after starting then you turn it off whet dose it do /how and wheat type of sound dose it make ,,dose it just go clonk and nothing else/or dose it turn over slowly and dont fire Iwant to get all information before stating the problem.
If it tested ok then the starter should be good
Let me know how it sounds Ron
Oct 02, 2009 | 1992 Subaru Legacy
Check Engine Light for 2 years.
The p1687 code is a NO MIC BUS MESSAGE( mechanical instrurment cluster). When replaced the guages did you replace the whole cluster? here is the diag for this code. 48 Turn ignition on, Engine not running.
Using the DRB, erase codes.
Cycle the ignition key on and off several times.
With the DRB read PCM trouble codes. LOOK for P1687.
Did the No PCI Bus Message from MIC trouble code return?
Yes ® Go To 50
No ® Go To 49
49 Turn the ignition key on, Engine not running.
Does the Odometer in the Instrument Cluster display No Bus?
Yes ® Go To 50
No ® Go To 51
50 Turn ignition off.
Disconnect the PCM.
Disconnect the Instrument Cluster Connector.
Using an ohmmeter, measure the PCI Bus Circuit between the PCM and the
Is the resistance below 5.0 ohms?
Yes ® Replace the Instrument Cluster.
Perform Powertrain Verification Test VER-1A.
No ® Repair the open PCI Bus Circuit.
51 Turn ignition off.
Note: Visually inspect the related wiring harness. Look for any chafed,
pierced, pinched, or partially broken wires.
Note: Visually inspect the related wire harness connectors. Look for broken,
bent, pushed out, or corroded terminals.
(DRB is the factory scan tool you can use subtitute if you have access)
Mar 12, 2009 | 2000 Dodge Neon
About sound device...
http://drivers.softpedia.com/get/SOUND-CARD/OTHER-SOUNDCARDS/Microsoft-UAA-Bus-Driver-for-High-Definition-Audio.shtml
to make the sound driver work
you must first download the UAA driver on the above page
then go to device drivers and upgrade the sound one it will go on net to find and install them
Aug 30, 2008 | Compaq Computers & Internet
West Marine Inverter 3000 Watt Continuous Power Logo
66 people viewed this question
Top West Marine Electronics - Others Experts
Are you a West Marine Electronics - Other Expert? Answer questions, earn points and help others
