Question about Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966
Describe string replacement Troy- Bilt TB5755SS
  • 1,041 Answers
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
Jim
Posted on Jun 24, 2009
  • Jim Parker
    Jim Parker Jun 27, 2009
    Did this solution solve the problem?
    Jim
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
How do I replace string trimmer string on 4cycle Troy bilt string ttrimmer
verify that you are using the proper diameter trimmer line, if you have the proper line, replace the head of the trimmer
Sep 14, 2014 | Troy Garden
Troy bilt troubleshooting
Bushing is worn out. You will need to replace the shaft. Fairly inexpensive.
Aug 24, 2014 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
My 4-cycle troy-bilt string trimmer: string is locked up. I can not pull the string
Your String needs to be re-wound. You are almost out of string or your string has Jammed under the Motor and placing a DRAG on the Trimmer
Apr 08, 2013 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Replace duel string trimmer line
Change the line on Troy Bilt 4cycle TB525EC weed eater
Oct 16, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy-bilt trimmer TB 490 BC
Turn the bump knob clockwise to loosen on my tb490bc.
May 29, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy Bilt string trimmer starts but dies when I try to give it gas to trim.
Try mixing up some fresh gas mixture if it is over 30 days old it is considered bad gas. Or the carburetor may need to be rebuilt.
Sep 30, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Describe your troybilt tb70ss pull string Problem.
Do you have mfg instructions? Can be very tricky without following instructions
Sep 29, 2009 | Troy Bilt Tb70ss Gas Trimmer
TROY BILT TRIMMER MODEL TB70SS. HOW DO I REPLACE
Is the pull rope in the front or rear of engine.Thinking that the string is in the front,you must throttle housing and shaft from engine. remove starter housing. There sould be a screw holding the string and spring in place.
May 07, 2009 | Troy -Bilt String Trimmer/Blower...
Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966 Logo
864 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
