Question about Nikon Coolpix S9100 12.1mp Digital Camera red 26249
1997 subaru check engine light flashing rapidly looling fans cycling on and off when engine is cold and not running
  • 4 Answers
Change temp, sensor or sending unit
Posted on May 18, 2014
Why is my 1997 Subaru Outback power light flashing 16 times when starting engine? Also Check Engine light comes on intermittently while driving?
Engine light comes on when service is needed usually, oabout service time ish. I would consult a dealers mechanic...just in case
May 30, 2015 | 1997 Subaru Outback
What would cause check engine light to flash rapidly and cooling fans cycle on and off with key on and engine not running
There is a diagnostic connector under the dash board that is supposed to be left disconnected (green) if you connect then it forces it into diag mode.....
May 18, 2014 | 1997 Subaru Legacy
Cold start valve
use a code reader to reset the computer. As to the cold start valve have the subaru mechanic point it out just to see if he is telling tales or not.
May 30, 2013 | ACT Subaru 1997-2006 Forester 2.5L,...
Subaru legacy 1997 shudders when accelerating through changing gears car is automatic
if this happens while the engine is cold please run it idle once to start in the morning then drive and if it does always then. put the gear to neutral with the brakes on and push the accelerator slowly to higher side to see if engine is smooth if it shakes or shudders or engine seems to un stable use carburettor cleaner with the engine roaring say around 2000-2500 rpm. just spray from the opening intake of the air filter on top of the engine. spray two to three times, if it does not work remove the top cover of air filter remove the air filter and close the cover then try again. if it still does not help take the car to service station to check for all hydraulic oil and clutch oil. are you sure that engine oil is on top indicator or it is low. this could also be the reason and the engine could cease also.better first check for the engine oil level on the oil dipstick.usually located near the fan belts of the engine front side
Aug 29, 2012 | 1997 Subaru Legacy
An341@hotmailcooling fans come on soon as the engine starts and check engine light is on as well ?
Had a related/similar problem with my 1995 Subaru Impreza; cooling fans would come on and check engine light would illuminate (while fans were running). Problem resolved with replacement of coolant temperature sensor.
Apr 04, 2011 | 1995 Subaru Impreza
Head and tail lights won't turn off when key is removed.
wires must have been trapped,shorted when engine was removed, check loom for damage
Jul 05, 2010 | 1997 Subaru Legacy
97 subaru outback 2.5- just checked the trouble codes after check engine light went on. what could be causing radiator fan problem?
Faulty cooling fan relay, faulty coolant temperature sensor, or the fan assembly itself is defective.
Feb 23, 2010 | 1997 Subaru Legacy
If the fan and compressor are both running and no cold air
are you sure the compressor is operating,can you hear it cycling over the noise of the fan???if its not its probably got one of 2 things wrong,rapid cycling or no comp operation: low refrigerant, no start condition: capacitor or contactor
Aug 02, 2009 | Haier HWR10XC3 Air Conditioner
Common fault codes for subaru legacy
replace the coolant temperature sensor (2 pins)... im not sure but i think is brown...
Jan 07, 2009 | 1997 Subaru Legacy
Check engine !
please send information of control computer for subaru forester 1997,
Aug 28, 2008 | 1998 Subaru Forester
Nikon Coolpix S9100 12.1mp Digital Camera red 26249 Logo
16 people viewed this question
Top Nikon Cameras Experts
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
